RainMan's 2021 Lunar Rock TRD Pro Build
Discussion in '2.5 Gen Builds (2014-2021)' started by RainMan_PNW, Oct 30, 2020.
  1. Jan 9, 2024 at 2:13 PM
    #961
    RobertD
    Robert
    DFW, Texas
  2. Jan 9, 2024 at 2:14 PM
    #962
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    :D
    RobertD[QUOTED] likes this.
  3. Jan 9, 2024 at 2:33 PM
    #963
    TaquitoBandito
    Joel (AKA Bif)
    It's a little after the fact now, but okay. :)
    TRDFerguson and Tripleconpanna like this.
  4. Jan 9, 2024 at 8:19 PM
    #964
    RainMan_PNW
    RainMan_PNW [OP] "Oz" SSEM #82 RGBA #4 Unofficial Forum Treasurer Vendor?
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Worth noting that I no longer have that one installed.
    I switched over to this one that has USB-C and higher output.
  5. Jan 10, 2024 at 3:17 PM
    #965
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Did you have to remove the center console to access that plug? Looking to do the same on our seqouia and pulling on the factory plug broke the cover off and scared me to pull harder lol
  6. Jan 10, 2024 at 3:29 PM
    #966
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
    Click on the link in the message that you quoted that says "Look for that write-up here". It tells you everything.
  7. Jan 11, 2024 at 10:01 PM
    #967
    RainMan_PNW
    Casey
    Clark County, WA
    Like Jeff (Bulldog) said - hit that link for more details. But no - don't have to remove the center console, just the back panel of it. Don't pull on the factory plug - use a trim tool to lift up/out on the whole back panel.
    TaquitoBandito, bulldog93 and RobertD like this.
  8. Jan 22, 2024 at 1:34 PM
    #968
    Ptundra
    Ptundra New Member
    2016 1794 Crewmax
    TRD Sway bar and a fresh new cabin air filter
    Can I pick some brains?
    Related to this:
    ‘Also wrapped up the install of BSM on another member’s truck about 1-1/2 hours’
    Got destroyed by rain last week. Water through cabin air by way of cowl (I think) with puddle on passenger floor. Now my passenger side BSM stays illuminated and drains battery. Is there a harness or wire that I should hone in on to fix/replace?
  9. Jan 22, 2024 at 2:46 PM
    #969
    RainMan_PNW
    Casey
    Clark County, WA
    Not knowing what year or trim level your truck is makes it tough (information you can fill out in your profile).
    That said, I would trace the harness that comes from your mirror down through the door and into the passenger kick panel junctions. Specifically MJ2 (pin 3) and AJ3 (pin 18).
    BUT, all that said, if the system is illuminated with your truck off, you've potentially got bigger issues. The circuit that powers the BSM is from the IGNITION fuse ECU-IG1 No. 4 - it won't be powered unless the key is on (or smart switch in ignition). So unless there's a short in one of those connectors that is allowing battery power (not sure what else is in there) to juice up that LED (in which case it's probably also shorted to a whole slew of other stuff), I'm not sure what's causing it.
  10. Jan 22, 2024 at 3:50 PM
    #970
    Ptundra
    Ptundra New Member
    2016 1794 Crewmax
    *updating the profile after this post
    Thank you for the response and guidance. Sounds like I need to start researching how to locate and check the ignition fuse. Crazy how many posts I've found with similar cowl-related water issues but seems I’m alone on the electrical surprises downstream. Doubt it’s helpful but there is one harness in the passenger kick panel that makes the illuminated BSM light flicker when a give it a shake.
  11. Jan 22, 2024 at 4:59 PM
    #971
    RainMan_PNW
    Casey
    Clark County, WA
    You might also look for rodent damage. that sounds like compromised wire insulation causing a short between a BATTERY-powered wire and your BSM LED. Just that LED by itself shouldn't drain the battery that fast, but if a wire is damaged and shorting out something else that could be draining things pretty quick.
  12. Jan 22, 2024 at 6:10 PM
    #972
    Ptundra
    Ptundra New Member
    2016 1794 Crewmax
    Im afraid mice love the barn so I’ll survey for damage.
    Do you know what the 3 blue ones are above AJ3? Think it’s one of those that semi fixes the issue when a shake it.
  13. Jan 22, 2024 at 7:43 PM
    #973
    RainMan_PNW
    Casey
    Clark County, WA
    Not specifically without digging through the wiring diagrams... Hit the link in my signature and download them for your model year. The "Location and Route" will give you info on everything over there to get the connector names and colors, then dig through the diagrams to search for those connector names to see what circuits are involved. That particular area is pretty busy though, since it is the primary junction between the ECM, the harnesses running out to the rear of the truck, and a lot of stuff in the cabin.
    Ptundra[QUOTED] likes this.
  14. Jan 23, 2024 at 3:42 PM
    #974
    Ptundra
    Ptundra New Member
    2016 1794 Crewmax
    Those diagrams are gold. Ty ty Ty! Related ?, reattaching the cowl and have gaps…do people use silicone Or gorilla glue to seal?
  15. Jan 23, 2024 at 4:44 PM
    #975
    RainMan_PNW
    Casey
    Clark County, WA
    no idea.
  16. Jan 23, 2024 at 4:57 PM
    #976
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    You didn’t get the cowl clips under the windshield. You’ll need to kind of tip it in and up under the windshield to get it to seat right.
  17. Jan 26, 2024 at 9:47 AM
    #977
    Ptundra
    Ptundra New Member
    2016 1794 Crewmax
    That’s what I thought too. Tried a couple times. The plastic clips must be slightly bent from removing the cowl so it won’t sit flush. Tried the heat gun which helped a little. Thinking about using a clear silicone or something. Anything to avoid paying hundreds for a new cowl.
  18. Feb 6, 2024 at 5:30 PM
    #978
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    @RainMan_PNW or even @memario1214
    out of curiosity, what is the height from the bed rail to the sherpa rack crossbar?
  19. Feb 6, 2024 at 5:36 PM
    #979
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Top of bed rail to top of roof rack... I can probably snag that for you tomorrow in the daylight.
  20. Feb 6, 2024 at 6:01 PM
    #980
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    :rolleyes:
    making a water slide from the top of your roof and need to figure out the pitch and length of supports?
  21. Feb 6, 2024 at 6:08 PM
    #981
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    close
  22. Feb 6, 2024 at 6:32 PM
    #982
    RainMan_PNW
    Casey
    Clark County, WA
    Just saw this. I can grab a measurement tomorrow as well
    TaquitoBandito and TRDFerguson like this.
  23. Feb 6, 2024 at 6:33 PM
    #983
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    it’s a race, whomever wins gets a mustache ride from @AT x AT and a ZJ from @TRDFerguson
  24. Feb 6, 2024 at 6:34 PM
    #984
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  25. Feb 6, 2024 at 6:39 PM
    #985
    @TRDFerguson i didn’t know there were other win-cubed gifs…..
  26. Feb 6, 2024 at 6:41 PM
    #986
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
  27. Feb 7, 2024 at 7:04 PM
    #987
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    guess I need to sweeten the pot...adding a lap dance from @KevinK
  28. Feb 7, 2024 at 7:06 PM
    #988
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    And yet…
  29. Feb 7, 2024 at 7:07 PM
    #989
    memario1214
    Colton
    Missoula, MT
    Someone forgot… :pout:
    Text me in the morning for instant results.
  30. Feb 8, 2024 at 6:43 AM
    #990
    RainMan_PNW
    Casey
    Clark County, WA
    Yesterday was a shit show - was working till after 11pm.
    just checked - 23-3/4” exact from the top of the cross bars to the top of the bed cap at the back of the cab.
