4 x4 speed
Discussion in '2.5 Gen Tundras (2014-2021)' started by PNJ 4x4, Jan 17, 2024.
  1. Jan 17, 2024 at 2:53 PM
    PNJ 4x4
    PNJ 4x4 [OP] New Member
    2018 TRD OFF ROAD
    Any thoughts on max speeds in 4wd? I dont usually exceed 60 mph
  2. Jan 17, 2024 at 2:55 PM
    Don't think it matters. Max speed to engage or disengage is 60mph or so. Once your in 4wd, go to town.
  3. Jan 17, 2024 at 3:21 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I don't stay at the high speeds but 75-85 no issues. Some also are in 4wd at the drag strips.
    HulkSmurf14 likes this.
  4. Jan 17, 2024 at 4:46 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I don’t know of actual limit of 4H after it’s already engaged. But if you NEED 4x4 due to road conditions (snow, mud etc), I don’t think you need to be going over 60 anyway. YMMV though.
    yakeng, Philipl and PermaFrostTRD like this.
  5. Jan 18, 2024 at 8:52 AM
    seydou
    seydou Distinguished Member
    My manual states 62mph as the cut-off for switching into or out of 4WD. An alarm will sound when trying to engage over that limit but not when disengaging. Then the light will simply blink until speed is reduced enough and disengagement occurs.
