HELP! - 2 different OEM radiators...difference?
Discussion in '1st Gen Tundras (2000-2006)' started by tburick, Dec 1, 2019.
  1. Dec 1, 2019 at 2:48 PM
    tburick
    tburick [OP] New Member
    Tom
    2003 Tundra 4.7L 2WD
    none
    Getting ready for a major service on my 2003 Tundra 4.7L 2WD and I want to replace the radiator as part of the service. Toyota lists 2 different radiators that will work.
    16410-AZ018 - Description mentions something about service and warranty repair and also uses a descriptive of MVP. Radiator is CHEAP $150.00
    PRODUCT DETAILS
    • Description: 4.7L, mvp, without double cab.
    • Notes:Warranty And Service Radiators Included With A Special Toyota Program.
    16400-0F020 - this is the second compatible radiator...but it costs a whopping $330.
    I've done a ton of online research and both will fit. I can't find any info on what the difference is.
    Any ideas?
    Thanks!
  2. Dec 1, 2019 at 3:04 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Don't know physical composition differences but MVP is simply not OEM.
    https://www.toyotapartsandservice.com/products/collision/radiator-condenser-collision
  3. Dec 1, 2019 at 3:21 PM
    tburick
    Tom
    none
    That answers it. Looks like the MVP part is an oem-designed substitution.
    Ok - so that said... I can't afford to spend almost $350 on a radiator. Since the cheaper radiator is "designed, tested, and approved" by Toyota...that looks like the winner.
    Maybe for further clarity...looks like the MVP parts are designed by Toyota...but farmed out for the manufacturing.
  4. Dec 1, 2019 at 3:25 PM
    Aerindel
    Aerindel New Member
    Montana
    It's what I bought when mine went out last winter.
    Its been fine. I will warn you though, at least with mine, it was packed very badly and beat to hell in when I got it. I used it anyway because it was the middle of winter and I needed the truck fixed, but if you have time, inspect yours and return it if beat up and demand it be better packed.
    The built quality I feel is fine...but the way they ship them is terrible. I've bought a lot of radiators from Amazon over the years and most are very well, and elaborately packed, but this one was just thrown loose in a box by Denso with no packing and was bent in several places by the time I got it. I would have no reservations about it if it had simply been packed better.
  5. Dec 1, 2019 at 3:26 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    If it were I, I would put nothing in that 2003 but OEM or the MVP even if I had to wait till I could afford it.
  6. Dec 1, 2019 at 3:35 PM
    tburick
    Tom
    none
    I edited my reply and it actually posted both the pre-edit and post-edit response...so it looks confusing.
    I'm sure the Amazon Denso would work just fine...but I decided to buy the Toyota designed MVP radiator. It's only $50 more and there's peace of mind knowing that Toyota actually designed the part.
  7. Dec 1, 2019 at 3:49 PM
    Professional Hand Model
    Fred
    Hand Protectors
    A shop put a Cryo-Max radiator in mine about 4 years ago. Working fine. Roll with your MVP and report back.
    KarmaKannon likes this.
  8. Dec 1, 2019 at 3:51 PM
    Fred
    Hand Protectors
    Make sure you buy a new Denso cap. $14 on internets this past summer when I bought a new one for grins. They should be replaced 3-5 years. Cheaper than pressure testing.
  9. Dec 1, 2019 at 4:09 PM
    tburick
    Tom
    none
    Yep. New cap ordered as well!
  10. Dec 1, 2019 at 7:08 PM
    Aerindel
    Aerindel New Member
    Montana
    Caps are actually one of the very few things I go OEM on.
  11. Jan 15, 2024 at 3:57 PM
    WaterOp
    WaterOp New Member
    So Lake Tahoe, CA
    2005 Tundra Access V-8 Auto 4x4
    Hi All,
    I'm in the same situation.
    I have a 2005, Access Cab, 4x4, automatic, SR5/TRD, with tow pkg, VIN 5TBBT44135S463029.
    Websites seem to list three different choices... 16400-0F050, 16410-AZ012 AND 16410-AZ018.
    Anyone know which one is correct?
  12. Jan 15, 2024 at 4:07 PM
    shifty` Animals and insects don't do drugs
    Go to www.densoautoparts.com
    Plug in your truck details and look up radiators/cooling parts in their system.
    There should be two options for radiators: "Without double cab" and/or "with double cab". Choose whichever applies to you.
    Order through Rock Auto - www.rockauto.com - find a 5% off coupon at www.retailmenot.com
    Their price will not only usually be cheaper than scAmazon, but you'll get the part, undamaged, which is usually not the case w/scAmazon. And the part will be authentic, which is also not always the case with scAmazon.
    Denso *IS* Toyota's OEM supplier for that part.
    The Black Mamba likes this.
  13. Jan 15, 2024 at 4:11 PM
    And in case it's tough, here you go.
    Take that "221-..." part number and plug it, hyphen and all, into RockAuto's website. You'll find the part number you need.
    Schcoman and The Black Mamba like this.
  14. Jan 15, 2024 at 4:23 PM
    WaterOp
    WaterOp New Member
    So Lake Tahoe, CA
    Thanks Shifty,
    Looks like Summit Racing is a tad cheaper, so probably go with them.
    I appreciate the help
    shifty` likes this.
  15. Jan 15, 2024 at 4:41 PM
    Summit is my preferred also. But they're also a short trip south to pick up my part in person, so I'm biased. :D
