2020 Tundra TRD Won't Start
Discussion in 'General Tundra Discussion' started by Gorbyt6, Dec 27, 2023.
  1. Dec 27, 2023 at 6:44 PM
    Gorbyt6
    Gorbyt6 [OP] New Member
    NewTruck
    2020 Tundra Limited
    Leveling Kit,Step Rails,Tembren SES
    I have a 2020 Tundra with 23000 miles.It just started to act up. Truck will turn over but will not start.It has the push button start system with a Fob. It will take several tries before it will start . This does not happen all the time.Battery has been replaced in the fob.Now I am at the point that I don't trust it. Does anybody have any ideas what might be wrong?
  2. Dec 28, 2023 at 8:47 AM
    seydou
    seydou Distinguished Member
    What is the tested condition of the vehicle battery?
    PermaFrostTRD likes this.
  3. Dec 28, 2023 at 9:00 AM
    Bergmen
    Bergmen New Member
    Ukiah, California
    Could be one of a 100 things. Almost impossible to diagnose over the forum, I would take it to the dealer.
  4. Dec 28, 2023 at 9:00 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Being a 2020, now is about the time the battery will take a crap. You probably need to replace the vehicle battery. They generally last 3-4 years.
  5. Dec 28, 2023 at 9:11 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    I would definitely start with a thorough check of the vehicle battery. Have you tried the other fob? I got two with my 2020.
  6. Dec 28, 2023 at 1:23 PM
    Gorbyt6
    NewTruck
    2020 Tundra Limited
    I will be trying the other fob it hasn't been used since new. Have put new battery in it for the test. Have been thinking about the truck battery also. just eliminating the simple things first. Dealership is an hour away.
  7. Dec 28, 2023 at 1:24 PM
    ninjajay
    ninjajay Posting from the toilet
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Toytec/Radflo Lift, Ambit RS02 18x9+0, Bridgestone Revo 3 295/70/18
    If it’s not the battery - Is it a flex fuel truck? Do you have access to an OBD2 reader or Techstream?
    KNABORES likes this.
  8. Dec 28, 2023 at 3:44 PM
    clarkritchie
    clarkritchie New Member
    It's probably your battery, which are known to be crap. The OEM battery in my '21 was only producing ~400 cold cranking amps (factory spec is 710) after 2 years + a few months.
  9. Jan 11, 2024 at 4:47 PM
    Gorbyt6
    NewTruck
    2020 Tundra Limited
    Here is an update on my issue. Replaced the battery and it still started off and on until yesterday and then it wouldn't start at all, towed to the dealer and they found the fuel pump control module had shorted out.Good thing for extended warranty. Will pick up tomorrow.
    clarkritchie likes this.
