2023 Tundra Backseat for dogs
Discussion in '3rd Gen Tundras (2022+)' started by Mcvic21, May 23, 2023.
  1. Nov 7, 2023 at 3:06 PM
    #61
    Pr4sno
    Pr4sno New Member
    Loveland, CO
    TundraTT[QUOTED] likes this.
  2. Jan 7, 2024 at 1:28 PM
    #62
    andrewftw
    andrewftw New Member
    Bay Area, California
    2022 Tundra Platinum
    This helped me SO much. Thank you for sharing the measurements you took.
  3. Jan 14, 2024 at 6:03 PM
    #63
    K9Candyman
    K9Candyman New Member
    2024 Lunar Rock Platinum 4x4
    Thank you to TTCM for the dimensions! It truly helped. Used the same numbers and feel the dog platform came out great! I added an anti-fatigue mat layer below the marine black all weather carpet. Best part, the doggo approves.
    C6Bill, raylo, Boomer08 and 4 others like this.
  4. Jan 21, 2024 at 7:30 AM
    #64
    Jalzate44
    Jalzate44 New Member
    San Antonio TX
    2024 Tundra SR5 Crewmax 4x4
    Do you have any pics of the bottom support?
  5. Jan 21, 2024 at 8:09 AM
    #65
    K9Candyman
    Here you go!
    ReCKzX, RatPanda and Mattedfred like this.
  6. Jan 21, 2024 at 9:35 AM
    #66
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    I have about 400k miles combined in a Gen 1 Tundra, Gen 2.5 Tundra and a Titan with 1-3 Labs using this tarp set up in my back seat. No issues with the headrest posts. I had a 75# Lab that loved "the sling" and my 65# current youngest likes to sit in "the sling" portion, not on the seat.
  7. Jan 21, 2024 at 9:40 AM
    #67
    Oldandfat
    Oldandfat New Member
    Cannuckastan
    what size tarp,are you using, and what’s under the tarp at the front seat ?
  8. Jan 21, 2024 at 9:42 AM
    #68
    Same with 2 Aussies in mine. About 110# worth of pups.
  9. Jan 22, 2024 at 8:12 AM
    #69
    Over the LINE
    New Orleans
    I'm pretty sure it is 5 x 7. There is a piece of PVC conduit that runs side to side at the front seats. I found that spreading the load works better and also in a panic stop the bar keeps the pups in the back seat. I use grommets to secure the "loop" the PVC runs through and then cut small holes for the headrest lines to run through. I add grommets where the back seat attachments are and use wire ties. I add grommets on the bottom back corner and tie this part down to keep the tarp from sliding around. I use this type of tarp. The coated tarps can make a mess of your truck as the coating rubs off. I'm pretty sure the tarp I have now has 155K on it since 2016.
    Polyester Tarp - Iron Horse - Waterproof Tarp (chicagocanvas.com)
  10. Jan 22, 2024 at 6:22 PM
    #70
    Oldandfat
    Cannuckastan
    so the “loop” is permanent due to being “geometries” together?
    is that paracord on the front head rests?
    what made you decide on this method as opposed to the dog hammocks on Amazon?
  11. Jan 23, 2024 at 11:44 AM
    #71
    Over the LINE
    New Orleans
    The loop of fabric is permanent, using grommets. I used grommets because I don't have a machine that will sew through the tarp.
    I used cord and brass hooks on the headrest to make removal easier.
    I made my first one of these back in 2004 or so. At the time there were few options available commercially so I decided to make what I wanted. I actually had it sewn by a sail/canvas guy out of Sunbrella fabric. The fabric did not hold up. I went to tarps after that and at some point started using grommets instead of having them sewn. I have a Mud River sling for my wife's 4 Runner. It's OK but I think my version with the PVC conduit is more secure and the dogs are better contained.
    I think I got pics from every angle.
  12. Jan 26, 2024 at 8:32 PM
    #72
    Jalzate44
    San Antonio TX
    Thank you @TTCM for the dimensions.
    raylo, CV60, myfirsttundra1 and 3 others like this.
  13. Feb 1, 2024 at 11:02 AM
    #73
    CV60
    CV60 New Member
    ’24 Tundra 1794 Lunar Rock
    @TTCM
    I’ll buy you coffee tea ice cream for sharing your dimensions.
    :thumbsup:
    K9Candyman likes this.
  14. Feb 6, 2024 at 4:45 AM
    #74
    Blissfull
    Blissfull New Member
    Here is my version. Two parts to allow use of seat and deck. Folding feet. Center support using cargo dividers. Rubber floor tiles on surface. upload_2024-2-6_7-45-10.jpgupload_2024-2-6_7-45-19.jpgupload_2024-2-6_7-45-26.jpgupload_2024-2-6_7-45-35.jpg
    K9Candyman and Mattedfred like this.
  15. Feb 29, 2024 at 8:38 AM
    #75
    TowTundra
    TowTundra New Member
    23 Tundra Limited
    Can anyone share the height of the support legs for the outboard and center tunnel? Thank you for posting dimensions of the board itself, super useful!
    CV60 likes this.
  16. Mar 13, 2024 at 5:25 AM
    #76
    2494
    2494 New Member
    2024 Tundra 1794
    So…hopefully I’m on the correct thread. Has anyone tried the Ruffland Back Seat Rider kennel?
  17. Mar 14, 2024 at 6:33 AM
    #77
    gmcguire7220
    gmcguire7220 New Member
    Ontario Canada
    2022 Limited TRD OR Crewmax - WCP- 2019 Toyota RAV4 Hybrid XSE
    TRD running boards & Bridgestone Dueller Ascent tires
    I thought Ryan answered this in another thread about storage maybe. I believe his answer was that the cover doesn’t have strength to it, it’s just a cover & is supported by the battery & related structure, not self supporting. I think?
    Mattedfred[QUOTED] likes this.
  18. Mar 14, 2024 at 3:59 PM
    #78
    gmcguire7220
    Ontario Canada
    All good, it gets challenging sometimes to remember where you found something before!
  19. Mar 16, 2024 at 1:39 AM
    #79
    EffinNewGuy
    EffinNewGuy New Member
    Scuba Steve
    2005 Sequoia Limited 4WD
    Do you have any issue with keeping your Shepherds hair out of the vents for the hybrid battery?
    Tundrastruck91 likes this.
  20. Mar 16, 2024 at 11:10 AM
    #80
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Good question, should probably plan to clean filter once a month or so.
  21. Jun 29, 2024 at 4:35 PM
    #81
    Woodrow bangs
    Woodrow bangs New Member
    Baltimore
    2023 MBM Platinum
    Thank you very much for sharing the measurements TTCM. Perfect fit. If this helps anyone my legs are 7 1/2” tall, and there is a support in middle bump that is 3” tall or (2) 2x4’s. Used 3/4 plywood and it’s super sturdy all around. About $50 bucks (had spare carpet) and an afternoon taking my time.
    just need a slobberguard now
    303Gen3 likes this.
  22. Jun 30, 2024 at 7:13 AM
    #82
    CV60
    CV60 New Member
    Looks good - I’d pay for someone to build me one :)
    It’s on the list, maybe I can over the next weekend.
  23. Jun 30, 2024 at 8:00 AM
    #83
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp & sub, DIY rear seat delete, cat shield
    Rear seat delete on my DC makes this the perfect spot for the dog. Just add a blanket, some towels or his dog bed and we are ready to go.
    C6Bill, NateMob and CV60 like this.
  24. Jun 30, 2024 at 8:02 AM
    #84
    CV60
    CV60 New Member
    Heck I was recently in Annapolis …looks good
    raylo likes this.
  25. Jun 30, 2024 at 8:04 AM
    #85
    raylo
    Frederick, MD
    Do/did you have someone at USNA?
  26. Jun 30, 2024 at 8:09 AM
    #86
    CV60
    CV60 New Member
    No, I have close Navy friend that works there. Heading back up shortly.
    raylo likes this.
  27. Jun 30, 2024 at 8:22 AM
    #87
    brhodea
    brhodea New Member
    Michigan
    '24 CM Limited
    These all look great!! Wish I'd have seen this thread 2 weeks ago. Taking a 14 hour drive after work tonight with the wife and dogs.
  28. Jul 18, 2024 at 3:38 PM
    #88
    303Gen3
    303Gen3 Old enough to know better. Young enough to try
    Golden Colorado
    '23 MGM SR5 CrewMax 4x4
    Nitrogen filled tires!
    Thanks to all the posters on this thread. Made a platform for my pup a few weeks ago and it works great. It may never come out because it makes the rear seating area so much more usable when you don't have passengers.
    astrength22 and Woodrow bangs like this.
  29. Jul 18, 2024 at 4:34 PM
    #89
    Wood-Dro
    Wood-Dro New Member
    Any of you belting your dogs in?
  30. Jul 18, 2024 at 5:09 PM
    #90
    303Gen3
    Golden Colorado
    Mine (a 12lb JRT) rides in his kennel and the kennel is connected at the rear corners to the child seat metal connects. Tight and secure.
