Waterproof T-taps
Discussion in '1st Gen Tundras (2000-2006)' started by albru2, Jan 15, 2024.
  1. Jan 15, 2024 at 9:10 PM
    albru2
    albru2 [OP] Keep it simple stupid
    2002 Tundra Limited 4.7l 4WD AC
    What are people using for waterproof T-taps? Or if not T-taps, what is the best way to tap into a wire?
  2. Jan 15, 2024 at 9:20 PM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    Depends on the purpose. Only one place I have a T-tap on my truck, and that's for the pop-n-lock running to the rear gate handle. Pretty much any other accessory, I'd rather trigger somewhere else that doesn't need a splice, or install a Posi-Tap for a relay trigger at worst.
    albru2[OP] likes this.
  3. Jan 15, 2024 at 10:46 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    Scotchlocks and T-Taps. I don’t like, i don’t recommenced. Best used for roadside emergencies, otherwise i wouldn’t ever use them. I’d spend the time to splice in with solder and adhesive lined heat shrink.
    albru2[OP] and TXBrit like this.
  4. Jan 16, 2024 at 4:10 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L AC Limited 55k mi
    Posi-Taps are help in pretty high regard on the First Gen Forum. Their only drawback is they’re expensive as hell and there doesn’t seem to be a Chinesium version of them.
  5. Jan 16, 2024 at 6:35 AM
    I dispute the "expensive as hell", it's an investment, Posi-taps are infinitely reusable. Scotchlocks, T-Taps, Quick connects, etc. are not infinitely reusable. It would take a lot of re-use to equate the cost savings, but ... you're also not going to nead to deal with future electrical gremlins and repairs corroding your wire, cut strands of copper in your wiring caused by destroying your wire casings, oxygen+water intrusion on your copper, etc.
    Posi-taps are water-resistant but not waterproof in the classic sense of the word. They pierce the sheath vs. cutting it, so they'll retain whatever seal the wire casing provides. I suppose you could apply dielectric grease to the puncture area and get as near to waterproof as anything else. If you ever remove the Posi-tap, a simple dab of liquid electrical tape will re-seal the wire.
    Posi-taps are also made in USA. So you're supporting American manufacturing when buying their products. We all want to support American manufacturing, right?!
    But yeah. T-taps, scotchloks and their like are garbage, hackish, and shouldn't be used, especially externally.
  6. Jan 16, 2024 at 7:12 AM
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 DC SR5 Tundra TRD Off Road
    Not really such a thing. You can find splices designed for direct burial or wet locations but you would have to cut the existing wire. Essentially splice 3 cut unstripped wire ends together. They are 3M waterproof scotchlocks and we use them for connecting devices in underground fuel storage tanks.
    You're not going to find a weather tight connector of the T variety.
    Other best bet is to use and uninsulated butt splice connector and heat shrink over the splice. But you would still have to cut the original wire you're trying to T into. You will want to use the heat shrink lined with adhesive to make sure no moisture works it's way into the splice.
  7. Jan 16, 2024 at 8:53 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    Solder and heat shrink. I never trust anything else except butt-connectors and that’s just when I’m being lazy.
    Do58 likes this.
  8. Jan 16, 2024 at 1:36 PM
    Time and a place for everything. I use a butt splice if the line is cut and the application isn’t suited or reasonable to solder and shrink. If the line isn’t cut and I don’t want to cut a factory harness, it presents a unique dilemma. posi-taps nicely solve that dilemma in a non-invasive way.
    chunk likes this.
  9. Jan 16, 2024 at 3:53 PM
    :anonymous:
    JasonC. likes this.
  10. Jan 16, 2024 at 5:25 PM
    bfunke
    bfunke Tundra Curmudgeon
    Another option is to build a custom harness adaptor from OEM connectors. A couple members here have done that for others for a modest fee.
  11. Jan 16, 2024 at 6:05 PM
    albru2
    I actually really enjoy soldering and heat shrinking for splicing but haven't tried that in a T type of connection. Do just expose a length of bare wire and solder your new wire along side it? more like a Y than a T? Or I guess you could cut the existing wire and strip both ends and solder the new one between them
    OldGuy03 and FishNinja like this.
  12. Jan 16, 2024 at 6:36 PM
    albru2
    I've never used a posi-tap, thanks I'll give them a try
  13. Jan 16, 2024 at 7:29 PM
    FishNinja
    Lee
    06DC2wd
    you can do whatever your heart desires. I personally will cut and strip all the wires and do the Y connection so I can kinda work things in the directions I want
    OldGuy03 likes this.
  14. Jan 16, 2024 at 8:25 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    I've also never used t-taps, posi-taps or anything similar. I've been a fan of soldering and heat shrink methods since I started tinkering on dirt bikes in my teens. However, @shifty` brings up a good point about the reusaability of posi-taps. I might look into these for any future project needs.
  15. Jan 16, 2024 at 10:24 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Another vote for Posi products. Good shit.
  16. Jan 17, 2024 at 4:36 PM
    albru2
    I had an 83 Toyota Sunrader that was absolutely riddled with those quick tap things (100's of them) and yes they are bad. Many an evening was spent on the side of the freeway searching for the bad connection. I would just work my way from tap to tap until I found the culprit.
