Tire Fitment: 35x12.50 or 285x75? on 17x8.5 - 0 offset wheel with 2" level.
Discussion in '3rd Gen Tundras (2022+)' started by Taykn, Jan 15, 2024.
  1. Jan 15, 2024 at 10:41 PM
    Taykn
    Taykn [OP] New Member
    Hi everyone,
    I have a 2 inch Readylift Leveling kit installed on my truck and Im looking to get that big tire smaller rim look with some poke on my truck.
    Im currently running 35x12.50-20 on the stock 2024 platinum tundra wheels. I am also currently having small amount of rubbing on my upper control arms when in full lock with the stock wheels. I figured an offset might help with and I really like the look of 0 offset but I'm afraid that a 0 offset may be too much and may cause rubbing on the fenders or else where and have the same issue but in a different area.
    Anyone know if running a 0 offset on size 285x75 tires will work?(keep the 2" level in mind) Or anyone successfully running that exact set up with no rubbing? Or will I need any trimming done?
    Thanks in advance!
  2. Jan 15, 2024 at 10:43 PM
    Taykn
    I just want to add that I understand that the tires are very similar in size but figured the thinner tire may help midigate rubbing.
  3. Jan 16, 2024 at 11:05 AM
    22platitundy
    22platitundy New Member
    2022 White Tundra Hybrid Limited TRD Off-Road
    Yeah you could just get a wheel with an offset of say +18 or lower and it would move the tires away from your UCAs. Or wheel spacers. Because the stock platinum wheels with the Lunar look awesome IMO. I have a 2 in level on mine and am running +12 17 in wheels with 35x12.5 tires. They rubbed the mudflaps but I removed those. I just need to pin back the liner.
  4. Jan 16, 2024 at 2:28 PM
    22platitundy
    I’ve heard all different things with different setups. They removed the metal piece sitting behind the wheel well on mine or it would have rubbed pretty heavy. What kit do you have?
  5. Jan 16, 2024 at 5:31 PM
    Magnetic1
    Magnetic1 New Member
    The Lunar with those wheels/color looks very nice. Curious does the front now sit a bit higher then the back with that 2" level? I was thinking about going with a 1.75" RC to get as close to level as possible on my 1794.
  6. Jan 16, 2024 at 6:57 PM
    ArBrnSnpr
    ArBrnSnpr New Member
    Colin
    22' AG SR5 TRD OR
    I'm running 35x12.5 on the 18" TRD off-road wheels.
    I have a 1" wheel spacer and a 1.5" Procomp leveling spacer and I don't rub. No body mount chop, mud flaps are still installed and no cutting on the fender liners.
  7. Jan 16, 2024 at 11:30 PM
    romanlegion
    romanlegion New Member
    Roman
    Katy, TX
    2022 Tundra SR5 TRD Off-Road Lunar Rock
    +20 to +30 wheel offset on a 12.50" tire width if you don't want any rubbing issues.
    I run a 17X8.5 +25 wrapped in a 37X12.50R17. Zero rubbing even when going on trail runs, etc.
  8. Jan 17, 2024 at 8:56 AM
    ArBrnSnpr
    Colin
    22' AG SR5 TRD OR
    What wheel?
    I'm having a hell of a time finding an 8.5, not 9" wide wheel with any type of offset that would fit and actually compress into the wheelwell.
    I love the look of the 0 offset wheels, but I'd like to save my fenders if possible.
  9. Jan 17, 2024 at 12:47 PM
    Maharisc
    Maharisc w/Patty
    Karl
    Build date: 12/05/22
  10. Jan 17, 2024 at 12:58 PM
    ArBrnSnpr
    Colin
    22' AG SR5 TRD OR
    I've known about the size similarities for years, but I never knew about the weight. That's massive! And to consider that you're saving money too makes it a no brainier! I just wish there was a similar hack for 37's.
  11. Jan 17, 2024 at 8:39 PM
    romanlegion
    Roman
    Katy, TX
  12. Jan 17, 2024 at 9:06 PM
    romanlegion
    Roman
    Katy, TX
    In my opinion, the main difference between tires that are LT-metric and Flotation are the tread depth, shoulder block dimensions, and sidewall lug thickness. Tires with flotation sizes will usually have a deeper tread, bigger shoulder blocks, and thicker sidewall lugs, which means more rubber, heavier tire, and higher price.
    The closest you're going to get to a 37" OD tire with an LT-metric is the Nitto Trail Grappler LT325/60R20 (35.6" OD and 13" width).
  13. Jan 18, 2024 at 2:35 AM
    Blufin
    Blufin Seasoned member
    Bob
    Cape Cod,MA.
    23 Capstone
    "I'm tellin ya right now" LMAO!
    Man do ya think he said it enough!?
    Good info but I'm tellin ya right now, it's either a rip off or a HUGE rip off!
    Hahahahahahaha!
    Eurodriver likes this.
  14. Jan 18, 2024 at 6:40 AM
    Maharisc
    Maharisc w/Patty
    Karl
    No Sir, not mine.. I do very few videos for the public on YT.
