3/2 Readylift
Discussion in '3rd Gen Tundras (2022+)' started by Rampking01, Jan 9, 2024.
  1. Jan 9, 2024 at 6:27 PM
    Rampking01
    Rampking01 [OP] New Member
    I’ve searched through as much as possible on this site. Anybody running a 3/2 Readylift on a 3rd Gen? My car dealership has these installed on some of their new ones. I talked to the installers today and they said they replace control arms and spindle drop as well. Below is an example. It looks great but I don’t know much about Readylift.
  2. Jan 10, 2024 at 11:54 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Most often readylift is a spacer lift or combo if a larger lift. Lower price to get a certain look and some clearance for bigger tires. Look vs function.
    So basically spacers to make it higher and maybe drop brackets or other lowering spacers to use the stock suspension. Mainly for looks, you dont want to be doing any heavy offroading with a spacer lift for many reasons, not going into all that.
    https://www.readylift.com/toyota-lift-kits
    Rampking01[OP] likes this.
  3. Jan 10, 2024 at 12:00 PM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
    There were 5 pages of results containing the word readylift. Click on more on the search and you can narrow it down to 3ed gens only.
