I'm an asshole
Discussion in '1st Gen Tundras (2000-2006)' started by FrankieGene30, Jan 14, 2024.
  1. Jan 14, 2024 at 9:02 PM
    FrankieGene30
    FrankieGene30 [OP] New Member
    Fra m
    Base model 01 Tundra
    None
    I cut my factory stereo wiring plug right off the harness. I'm thinking Flux solder and liquid electrical tape
  2. Jan 14, 2024 at 9:11 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Butt connectors!
  3. Jan 14, 2024 at 9:18 PM
    j-utah
    j-utah performance warrantied member
    Utah
    Fortress of Solitude, CO
    2024 Tundra SR5
    Dice valve stem caps (black)
    Straight to the point. I like it. Welcome!
  4. Jan 14, 2024 at 9:23 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    :rimshot:
    Sundog, N84434, ColoradoTJ and 3 others like this.
  5. Jan 14, 2024 at 9:30 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Hardwire the radio, then spray paint all the wires the same color.
  6. Jan 14, 2024 at 9:36 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Re-pin the connectors prior to spray painting the wires the same color.
  7. Jan 14, 2024 at 9:43 PM
    evanhmn
    evanhmn mmm chicken pot pie
    State of Taxes
    2001 TRD Off-Road AC 4x4 Limited in Black
    5100/2885s, 1.5" Add-Leaf, BFF Front Bumper, 265/70/17 KO2s
    Hey, mine are probably cut too but I wasn't the one who replaced it so I try not to feel as bad about it...
    Black Wolf likes this.
  8. Jan 14, 2024 at 9:52 PM
    Haulmode
    Haulmode New Member
    2021 CM SR5 Cement
    Bilstein 5100, Falken Wildpeak 285/75r18, Demello Rock Crushers, Tech12Volts Sound
  9. Jan 14, 2024 at 9:59 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
  10. Jan 14, 2024 at 10:50 PM
    blenton
    blenton New Member
    ColoradoTJ likes this.
  11. Jan 14, 2024 at 11:06 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  12. Jan 14, 2024 at 11:52 PM
    artsr2002
    'Yonder
    LMAO. Classic Carrey.
  13. Jan 15, 2024 at 2:03 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Welcome to Assholes Anonymous. We get a lot of new members in January, but very few stay...
  14. Jan 15, 2024 at 3:11 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Welcome to the family!
  15. Jan 15, 2024 at 4:41 AM
    I won't argue. Welcome.
  16. Jan 15, 2024 at 5:19 AM
    Richid
    Richid New Member
    I solder and heat shrink connections, then friction wrap the section.
    At the age of these trucks, I'm sure many have lost the factory connectors. I never plan to reinstall my factory radio, but I used the adapter harness to make the install easier.
  17. Jan 15, 2024 at 7:56 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    I've had my OEM HU, amp, and speakers in my attic for 8 years.
    I thought I would probably put it back in the truck if I ever sold or traded it.
    But as years go by, I'd probably just leave it in there..:thumbsup:
    gosolo likes this.
  18. Jan 15, 2024 at 11:13 AM
    chunk
    chunk New Member
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    I would use crimp connectors of the correct size for the wire gauge, reason being is when you solder it wicks up the wire and when solidified it will create a stress point that can break with vibration at that spot.
    gosolo and landphil like this.
  19. Jan 17, 2024 at 10:32 AM
    Richid
    Richid New Member
    If you heat the wire that much, the insulation will melt and you'll have bigger issues. I've never had to fix a solder connection, but have seen crimp connector break or damage the wire.
    Some people do not mechanically connect the wires correctly and rely on solder, which does create a stress point. Solder is an electrical connection in wiring not meant to physically join them.
    Ok with any of it as long as they fix their own wiring.
    gosolo and NewImprovedRon like this.
  20. Jan 18, 2024 at 9:48 AM
    jimf909
    jimf909 Battery almost dead...
    Washington or Idaho
    '03 Tundra SR5 AC 4.7 TRD w/LSD
    Dead stock with oem 16" starfish wheels. We'll see how long that lasts. :) Topper of unknown origin.
    Who isn't?
    gosolo and ZappBrannigan like this.
  21. Jan 18, 2024 at 10:38 AM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    Not me.
    I'm extremely cordial, amicable and generally charming.
    jimf909[QUOTED] and gosolo like this.
  22. Jan 18, 2024 at 10:55 AM
    Kung
    KG, VA
    Do you drive real slow in the ultra-fast lane?
    While people around you are going insane?
    (10 points to the guy who gets this reference.)
    AZBoatHauler and gosolo like this.
  23. Jan 18, 2024 at 11:28 AM
    blenton
    blenton New Member
    Wait a second… Mods - I think this account has been hacked. Please look in to it.
    gosolo and RichterScale[QUOTED] like this.
  24. Jan 18, 2024 at 12:39 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    In children’s book voice: “Said the A-hole.” :D
  25. Jan 18, 2024 at 12:42 PM
    AZBoatHauler
    So.Arizona
    You’re a baseball glove - get on the truck. :rofl:
    Haulmode[QUOTED] and gosolo like this.
  26. Jan 18, 2024 at 3:35 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    But those that do stay, gain weight and lose money!
    blenton likes this.
  27. Jan 18, 2024 at 6:26 PM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    While handicap people, make handicap faces?
