Newb gen 3 owner questions
Discussion in '3rd Gen Tundras (2022+)' started by FLO, Jan 15, 2024.
  1. Jan 15, 2024 at 7:25 AM
    FLO
    FLO [OP] New Member
    Frank
    2024 Tundra SR5
    None
    Just picked up a 2024 SR5 a few days ago and I have a few questions for the more experienced gen3 owners. Is the open design of the wheel wells any concern to non-off road driving? I was surprised to see how open they are especially the drivers side front with clear view of a belt/pulley. No snow to worry about down here in lower AL but plenty of flash floods and puddles on my usual driving routes. I did a search here and only found this topic discussed for off roading.
    Another topic, I like to surf and paddle board a lot and don’t want to carry a key fob for obvious reasons. With my old gen2 I just kept a good old fashion manual key secured in my board shorts or wetsuit. I can see I don’t have that option anymore with the gen3. Is my only solution to get the Toyota key code pad installed or is there another way to secure my truck while I’m in the water without having to stash my key fob? Thanks!
  2. Jan 15, 2024 at 7:47 AM
    wauto
    wauto New Member
    mike
    There is a valet key built into your FOB,
    Mattedfred likes this.
  3. Jan 15, 2024 at 7:49 AM
    surfmonkey
    surfmonkey New Member
    2024 Tundra Limited
    Full tank of gas
    Maybe look into the breather for the diff, but the wheel well isnt an issue, and the engine is a closed system save for the intake. If you are in water deep enough to flood the engine, your truck is the least of your problems.
    For the fob, take out the physical key and read this.
    https://www.tundras.com/threads/disabling-key-fob.117245/#post-3014815
  4. Jan 15, 2024 at 8:08 AM
    FLO
    FLO [OP] New Member
    Frank
    2024 Tundra SR5
    None
    Interesting. I’ll check it out and give it a try. Thanks!
  5. Jan 15, 2024 at 9:47 PM
    sandiegosteve
    sandiegosteve New Member
    San Diego
    24 Limited TDR Lunar Rock
    I don't think there is a great option for a key in your wetsuit. The only option I've found is to leave the FOB behind and cary the valet key. Leaving the FOB behind has obvious problems, but putting it into a faraday pouch so the Tunrda doesn't think it is there. Then, you need to hide it or lock it up well.
    I got this one, and it is a dual pouch and the inner gold part does block signal.
    https://www.amazon.com/gp/product/B07MDF5TX9/
    I wasn't aware of a keypad we could add.
    FLO[OP] likes this.
  6. Jan 16, 2024 at 6:38 AM
    DRP
    DRP Old Member
    Dave
    I use one of those waterproof cell phone pouches while I'm kite surfing. Works great. My life jacket/rash guard has a zippered compartment that I keep the pouch in.
    FLO[QUOTED][OP] likes this.
  7. Jan 16, 2024 at 8:03 AM
    Blufin
    Blufin Seasoned member
    Bob
    Cape Cod,MA.
    23 Capstone
    Get an H20 resistant magnetic box and find a safe place and easy to get at on your chases.
    Cheap money on Amazon
    FLO[OP] likes this.
  8. Jan 16, 2024 at 10:33 AM
    FLO
    FLO [OP] New Member
    Frank
    2024 Tundra SR5
    None
    Excellent info. Thanks guys!
