Good Buy?
Discussion in '2.5 Gen Tundras (2014-2021)' started by evanthetrucker, Jan 11, 2024.
  1. Jan 11, 2024 at 1:39 PM
    evanthetrucker
    evanthetrucker [OP] New Member
    Hey everyone, im looking to buy my first tundra. I found a 2014 tundra double cab sr5 with a 6.5 foot bed on facebook market place. It has 180k miles. Timing chain was replaced 2020 and In 2021 received all new engine gaskets, drive chain, water pump ect. Its in really good shape, most of the miles were on the highway. There is a little surface rust underneath... They have it listed for 14k. Im just looking for someone else's opinion on it as I am not very experienced.
  2. Jan 11, 2024 at 4:02 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    See how big the fuel tank is. If i recall (someone correct me if i'm wrong) the 14's came with a small tank.
    Post up picture of what you are looking at.
    and welcome
  3. Jan 11, 2024 at 4:04 PM
    Retired...finally
    Major work done twice in two years? I'd run.
  4. Jan 11, 2024 at 4:10 PM
    evanthetrucker
    Thanks! Heres a picture. 26.4 gal tank
    IsaiahCanada likes this.
  5. Jan 11, 2024 at 4:42 PM
    That’s a lot of work at 180k imo for a tundra
    Timing chain…is this the 5.7?
  6. Jan 11, 2024 at 4:43 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    You will come to regret the small fuel tank, it eats too fast. A lot done before 200k, think I have to agree on passing. Better deals out there. Visually nice truck otherwise
  7. Jan 11, 2024 at 4:47 PM
    evanthetrucker
    yeah it is the 5.7, do you know what years have the larger fuel tanks?
  8. Jan 11, 2024 at 4:49 PM
    I think 2016+ and the TRD+ trim
    GODZILLA, IsaiahCanada and OHwendTrd like this.
  9. Jan 11, 2024 at 5:00 PM
    NoRcptn
    NorCal
    2017 Platinum
    mmmm. Timing chain twice in a year? doesn't make sense. Pass.
    Metro14536 likes this.
  10. Jan 11, 2024 at 5:01 PM
    evanthetrucker
    Sorry I worded it poorly, the timing chain was replaced in 2020, the other stuff listed was done the year after because the dealer recommended it.
  11. Jan 11, 2024 at 5:09 PM
    NoRcptn
    NorCal
    2017 Platinum
    Oh I read it SLOWER and it makes sense. The price is good for what I see around my area, however that makes me skeptical but it is a higher mileage Tundra. That is a lot of work for less than 200k miles.
  12. Jan 11, 2024 at 6:19 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    “Dealer recommended”…
    How much of the work was necessary? If the work was done at a dealer, there should be notes on why the work was done, I’d think. Perhaps the previous owner acquainted a timing chain to a timing belt and assumed it needed periodic replacement, and a dealer may have obliged?
    IMHO, it’s worth a look and checkout with a solid mechanic that is familiar with Tundras.
    If it checks all your boxes, lowball them enough to retrofit a 46 gallon Transfer Flow tank. Unless all your driving is just around town, you will hate the 26 gallon.
  13. Jan 11, 2024 at 7:27 PM
    Gene_in_FL
    Gene_in_FL SUPER genius
    FLORIDA
    2016 SR5 DC 5.7 2021 SR5 DC 5.7
    That, or somebody said timing chain when they meant serpentine belt?
  14. Jan 11, 2024 at 8:02 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! I think the previous owner was ignorant and fell for a dealer scam to have all that work done.
  15. Jan 11, 2024 at 8:07 PM
    Yep. Easy money for the service writer
  16. Jan 12, 2024 at 6:12 AM
    DCLarston13
    DCLarston13 New Member
    2020 Tundra Magnetic Gray TSS
    Did you run a carfax on it? Personally all the work that was done recently would make me skeptical. The price is pretty good. The previous owner probably spent a few grand at the dealer getting that work done. Why did they not want the truck after spending all that money?
  17. Jan 12, 2024 at 6:24 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Pass. No way a 3UR engine would need that work that soon. Something is off.
  18. Jan 12, 2024 at 10:15 AM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    2018 Platinum Tundra, 2016 Platinum Sequoia, 2003 Tacoma SR5 V6 5Spd
    Agree with others, pass.
    Is $14k the top end of your budget? If so maybe find a clean 1st gen Tundra. Hard to find a real good 2nd/2.5 gen in that price range.
    If you can afford a higher price point, I'd look for lower mileage examples, unless you find a 1-owner, higher mileage example with droves of service records.
    In my experience buying cheaper, higher mileage Toyotas, the seller usually drives them until all the deferred maintenance can't be put off any longer, then sells to someone else who's then got to absorb those costs. They buy the Toyota thinking they're so reliable they don't even need maintenance.
    Then the vehicle can nickel and dime you to death with small repairs the previous owner neglected for too long (i.e. brakes, suspension, tires, fluids, belts, filters, etc). The couple grand more in purchase price needed to get a meticulously maintained vehicle will save you money in the long haul.
    Gene_in_FL likes this.
  19. Jan 12, 2024 at 5:19 PM
    evanthetrucker
    Hey everyone thanks for your advice. I asked the seller if there was any wiggle room on the price but he never responded. I'll probably keep on looking for the right truck! I may wait a little bit and save up some more money to get something newer/less miles.
    Gene_in_FL, OHwendTrd and T-Rex266 like this.
