New Front Brakes and Rotors
Discussion in '1st Gen Tundras (2000-2006)' started by Lupe, Jan 5, 2024.
  1. Jan 5, 2024 at 11:15 AM
    Lupe
    Lupe [OP] New Member
    Lupe
    2006 Tundra
    So i need new front brakes.i brought a set from Napa and well 1st set warped and i made a claim and they sent me a different set yet same thing happened. What is everyone running? I read that some are using cryo and hawk pads or akebono and i came across frozen rotors and EBC. I just want a good set that going to help my truck stop.
  2. Jan 5, 2024 at 11:16 AM
    I had to replace the ones on my wife's previous Highlander about 2 years ago, and I went with OEM. Straight as an arrow. Folks on here have had similar issues with aftermarket being warped out of the box.
    Lupe[QUOTED][OP] likes this.
  3. Jan 5, 2024 at 11:21 AM
    Psv
    Psv New Member
    Chicago
    2019 Tundra Sr5
    I'm still rolling on oem brakes but plenty of people i know have Power Stop brakes and are pretty satisfied with that brand
    Lupe[OP] likes this.
  4. Jan 5, 2024 at 11:35 AM
    Lupe
    Lupe
    2006 Tundra
    So your saying go OEM
  5. Jan 5, 2024 at 11:37 AM
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
    I've had good luck with PowerStop. They have kits on RockAuto.
  6. Jan 5, 2024 at 11:58 AM
    PowerStop makes solid stuff. So does Wilwood. But bang vs. buck vs. longevity, if I don't need anything special, I'm just buying OEM and calling it a day.
  7. Jan 5, 2024 at 12:40 PM
    Lupe
    Lupe
    2006 Tundra
    Yea i saw powerstop have good reviews. I just want to honestly brakes without the pulsation
    WILLINH likes this.
  8. Jan 5, 2024 at 1:10 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    The pulsation comes from the rotors being warped. As long as you replace then (if too far out of spec to be resurfaced. I think the max is 0.4mm) you'll be fine.
  9. Jan 5, 2024 at 1:12 PM
    Skip trying to resurface or turn your old rotors. Just makes them more susceptible to warping.
    Lupe[OP], bfunke, WILLINH and 2 others like this.
  10. Jan 5, 2024 at 2:04 PM
    Lupe
    Lupe
    2006 Tundra
    Yea these are done lol. I rather find a new brand. I dnt like to cheap out on brakes and tires. I just dont want spend the money and get the same result.
    KNABORES likes this.
  11. Jan 5, 2024 at 2:10 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    It's been posted on here about the LSVP and how adjusting it to be more rear bias will assist in front longevity and help prevent warping. I saw a pic PHM posted about how his was set all of the way down from the factory. I would look at that at the same time.
    Better Braking Brakes! Easy!!! | Toyota Tundra Forum (tundras.com)
  12. Jan 5, 2024 at 2:47 PM
    abcinv and G_unit3000 like this.
  13. Jan 5, 2024 at 3:14 PM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    I suppose the question would be, were both sets warped right out of the box? I have a hard time believing that NAPA couldn't source true rotors. Once maybe, but twice? How long before you noticed the pulsating? It doesn't take too long for a rotor to warp if a caliper is dragging hard. Lot's of questions...
  14. Jan 5, 2024 at 3:19 PM
    Be sure not to over-torque your lugs as well. That can cause the same feeling when braking.
  15. Jan 5, 2024 at 3:22 PM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    How long before they warped? Right out of the box? 30 miles? The reason I ask is because a dragging caliper/pads can warp a rotor pretty quickly. I went through two sets of rotors on my 2011 4Runner before I realized the caliper was the culprit. Changed it out, all was good. Only lasted a year before the piston seals started leaking, so I advise OEM calipers if that is indeed the problem. But, I digress... I just have a hard time believing 2 sets of NAPA rotors weren't good. Not calling you a liar, but I have questions...
  16. Jan 5, 2024 at 3:25 PM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    I learned this lesson as well. Now I use a torque wrench. 90 ft. lbs. It's amazing how modern wheels (aluminum) can distort.
  17. Jan 5, 2024 at 4:03 PM
    Lupe
    Lupe
    2006 Tundra
    I have a cousin that works for napa and i told him was give me the best set of brakes pad and rotors you have. My 1st set last about 5k-10k miles before they warped. After i spoke to him about the situation they gave me a 2nd set under warranty. I have mayb 15k on that set. But i had my rears done recently and said my pad life was about 40% but rotors where done. So i got about 1-2 years 30 max out of both sets
  18. Jan 5, 2024 at 4:10 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Powerstop.
    But if you watch the 3rd world manufacturing process, it's a wonder that any of them are good.
  19. Jan 5, 2024 at 4:56 PM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    This is exactly why I would start to question a bad caliper, or driving habits. Do you left foot brake? Do you ride the brakes? The fact that you recently had the rears done (I don't know what "recently" actually is), and you say they are now at 40% leads me to think something else is going on. I.E. driving habits. Not trying to insult you, but a lot of things don't really add up.
  20. Jan 5, 2024 at 5:03 PM
    I mean, ultimately this touches on part of our problem in the USA.
    While some name brands undboubtedly manufacture parts over there, "ultra-budget" but to specs they defined, before freighting here as intended, that's not the only thing making it over here.
    Almost every major manuf'er has different grades of parts, intended for different markets where low price point is more important than high quality. IOW, lesser quality parts at a lesser price, you may find something branded "Bosch" over there but it's priced 75% less what we pay, because the quality is lesser to cater to said market. There's also full-blown counterfeiting that happens, especially from factorys in mainland China, but that's another story.
    Unfortunately, with cheaper manufactured parts in mills like those in the video, it's unfortunately profitable to ship them over here for sale at our market's higher MSRP (i.e. "grey market"). Because certain vendors over here (*cough* scAmazon *cough*) don't give a flying shit about verifying the supply chain of people selling, OR they allow anyone to fulfill the order shipping from anywhere (*cough* scAmazon *cough* fleaBay *cough* WallyWorld *cough* Sears *cough*), American consumers get screwed. Shit parts at average pricing.
    When you're buying parts from the LAPS, brands like TRQ, CarQuest, Advics (only some examples), if it's cheaper, there's a solid chance you're getting the former, i.e. budget parts made at a factory like what's shown in the video, less-than-OEM quality, but sometimes a fraction of OEM pricing.
    When you're buying parts from online vendors who cannot, do not, or will not validate their supply chain to ensure no grey market or counterfeit parts are entering their supply chain, you may be getting the former, a budget part, but paying slightly less than MSRP for a part that's half the quality. You may also be getting full-blown counterfeits, some of which may use pieces which are created at factories like what you see in the video.
    I know OEM parts from Toyota and/or their dealerships are expensive. But at least when you're buying those, you're (A) almost certain to get legitimate parts on-par with the original quality shipped from the factory, (B) getting a part that's going to last as long as the original part did, which pays dividends in the long run, and (C) don't need to worry about fitment problems, quality control issues, or other problems that go with purchasing non-OEM.
    Furthermore, people's willingness to buy things because they're cheaper, knowing good and well they're lower quality, is a huge part of what's has and continues to kill American industry.
    Schcoman and ATBAV8 like this.
  21. Jan 6, 2024 at 7:46 AM
    Lupe
    Lupe
    2006 Tundra
    I dnt have a heavy foot. My method is i rather get there then get there in pieces. And that that i have my daughter half the time with me i def do not speed or do anything crazy. And let re-explain. I had my rears done recently maybe 3 months ago and at the time my front pads were at 40% but i had the pulsating already but i wanted to get at least some out of them. So i am at the point were i have to replace them and looking to do a better purchase
  22. Jan 6, 2024 at 8:21 AM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    Ok. I think we're talking in circles here. Bottom line is you need to replace everything. Use Toyota OEM. If the problem happens again, maybe we'll re-visit.
  23. Jan 6, 2024 at 6:13 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    My Bro in law put full PowerStop front and rear rotors and pads on his 06’ Sequoia and he’s really happy with them.
    I’ve had the same pads on my 06’ Tundra for over 140k, and I’m debating trying PowerStop. I may just got OEM though with new calipers.
    I put all OEM on the GF’s 07’ Sequoia, and it’s smooth as butter right out of the box.
    WILLINH, Elevatorguy and Lupe[OP] like this.
  24. Jan 7, 2024 at 5:00 PM
    Lupe
    Lupe
    2006 Tundra
    The set that you ran for 140k was this OEM?
    Going to shop around for OEM with all the positive feedback about them.
  25. Jan 7, 2024 at 5:01 PM
    Lupe
    Lupe
    2006 Tundra
    I will take a look at my calipers as well
  26. Jan 7, 2024 at 7:44 PM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    There's not much shopping around. You have to get them from a Toyota dealership or Toyota parts online. Calipers are running $250-$300 each, and rotors are running $80-$110 each. Disc brake pads are $80-$105 for a set(both sides).
  27. Jan 7, 2024 at 7:46 PM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    If you're not driving around with your left foot on the brake pedal all of the time(riding the brakes), then you definitely need to look at the calipers as a problem for warping the rotors.
  28. Jan 7, 2024 at 7:57 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    Well they were on the truck when I bought it, and they still have a bit left. I would assume not OEM, cause they suck :rofl:
  29. Jan 14, 2024 at 2:28 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    After getting like 150K from original rotors and several pad changes, got an aftermarket set from a nationally recognized auto parts store that pulsed in about a year. Replaced them under warranty and then decided to index them on the hubs before running them. They were at edge of or past spec (.0028" or .07mm). Parts store swapped em again, and actually tried two more sets ... with similar results in some cases measuring like .002"-.0035". So gave up on those and picked up the Toyota rotors and pads. One rotor had undetectable runout and another measured <=.001" on the hubs so ran em.
    If you're having trouble, suggest checking runout first on your hub. If the hub is true, then can bolt the rotors on the hub (can leave calipers off) and check rotor runout. Then can index them by marking one stud and the rotor hat at the same starting position and measuring, then rotate one lug and check again, repeating for each lug until you find the sweet spot. Of course if its true on the first lug your done.
    Mathematically can record any hub runout, then if have disc runout on first try that matches the position on the hub where the runout occurred, swap the disc 180 degrees to see if that fixes or exaggerates the disc runout - confirming if runout is from disc or just propagated from hub (or both). Sometimes hub and disc are both slightly off and can be mounted to offset each other.
    Recall 1st gens with the 13WL caliper use the # 43512-0C011 rotor and appear to originally have come with semi met pads (# 04465-35250) but now Toyota sells a ceramic pad that has gone through several part number revisions. Currently found that # 04465-AZ200 are full width and not notched (reduced width).
    See photos: The pads and rotors appear to be Advics (but dial photos are from a 1st gen taco as I recall). Advics rotors and pads can be purchased from other suppliers and the ceramic pads apparently come with shims unlike if purchased from Toyota:
    Advics A6F004U Rotor
    https://www.rockauto.com/en/parts/advics,A6F004U,rotor,1896
    https://www.amazon.com/gp/product/B09ZQ6L1G3
    Advics AD0976 Brake Pad
    https://www.rockauto.com/en/parts/advics,AD0976,brake+pad,1684
    https://www.amazon.com/Advics-AD0976-Front-Brake-Pad/dp/B0081WW6FQ
    Hope this helps.
    1st Gen Tundra - Advic Pads (rear).jpg 1st Gen Tundra - Advic Pads (front).jpg Advics rotor.png Checking Hub Runout.jpg Checking Rotor Runout.jpg Assembled with index marks.jpg
  30. Jan 14, 2024 at 2:40 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    I had a terrible experience with hawk pads. They covered my wheels in dust like I've never seen before. Luckily, and unluckily, the braking material on one pad separated from the metal backing plate. Which you can imagine also destroyed the rotor. It happened sometime within the first 60 days of use but I was over cleaning my wheels every day. They were BLACK. Tossed them all in the trash and went back with oem
