Tonneau cover drainage
Discussion in '3rd Gen Tundras (2022+)' started by sulli155, Jan 16, 2024.
  1. Jan 16, 2024 at 4:59 AM
    sulli155
    sulli155 [OP] New Member
    Hi team - I have a retracting tonneau cover, where water drains from the drum via two tubes into the bed’s drainage holes. I haven’t done any extra drilling, so I’ve found that even if a small rock or leaf blocks the drainage hole, I’ll sometimes end up with a pool of water in my bed. Has anyone found a good solution?
    My thought is to drill into the bed’s drainage holes and then connect the drain lines directly to that larger hole. Not thrilled about drilling, so would love to avoid that. Also, if you were to go with that setup, what about if water happens to get into the bed via another route (leak or tailgate being open)…how does that water drain then?
    Thanks and look forward to your ideas!
  2. Jan 16, 2024 at 5:58 AM
    Blufin
    Blufin Seasoned member
    Bob
    Cape Cod,MA.
    23 Capstone
    I have a retractable cover as well and with the holes I just reamed them out with a step bit,but my concern was that the cheap plastic drainage nipples kept falling out and water draining into the bed.
    I can see your concern about it getting clogged by a pebbles or debris, anything is possible,but unless your bed is carpeted or have precious cargo I wouldn't sweat the small stuff.
    I ended up modifying the plastic portion aspects and used brass a ridged SS sink water feeds.
    velcromidget, JMGmanAZ and j-utah like this.
  3. Jan 16, 2024 at 6:29 AM
    j-utah
    j-utah lost member
    Utah
    Fortress of Solitude, CO
    2024 Tundra SR5
    Dice valve stem caps (black)
    This looks really good. I have a Retrax slider on my Tacoma and agree the plastic nipples are not great. One of them is broken a bit but I think the tube still kind of works.
    OP, FWIW, my solution is the OEM rubber bed mat. My tubes are routed under the edge of the mat. Water drains under the mat to the bed and then out. The rubber surface stays dry. That’s good enough for what I need and I put off the next step that @Blufin took. Anyway, water is going to get in sometimes, so I like the bed mat as a top layer.
    MAC25Tundra likes this.
  4. Jan 16, 2024 at 6:36 AM
    sulli155
    Dang - legit upgrade! So did you just step up the hole a bit larger than the replacement tube? After a big rain the other day I ended up with almost an inch of water in the bed, just due to a tiny rock blocking the drain.
  5. Jan 16, 2024 at 6:47 AM
    Blufin
    Bob
    Cape Cod,MA.
    23 Capstone
    Yes only by a fraction,the barbed fitting I drilled twice to make 4 holes @ 7/32" one thread up from the closest to prevent water poolage
    and smelling like the town pool.
    PBNB likes this.
  6. Jan 21, 2024 at 7:20 PM
    sandiegosteve
    sandiegosteve New Member
    San Diego
    24 Limited TDR Lunar Rock
    Do you remember the size of that brass fitting? I've been doing a lot of local searching, and I can't seem to find anything similar. Did you get it at a specialty place?
  7. Jan 22, 2024 at 3:54 AM
    Blufin
    Bob
    Cape Cod,MA.
    23 Capstone
    It is 3/4X1/2 NPT you can get them any hardware store Homies or Blows AKA Home Depot & Lowes.
    sandiegosteve likes this.
