Buzzing Noise on Startup
Discussion in '2nd Gen Tundras (2007-2013)' started by MartinBlank, Jan 3, 2024.
  1. Jan 3, 2024 at 4:36 AM
    MartinBlank
    MartinBlank [OP] New Member
    Bruce
    Loveland CO
    2008 Crew Cab Limited
    TRD Sway Bars, TRD CAI, Bilstein 5100's, LED's, plus LED rear Plate backup light, Aluminum oil filter housing, ECGS Needle Bearing upgrade.
    Hey Guys,
    I've been having a weird buzzing noise on startup when it's cold out. The noise seems to be coming from the pass side rear seat area. If I shut off the engine and restart, it doesn't come back.
    Anyone have any idea what it might be? I was thinking evap system maybe?
    Thanks
    Bruce
  2. Jan 4, 2024 at 6:50 AM
    MartinBlank
    Bruce
    Loveland CO
    Anyone?
  3. Jan 4, 2024 at 8:03 AM
    G Man
    G Man New Member
    Could it be your secondary air injection pumps? They are on the passenger side but under the hood. They come on for a very short time on cold start and then turn off.
  4. Jan 4, 2024 at 1:43 PM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    Have you pulled to HVAC blower motor, there may be a piece of debris in there. It’s only 3 screws. It could also be one of the bearings in it going bad. It’s a common problem with most Toyota’s. If you have to get a replacement, stay away from the Dorman brand unless you want to replace it every 6 months
  5. Jan 9, 2024 at 4:31 PM
    MartinBlank
    Bruce
    Loveland CO
    Danny3737- I replaced the blower motor last fall (OEM), that isn't it. I'm guessing it's the air injection pumps like G Man said. It's driving me crazy, having to restart it every morning to make the noise go away.
