PCV Valve
Discussion in '2.5 Gen Tundras (2014-2021)' started by Beardoog3, Jan 12, 2024.
  1. Jan 12, 2024 at 9:29 AM
    Beardoog3
    Beardoog3 [OP] New Member
    So, I just completed the 30K service at my local stealorship.
    I was summoned to the service advisor who stated that the technician advised that I replace the PCV valve ($490) and clean the fuel system ($380). I declined.
    Question: Is it advisable to replace the PCV valve on a milage based schedule? Will not doing so affect the warranty?
    Thanks
  2. Jan 12, 2024 at 9:31 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Sounds like total BS.
  3. Jan 12, 2024 at 9:34 AM
    Mr Badwrench
    Mr Badwrench New Member
    At 30,000 miles, I can assure you, you do not need either service.
    Fuel system cleaning service is a scam at any age/mileage.
    Rstreight, equin, Skaufma0 and 7 others like this.
  4. Jan 12, 2024 at 9:37 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Find a new dealer fast! Or better yet start performing your own maintenance…your truck will thank you!
  5. Jan 12, 2024 at 9:48 AM
    2mchfun
    PCV should be checked for proper function but not likely bad at stated mileage. Watch YouTube for maintenance check procedure. Clean your own fuel system with two cans of Berryman's B12 chemtool in a half tank of fuel every 25k. Fuel injector cleaning after about 200k for best performance.
    Pillslinger, WILLINH and Shanet421 like this.
  6. Jan 12, 2024 at 9:48 AM
    Beardoog3
    Thank you. That is what I thought. Not going back again for sure.
  7. Jan 12, 2024 at 9:49 AM
    Beardoog3
    Thank you Dan
    2mchfun likes this.
  8. Jan 12, 2024 at 10:42 AM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    I had one put in my wife’s Subaru 2 years ago at the dealership and it was $59 for part and labor.So $490 is extreme.
    seanyy11 and Black Wolf like this.
  9. Jan 12, 2024 at 10:50 AM
    AZBoatHauler
    So.Arizona
    What dealer so they can be publicly ridiculed for their thievery…
  10. Jan 12, 2024 at 11:24 AM
    PRNDS
    PRNDS New Member
    FL
    2021 Black Limited 4x4
    Even if you did need the PCV valve, the price is a rip. The PCV valve costs about $30 at the parts counter and can be swapped in 15 minutes.
  11. Jan 12, 2024 at 11:38 AM
  12. Jan 12, 2024 at 12:23 PM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    PCV valve is like 8 dollars. WTF has happen to humanity these days. Are people this fucked up?
  13. Jan 12, 2024 at 3:09 PM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
  14. Jan 12, 2024 at 6:42 PM
    CasperTheFriendlyTundra
    CasperTheFriendlyTundra New Member
    I change my pVC valves every couple of years on my vehicles. They are so cheap they it's not worth reinstalling a used one.
  15. Jan 12, 2024 at 10:47 PM
    Brothermoe
    Brothermoe New Member
    Brandon
    Kitsap county WA
    2014 Crewmax
    About 2 weeks after I bought my 14 tundra elsewhere, took mine in for an oil change. My local dealer also wanted to charge me $579 to replace the pcv, plus 500 for spark plugs, 350 for front/rear/transfer case oil, 300 fuel treatment, 30 each for 2 marker lights(still haven't found any burnt out)and license plate light, and probably more im forgetting. I bought oem Toyota pcv for 15 on Amazon and it took me longer to find the right socket than actually replace the damn thing. Heartland Toyota of Bremerton service department is a bunch of crooks.
    equin, Mdl, Tripleconpanna and 3 others like this.
  16. Jan 13, 2024 at 8:02 AM
    Gene_in_FL
    Gene_in_FL SUPER genius
    FLORIDA
    2016 SR5 DC 5.7 2021 SR5 DC 5.7
    I'm guessing the name is "Bernie Madoff Toyota".
    equin, WILLINH, 2mchfun and 3 others like this.
  17. Jan 13, 2024 at 8:49 AM
    fallen0
    fallen0 New Member
    Minnesota
    2017 Tundra TSS OFF-ROAD, 2020 Mazda CX-5, 1997 Mazda Miata
    Dealer charges so much because the book states to remove the intake manifold, which is I think 4hr time.
    Intake does not need to be removed.
    PCV - $24.99
    22mm socket
    10 minutes max time.
    Changed mine at 130k (Purchased at 120k) in my drive way before going to work. Old still functioned, but a rear main seal leak alerted me to change it. No more leak.
  18. Jan 13, 2024 at 10:30 AM
    Brownsfanhere
    Brownsfanhere New Member
    2015 Crew Max
    What a load of poo from that dealer. And they wonder why folks don’t trust dealerships.
  19. Jan 13, 2024 at 3:28 PM
    Gene_in_FL
    FLORIDA
    I call bullshit.
  20. Jan 13, 2024 at 3:30 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Yes... some are :thumbsup:
    pursuit2550[QUOTED] and WILLINH like this.
  21. Jan 13, 2024 at 6:02 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Pcv valve is like 4 dollars from Toyota. I change it every 25k on all my vehicles. If it saves you .005 mpg it still paying for itself in fuel alone.
  22. Jan 14, 2024 at 5:01 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Local dealership left a VM. They offered me a full synthetic oil change for $14.95. I am certain they were just inticing me to come so they could try to sell me some other bullshit. Air filters at the least. They tried to get me in once for steering rack recall. Checked my VIN and no recalls. Dealerships make their money off little old ladies and women.
    MadMaxCanon and WILLINH like this.
  23. Jan 14, 2024 at 1:57 PM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    Would anyone mind sharing the part number?
  24. Jan 14, 2024 at 3:16 PM
    agrestic1
    2016 CrewMax
  25. Jan 14, 2024 at 7:27 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    God, please don’t take this wrong, because stories like this absolutely make my blood boil. Hear me out…
    I am in construction sales, yet consider myself to be very honest and will 100% do my best to save a customer money.
    But!!! If I get the job done faster than expected, should I discount the price? What about if the job takes longer than it was supposed to? Not many customers want to hear that they need to pay more than expected…. Some jobs are quoted on a Time & Materials basis, with a not-to-exceed price. Totally fine, we both know this coming in. Obviously, a small buffer is added in case the job goes a little over. It makes it fair. The ones that irk me is when I competitively bid a project and then the want to make it T&M, NTE that price. That ain’t right, because it relieves all risk from their end, but not mine. It isn’t fair, so I don’t accept the terms. Almost like ordering dinner, eating it, then dickering on the price when the bill is delivered…
    Again, don’t over think my thoughts here. Dealerships are notorious for quoting “book” prices, and I’m assuming that a lot of these jobs are done in well under the time that the book says. Does the service tech get paid 4 hours for the 20 minute job? Does he later get paid 2 hours for a job that went a little sideways and took 5 hours?
    Or is the dealer fucking the customer on book rates and paying the tech hourly?
    In the end, it’s always smart to learn about our trucks and handle what you can on your own. Spark plugs? $100 in plugs and 30 minutes in the garage. That ain’t a $500 job…. But when you have things beyond your capabilities, it is worth finding a private mechanic that you trust with your vehicle and believe that he has your best interest at heart. I’m fortunate to have a longtime friend that owns a very reputable shop in town. I knew him as Landcruiser Dan for a lot of years before I actually knew his last name…. He ain’t cheap, but he does it right.
  26. Jan 14, 2024 at 8:53 PM
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    This is scary. I went to my Toyota dealer 2 weeks ago and purchased a brand new OEM PCV valve and I believe it was $12. I processed to drive home, remove the old one and install the new unit in 20 minutes. I could see this being a $29-$39 job but at this price, I would stop doing business with this dealer and leave them a poor Yelp and Google review.
  27. Jan 15, 2024 at 3:02 PM
    Gene_in_FL
    FLORIDA
    You ARE fortunate. And "does it right" is all I ever hoped for in mechanic. Or anyone else.
    It reminds me of the sign you sometimes used to see in repair shops: "You can get it done cheap, you can get it done fast, or you can get it done right. Pick one." ;)
  28. Jan 16, 2024 at 5:17 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    I think most dealers charge a 1 hour minimum. I know from getting the free oil changes that they don't on air filters but probably because the truck is already in the shop. When they pulled mine and showed it to me the price was $30. Of course I passed on their air filters.
    georgiey22[QUOTED] likes this.
  29. Jan 16, 2024 at 5:31 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, solid Offroad engine mounts, DIY Traction Bars, Tuning by snivspeedshop.com
    The service dept is clueless...the parts department is polar opposite. Parts dept are very knowledgeable and will take the time to find and cross reference parts.
    Brothermoe[QUOTED] likes this.
  30. Jan 16, 2024 at 6:01 AM
    Skaufma0
    Skaufma0 Just a little stitious.
    Rock Hill, SC
    2018 MBM Limited CM
    This right here.
    We always used:
    You can get it done fast and cheap, but it won't be right.
    You can get it done cheap and right, but it won't be fast.
    You can get it done fast and right, but it won't be cheap.
    Gene_in_FL[QUOTED] likes this.
