Transfer Case oil
Discussion in '2.5 Gen Tundras (2014-2021)' started by digger21, Jan 12, 2024.
  1. Jan 12, 2024 at 3:09 PM
    digger21
    digger21 [OP] New Member
    Kane
    Tennessee
    2018 SR5 4x4 Crewmax
    LED interior and bed lights, steel off rd wheels with 285/55/20 Toyo Open Country ATIII. Tow mirrors, winnjet taillights, undercover ultra flex bedcover, chrome delete
  2. Jan 12, 2024 at 3:41 PM
    ChesterTundra
    ChesterTundra New Member
    Central FL
    2020 Tundra SR5
    RCI Alum skids w/cat guards Leveled and AT Cooled SPD Performance exhaust Amsoil everywhere…
  3. Jan 12, 2024 at 3:44 PM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    2018 Platinum Tundra, 2016 Platinum Sequoia, 2003 Tacoma SR5 V6 5Spd
    Just make sure it's GL-4 and not GL-5. Some products will claim they're compatible with both, but that's literally impossible (contradictory). So ensure it's only GL-4 and not GL-5 compatible.
  4. Jan 12, 2024 at 3:52 PM
    AZBoatHauler
    So.Arizona
    Johnmatrix, digger21[OP] and reywcms like this.
  5. Jan 12, 2024 at 4:35 PM
    ChesterTundra
    Central FL
    2020 Tundra SR5
  6. Jan 12, 2024 at 4:39 PM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    I used Redline MT-LV gear oil in my transfer case, as it specifically is GL-4 and not GL-5 compatible. It also states on the bottle that it's safe to use in lieu of Toyota 75w gear oil.
    Also it's only like $20 a quart instead of $90 per quart for Toyota 75w.
  7. Jan 12, 2024 at 6:16 PM
    digger21
    Kane
    Tennessee
    coldcanuk likes this.
  8. Jan 12, 2024 at 6:25 PM
    digger21
    Kane
    Tennessee
    Thanks y’all! I’m just gonna order the ravenoil 75W to be safe.
    Tyman, OHwendTrd and Doxiedad like this.
  9. Jan 12, 2024 at 6:31 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    That's the exact oil I'm using.
  10. Jan 13, 2024 at 2:21 AM
    Kbar691
    Kbar691 Hmmm
    Kenny
    2019 TRD Pro
    I have read article and opinion over and over. They seem to stack up that a synthetic 75w-90 is perfectly fine in front, rear and T case. I bought a case of valvoline 75w-90 on Amazon for $100. I do find it interesting though that we are recommended to change this fluid every 30k miles. I work in chemical plants and that 75w-90 is the same oil used in many pieces of rotating equipment operated 24-7-365. We change it every 5 years…..
  11. Jan 13, 2024 at 4:26 AM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    Amsoil has no products listed for the transfer case..
    digger21[OP] likes this.
  12. Jan 13, 2024 at 6:31 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    If you can find a 75w90 oil that is GL4 than your fine to use it. Toyota specifies GL4 oil for the transfer case.
  13. Jan 13, 2024 at 7:20 AM
    digger21
    Kane
    Tennessee
  14. Jan 13, 2024 at 7:21 AM
    digger21
    Kane
    Tennessee
    I’m gonna change it every 60,000 miles that will be about 4 years for me.
    WILLINH likes this.
  15. Jan 13, 2024 at 8:59 AM
    fallen0
    fallen0 New Member
    Minnesota
    2017 Tundra TSS OFF-ROAD, 2020 Mazda CX-5, 1997 Mazda Miata
    Shouldn't be an issue. The rear diff would be earlier for me since I tow. If you do also, maybe do the rear at 45k.
    As long as you work out the T-case once a month you should be fine.
    If you live in the city, find a nice straight road that is about 2-3 miles long or more. Switch to 4hi and turn off when desired or before a curve.
    You can do the same in 4lo but I reserve that for little to no traffic since you have to be stopped and in neutral to engage/disengage.
    digger21[QUOTED][OP] likes this.
  16. Jan 13, 2024 at 9:49 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    The reason for switching from 2HI to 4HI and 4LO is to exercise the transfer case actuator and the front diff actuator. You don't have to drive the truck a couple of miles in 4WD. You can switch it back and forth in the driveway. The actuators tend to seize up if not used for a long period of time and is not related to the transfer case oil life.
  17. Jan 13, 2024 at 10:31 AM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    This is the part number for the only approved fluid by Toyota 08885-81080. No other fluid is remotely close to it when compared with oil analysis. That said, many on the forum have used Ravenol, Redline, and amsoil products, many have also just used 75w90 which is what many have reported dealers have used. I think the biggest issue with using 75w90 over 75w is the 75w90 is much thicker and causes issues engaging when its cold, which for me is the majority of time I need 4x4 so I stick with the Toyota fluid and have had no issues going in and out of 4x4 im the winter.
    Avi8or and digger21[OP] like this.
  18. Jan 13, 2024 at 11:37 AM
    fallen0
    fallen0 New Member
    Minnesota
    Got it thanks. I thought it was two fold. Lube the actuators then lube the chain and other components under movement. Guess the latter is not really needed.
    Ruggybuggy[QUOTED] likes this.
  19. Jan 14, 2024 at 9:42 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Changed it at 50k in my Tacoma and looked just like the stuff I poured out of the bottle. I change the diffs every 30k. My transfer case is overdue but not worried about it until it warms up some. I have 2 quarts of Ravenol in my cart on Ebay. Reading this I might delete them and get the GL4 mentioned here.
  20. Jan 14, 2024 at 9:51 AM
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    GL-5 supersedes GL-4, there is no reason not to use a superior GL-5 lubricant. Both the API and SAE agree on that point.
  21. Jan 14, 2024 at 10:18 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    digger21[OP] and AZBoatHauler like this.
  22. Jan 14, 2024 at 10:23 AM
    centex
    centex New Member
    Lucas 75-90 in all diffs and t case. So far all good. Same with my 4runner, Durango, and k5.
  23. Jan 14, 2024 at 10:28 AM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
  24. Jan 14, 2024 at 10:39 AM
    centex
    centex New Member
    Cool. Experience says it’s fine so I posted it.
  25. Jan 14, 2024 at 11:22 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Here is a very good article comparing GL4 and GL5.
    https://rxmechanic.com/gl4-vs-gl5/
    It looks like a GL5 can be used in a GL4 application in most cases but does suggest using what the manufacture calls for. The only thing I've read is that if you use a GL5 gear oil where copper syncos are used that it will cause hard shifting in a manual transmission which makes sense because it has added wear protection to reduce friction.
  26. Jan 14, 2024 at 11:30 AM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    Here is the technology behind the fuel efficient MTF LV. The LF T-case fluid is based upon this, probably with a slightly different add pack. The oil analysis is posted at the bottom, it’s Russian, but not difficult to figure out… nothing magical, group III w/ modern additives that prevent metal to metal when the oil film can no longer keep things separate.
    A34FDE68-BD1E-454D-888C-6CDCBEAF49EE.jpg 8F4C643F-0213-4709-9D4C-93AC7F6D8DAC.jpg 1D2BCB3A-00C2-43ED-9320-AD94DBC4707D.jpg CD897CE2-041C-4EBE-A4EB-B4AA729077AC.jpg 9AA2AA60-DACC-410D-AD68-DCE6BB177A53.jpg 0552F035-71A3-4793-85B1-A521B35F9F11.jpg 4EBEC7D1-7138-410A-8743-D4D77E66C1B9.jpg
    CaptRussia253 likes this.
  27. Jan 14, 2024 at 11:52 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    a little humor to this epic:
    and if you spill some Ravenol 75w on something...apparently it will smell like Ravenol for 106 years.
    that stuff is rank.
  28. Jan 14, 2024 at 12:45 PM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    Care Care Nut claimed that Toyota manual transmissions and transfer cases don't like GL-5 oils. He recommended staying with GL-4 oils for both.
    WILLINH likes this.
  29. Jan 14, 2024 at 2:35 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    That's what I'm using because that's the spec Toyota calls for. Why take a chance on having to repair a transfer case.
    Red&03Taco[QUOTED] likes this.
  30. Jan 15, 2024 at 2:17 PM
    Totmacher
    Totmacher New Member
    Daniel
    West TN
    mesquite Tundra or blue 4Runner
    Some
    Ruggybuggy likes this.
