Look at a tundra 4x4 best year used
Discussion in 'General Tundra Discussion' started by trentstarkes, Jan 12, 2024.
  1. Jan 12, 2024 at 2:48 PM
    trentstarkes
    trentstarkes [OP] 2019 Tundra CrewMax Limited
    Trent
    The Woodlands, TX
    Was wanting to know the best year to buy 17, 18, 19, 20 or 21 4x4 crew. Also what year to stay away from if any. Thanks. TS.
  2. Jan 12, 2024 at 2:56 PM
    2mchfun
  3. Jan 12, 2024 at 4:00 PM
    AZBoatHauler
    So.Arizona
    Or 17 depending about how you feel about the TSS sensor and “features”.
    Rodtheviking and 2mchfun[QUOTED] like this.
  4. Jan 13, 2024 at 2:12 AM
    Kbar691
    Kbar691 Hmmm
    Kenny
    2019 TRD Pro
  5. Jan 13, 2024 at 2:57 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Really depends on the trim level you're looking at in regards to features you'll get w/some of the packages, and like someone already said TSS turns some folks off quite a bit...
    So, IIRC the 20's and early 21s had some glitches (which I believe most can be attributed to sitting for months after production until reaching a dealer due to the whole chip shortage mess), but we are rarely hearing about any consistent additional issues from those 2 years. Some folks struggle w/the whole no tranny cooler (2019-2021), but as a few here have pointed out... we're not hearing about any transmission failures from these model years yet either (even those towing). For those that monitor transmission temps and want them in a certain range when towing, most have just installed an aftermarket cooler.
    Basically, I think it comes down to finding something that is configured the way you want; was properly maintained (and broke in hopefully); didn't spend time in the rust belt; has mileage logged on it that you are comfortable with; and is priced fairly :thumbsup:
    jeffw6236, 2mchfun, Krewcial and 2 others like this.
  6. Jan 13, 2024 at 2:59 AM
    18" TRD Off Road Wheels
    It depends on what you want and your intended use.
    2017 was the last year that did not have the Toyota Safety Sense systems (TSS which includes radar adaptive cruise, pre-collision system, etc.) so if you don't want that stuff it's the only model year you listed that won't have it.
    2018 is the only year to have both the TSS and a factory external transmission cooler.
    2019 is the first model year to not have the external cooler, but there are aftermarket coolers that can be added using factory plumbing if you are so inclined. 2019 is also the last year you could get a CD player.
    2020 was the first year to get Android Auto/Apple Carplay functionality, but only if plugged into a specific USB port in the dash. It was also is the first year that push button start and smart handles became available. All previous model years have regular old fashioned keys for the ignition. 2020+ trucks also had the exterior antenna eliminated for a shark fin on the roof. Previous model years had a standard antenna on the passenger side front fender. I believe the 2020 MY also saw the elimination of the flex fuel engine option and the smaller V8.
    2021 I'm not certain there were any major changes from the 2020 model year.
    Whatever year you buy, make sure you get the 38 gallon fuel tank unless the truck will be restricted to in town duty. The 5.7 V8 is thirsty and having more fuel on hand makes fuel stops much less annoying, especially if you intend to tow.
  7. Jan 13, 2024 at 3:57 AM
    ChrisLopez
    ChrisLopez New Member
    Christian
    Chicago,Illinois
    2018 Tundra SR5 TRD off road Crew max
    2018, TSS is not that bad. Transmission cooler is nice to have but like they said, no transmission issues for the ones without the cooler
  8. Jan 13, 2024 at 5:07 AM
    gnatehack
    gnatehack New Member
    Middle of Minnesota
    13 SR5 5.7 4x4 Bench
    Up to date maintenance
    2013.
    Cheaper to insure, cheaper to buy. Hardly any electronics to talk about. No sensors telling you where to park. Rear seats in the Crew recline and slide, great for kiddos and road trips.
    Stock fuel tank is fine even with towing; especially if you have kid bladders to think of...
  9. Jan 13, 2024 at 5:14 AM
    Pillslinger
    Pillslinger New Member
    Rollin
    SWMO
    2018 Cement TRD CrewMax
    Bed light kit Jerry can mount Badge overlays (removed 2021) Pin stripe / TRD decal / pillar vinyl removal Raised tailgate lettering Center console badge/tray/divider Interior/exterior LED upgrade VLED footwells TVD Vinyl TRD Offroad wheels Icon 17x8 rebound titanium Bubbas Garage grab handles WeatherTech floor mats (Eagle Klaw added) Rough country front shackles (removed 2021) DD SS3 yellow fogs MESO map light replacement Softopper MESO Chrome delete
    '18 and up also came standard with the updated LED headlights/fogs.
  10. Jan 13, 2024 at 5:16 AM
    LED running lights, yes, but the headlights are not all LED.
  11. Jan 13, 2024 at 5:37 AM
    Pillslinger
    Rollin
    SWMO
    I'll be dammed. I had to check this. SR, SR5 and Sport still ran halogen. Higher level trim levels ran LEDs
    Tripleconpanna likes this.
  12. Jan 13, 2024 at 5:40 AM
    The TRD packages also upgraded the trucks to LEDs.
  13. Jan 13, 2024 at 6:07 AM
    2mchfun
    Watch out for cam tower leaks (5.7), rusty framework, sticky 4x4 engagement, and bad timing chain tensioner noises or diesel like tapping at cold startup(5.7). I'd try to find a one owner, low mileage, and issue free 5.7 private seller and not be too concerned about the year it was built. Things like the head unit, headlights, tss, transmission cooler, etc. are easily remedied and a little bit of searching here on the site will explain the options. Expensive and time consuming drivetrain issues on the other hand can be a little more challenging. Regardless, run 5w-30 and change it every 5k or so for the longevity of your new investment.
    jeffw6236 likes this.
  14. Jan 13, 2024 at 8:00 AM
    clarkritchie
    clarkritchie New Member
  15. Jan 13, 2024 at 8:46 AM
    fallen0
    fallen0 New Member
    Minnesota
    2017 Tundra TSS OFF-ROAD, 2020 Mazda CX-5, 1997 Mazda Miata
    17 IMO but I am not a fan of all the tech they are putting in cars. I think it makes people more distracted than ever especially when you add a phone in the mix.
    I like my cars K.I.S.S. Keep it simple, stupid.
    AZBoatHauler and Jjclamdips like this.
  16. Jan 13, 2024 at 9:27 AM
    Bergmen
    Bergmen New Member
    Ukiah, California
    True, on my 2018 the LED headlights were part of the TRD Off-Road Package. Also, as mentioned earlier the TSS is really no big deal, easy to turn most of the "features" off.
  17. Jan 13, 2024 at 11:43 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    You can't really go wrong with any of them, but @GODZILLA gave a good synopsis of the differences. The drivetrain is practically identical for all of those years.
  18. Jan 18, 2024 at 9:12 AM
    DCRB4X4
    DCRB4X4 New Member
    BLACK 2015 DCRB SR5 4X4
    5100's front, spacer rear
    I concentrated my search to 2015-2017 (no TSS) SR5 or nicer 4X4 Double cab (for the bed). Bought a 2015 SR5 from the dealer with 166,00 miles. Full service record, one owner local trade in (verified). Rides and drives like new, no leaks at all.
    $21,500 out the door with a 30 day "all lubricated parts" warranty in writing. Can't believe I paid that much for a used vehicle but I love it. (This was in August)
  19. Jan 18, 2024 at 9:36 AM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    19,,,,,21
  20. Jan 18, 2024 at 10:07 AM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    17 or 18, 19 if you don't care about a tranny cooler. If you plan on replacing the suspension and skid plates, look for a Limited non TRD.
    AZBoatHauler likes this.
