Throttle cable
Discussion in '1st Gen Tundras (2000-2006)' started by dutch143a, Jan 13, 2024.
  1. Jan 13, 2024 at 3:36 PM
    dutch143a
    dutch143a [OP] New Member
    Jerry
    2000 toyota tundra white
    starter replaced, ,timing belt also water pump replaced
    I had to change my Starter on my 2000 Toyota tundra 4.7L can't tell you the trouble this is my second time to do this. But my problem can anyone tell me how to put the Trottle cable back on the wheel, I can't make out how it's supposed to go. My next problem in the process of replacing the starter I removed about a look's like 5/8 inch bolt that has a hole in the shaft. I can't figure out where in the world I got it from Thanks for all the help.
  2. Jan 13, 2024 at 3:40 PM
    Yeah, starter is one of those parts where you only want to use OEM, or else you *WILL* be doing this again in the next 18-48 months. It's also one of those parts where you want to replace the intake gasket, and the only quality ones that last are FelPro or OEM. Too many people coming to this forum have learned both of these lessons the hard way, I hope this info can save you similar pain and issues!
    Starter is also one of those things people replace when the truck doesn't start, but the starter isn't actually the problem.
    You got a picture of what you're dealing with? Pic is worth a thousand words. It's really easy to upload pics here using the "Upload a File" button at the bottom-right side of the box where you type replies.
  3. Jan 13, 2024 at 5:26 PM
    dutch143a
    Jerry
  4. Jan 13, 2024 at 5:49 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    ^^^I'm no math genius, but round peg goes into round hole
  5. Jan 13, 2024 at 5:57 PM
    dutch143a
    Jerry
    Well it seems like you know what your talking about but I think you are WRONG!
  6. Jan 13, 2024 at 6:24 PM
    It should work similar to handlebar/bmx style brakes on a bike.
    Rotate the TB plate as shown with the red arrow (1)
    Rotate the lead barrel so it locks into the hole (2)
    You may need to insert the barrel in from OUTSIDE that channel, like have the whole cable alongside the "INSP" writing, insert it into the round slot (side load it) then push cha cable up over the side spine to get it into the slot.
    Schcoman and The Black Mamba like this.
  7. Jan 13, 2024 at 6:52 PM
    bfunke
    bfunke Tundra Curmudgeon
    Remove the bolt holding the throttle cable bracket and then you can insert the barrel into the whole and wind the cable into the groove. Let me know if you need a picture
  8. Jan 13, 2024 at 7:43 PM
    whodatschrome
    lots of dents
    Weird...i removed and reinstalled the throttle cable last summer on my 4.7 powered 2000 tundra and it had both a round shaped barrel end on the cable and a round shaped hole on the throttle pulley. It was all straightforward easy-peasy. Is the pic you posted up your actual truck or a random pic from the internet? If it’s not a pic of your truck, perhaps a previous owner modified (or bodged) your throttle cable and pulley?
  9. Jan 14, 2024 at 2:43 AM
    dutch143a
    Jerry
    upload_2024-1-14_4-39-22.jpgupload_2024-1-14_4-39-22.jpg This is the bolt I was asking about
  10. Jan 14, 2024 at 4:21 AM
    The Black Mamba
    Snek
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Now I have “Schism” is my head :rockband:
  11. Jan 14, 2024 at 4:23 AM
    The Black Mamba
    Snek
    DFW
    Imma keep it stock
    Where did that one come from? That’s not part of the throttle wheel that I know of. Related to the pic you put up, shifty has given the correct process for reattaching the cable.
    shifty` likes this.
  12. Jan 14, 2024 at 6:20 AM
    Thanks for confirming. I was not 100% positive, but have had at least two other vehicles with similar in the past, so I’m assuming Toyota works about the same.
  13. Jan 14, 2024 at 6:33 AM
    dutch143a
    Jerry
    This bolt does not come from the throttle body. I removed it from somewhere and forgot where it goes. I am not as young as I once was so I tend to forget things. Just asking if anybody can help me find where it goes. The throttle cable is back on thanks for the help.
    The Black Mamba likes this.
  14. Jan 14, 2024 at 6:52 AM
    bfunke
    Looks like the banjo bolt on the pipe connecting the two fuel rails at the front of the engine
    whodatschrome and shifty` like this.
  15. Jan 14, 2024 at 6:55 AM
    bfunke
    90401-12023
    shifty` likes this.
  16. Jan 14, 2024 at 4:18 PM
    dutch143a
    Jerry
    Well I do have the cable for the trottle cable on, thanks for the help But I do still need to know if anyone knows where it might go I looked for that banjo bolt that bfunke told me about but that isn't it.HELP please.
  17. Jan 14, 2024 at 6:51 PM
    I mean, I see the banjo @bfunke pointed out (big circle). Is there not another one on the other side (small circle?)
    There's only so many places banjo bolts go on an engine :D
  18. Jan 15, 2024 at 5:28 AM
    bfunke
    Yup - one on each side.
  19. Jan 15, 2024 at 5:56 AM
    whodatschrome
    lots of dents
    i’d double check to make sure that there isn’t a normal hex bolt installed somewhere that there should be a banjo bolt?
    shifty` likes this.
  20. Jan 15, 2024 at 12:33 PM
    dutch143a
    Jerry
    Well guys I found out where the bolt goes, it is where the vacuum line connects to the rear of the engine coming from the brake booster.I had to go to the Toyota Dealership and they helped me find it. Thanks for all the help though.
  21. Jan 16, 2024 at 7:43 AM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    Alright, this might be the funniest thing I've seen on this internet. Definitely LOL'd
