Serpentine belt without AC
Discussion in '1st Gen Tundras (2000-2006)' started by Eguti1971, Jan 13, 2024.
  1. Jan 13, 2024 at 10:49 AM
    Eguti1971
    Eguti1971 [OP] New Member
    Eli
    2000 Tundra SR5
    Stock
    2000 tundra 4.7 v8. Ac clutch failed, ran a 62.5 inch serp belt and deleted ac pulley, run perfectly... couldn't find and info only so I figured it out.. hope this helps some one.
  2. Jan 13, 2024 at 4:01 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Good info. Thank you for thinking about future searches. Good on ya mate!
    Elevatorguy and koditten like this.
  3. Jan 15, 2024 at 1:53 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    I do know most of your chain stores have the option of a/c or no a/c when you ask for the belt.
  4. Jan 15, 2024 at 3:07 PM
    bfunke
    bfunke Tundra Curmudgeon
    I’ve never seen a Tundra without A/C. Is that even a thing?
  5. Jan 15, 2024 at 3:10 PM
    His/hers failed, so they deleted the pulley and needed a shorter serp
  6. Jan 15, 2024 at 3:11 PM
    FishNinja
    Lee
    06DC2wd
    I don’t think it is. But it is an option when it comes to belt size.
  7. Aug 28, 2024 at 2:27 PM
    jake22si
    jake22si New Member
    kevin
    2000 tundra 4.7
    whats the belt diagram without ac?
  8. Aug 28, 2024 at 3:02 PM
    I'd need to dig up a diagram, but looks like the OEM p/n for the non-A/C belt is 90916-02792
    jake22si[QUOTED] likes this.
  9. Nov 17, 2024 at 1:51 AM
    DigNTundras
    DigNTundras New Member
    Sorry, late for this party but heres my trucks belt at Gates fwiw, (2005 Tundra Access Cab, 4.7). If you open 1st link below & click each belt listed youll see that belts diagram in pics?
    Click 2nd link below to add your own vehicle in their drop down menu.
    Nice how Gates took the time to add each belt diagram & the With/Without an AC unit routes are both shown.
    A+ for Gates, hope it helps members here in the future.
    1st link- 2005 Tundra Belts etc..
    https://navigates.gates.com/us/search-results?EquipmentClass=Passenger%20Cars%20%26%20Light%20Trucks&EquipmentYear=2005&EquipmentMake=Toyota&EquipmentModel=Tundra&EquipmentEngine=V-
    8%204.7%20L
    2nd Link: Catalog
    https://navigates.gates.com/us/catalogue-builder
  10. Nov 17, 2024 at 4:52 AM
    BroHon
    BroHon What day is it?
    Bro
    Final Outpost/Bitch Mitten
    '00 SR5 AC V8 4x4
    Iron oxide weight reduction
    @shifty`
    Interesting, we were just having this discussion. What Eguti1971 did is probably how I will solve that issue if the AC bearings give up the ghost.
    Because AC, and NON AC both have a pulley out there I am guessing he routed it something like this.
    Only thing in question is the amount of contact on the fan pulley, but apparently it works fine. :thumbsup: THX @Eguti1971
  11. Nov 17, 2024 at 7:07 AM
    I tried to find the gd belt routing sticker for the non-AC version of our trucks. I think that's the correct belt number I found above, but it was actually the STICKER that stumped me. Like, there's literally not one case of it I could find online! Which is baffling.
  12. Nov 17, 2024 at 1:23 PM
    DigNTundras
    Doesn't apply here but fwiw:
    My Ex wife had a 1995 GM (350 V8) & when her AC unit failed I ordered a $35 AC delete kit for it.
    Thats just a mount with a pulley on it. I removed her AC unit, bolted that mount/kit were the AC unit originally sit & done. It was a 10 min fix, the same oem belt is even used.
    Pretty sure Dorman made her kit but don't quote me there. This was around 2015 & hell I slept since?
    Unless there's a big market for it aftermarket corps rarely invest in such parts/kits. I know it had a cheap arse plastic pulley on it but hey' that was a handy lil' kit that kept it roll'n till she sold it like 5 yrs later. I figured it may last 2yrs max? Just say'n...
