How will these fit my tundra?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Natetrdoffroad, Jan 13, 2024.
  1. Jan 13, 2024 at 10:13 PM
    Natetrdoffroad
    Natetrdoffroad [OP] New Member
    Truck: 2014 tundra trd off-road. I plan on getting some 17x8.5 0 offset mr12's on 33x12.50 r17 nitro ridge grapplers. I currently have a stock suspension setup but plan to level out the front. will this setup require a body mount chop/and trimming?
  2. Jan 13, 2024 at 10:15 PM
    18" TRD Off Road Wheels
  3. Jan 14, 2024 at 4:45 AM
    Oolypoolay
    Oolypoolay Meh
    Virginia
    2015 Limited Crewmax
    Bilstein 6112/5160 Method 702 0 offet Toyo open country 285/75 17 Form led headlights OEM Toyota led fog lights Morimoto 3rd brake light Morimoto tail lights Amp Research power steps
    I just put 702’s on mine with 285/75R17. Lifted 1.9 in the front with 6112’s. Had to remove plastic but it clears the body mount.
    Natetrdoffroad[OP] likes this.
  4. Jan 14, 2024 at 4:47 AM
    Oolypoolay
    Oolypoolay Meh
    Virginia
    First time uploading a picture, let’s see if this works.
  5. Jan 14, 2024 at 7:05 AM
    jeffw6236
    jeffw6236 New Member
    Jeff
    San Antonio
    2019 MGM CrewMax 4x4
    You’ll probably clear the body mount. The 0 offset is the biggest thing to overcome. I’m at +7 and run a 287/70/17 - had to lose the mudflaps, push in the liner and I”ve got coachbuilder bumper shims.
