RainMan's 2021 Lunar Rock TRD Pro Build
Discussion in '2.5 Gen Builds (2014-2021)' started by RainMan_PNW, Oct 30, 2020.
  1. Jan 8, 2024 at 11:16 AM
    #931
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    I sent you mounting hardware already for the Sherpa! Looking at the tracking number though it would appear that USPS lost it... :annoyed:
    Did the wire hider show up?
  2. Jan 8, 2024 at 1:17 PM
    #932
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    My thought on forward facing driving lights, higher up you go, tighter dispersion (spot/hyperspot) beam patterns make more sense and even color (amber reduces does zap some efficiency).
    I'll be curious to see what the final output looks like. even with the fairing creating some artificial cutoff. I worry about hood splash.
  3. Jan 8, 2024 at 1:55 PM
    #933
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Gotta run it at Kevink depth to eliminate that. Hopefully Casey won’t see too much increase in wind noise or light bounce. Lunar rock should be a good color for it though.. not like “site foreman” white:boink:
    I too Will be interested to see the results
    Not gunna lie, was a little butt hurt I wasn’t invited to contribute :pout:
  4. Jan 8, 2024 at 1:59 PM
    #934
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Dang... my status as a super white plebe got upgraded to "site foreman" status...eat it @TRDFerguson
  5. Jan 8, 2024 at 2:01 PM
    #935
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
  6. Jan 8, 2024 at 2:08 PM
    #936
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  7. Jan 8, 2024 at 2:15 PM
    #937
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
  8. Jan 8, 2024 at 2:16 PM
    #938
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I almost used that gif instead
  9. Jan 8, 2024 at 2:20 PM
    #939
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Similar minds think alike....was going to say great...but that would've been me giving you too much credit....
  10. Jan 8, 2024 at 2:50 PM
    #940
    SAGE63
    San Diego County
    YES....
  11. Jan 8, 2024 at 4:21 PM
    #941
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Bottom. It’s bottom.
  12. Jan 8, 2024 at 4:40 PM
    #942
    SAGE63
    San Diego County
    so one above Jake... lol
  13. Jan 8, 2024 at 4:41 PM
    #943
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Hey. I’m at least a power bottom.
    GODZILLA, Patch999, Mater and 4 others like this.
  14. Jan 8, 2024 at 4:43 PM
    #944
    SAGE63
    San Diego County
    Didn't you say "It's Sid he's just going to send it...." at Submarine rock.
  15. Jan 8, 2024 at 4:46 PM
    #945
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    :anonymous:
  16. Jan 8, 2024 at 5:54 PM
    #946
    Savmikey47
    Savmikey47 New Member
    Finished front camera today. No pictures. It kicked my ass routing the wire thru the firewall
    Patch999, bulldog93, Mater and 4 others like this.
  17. Jan 8, 2024 at 6:33 PM
    #947
    TaquitoBandito
    Joel (AKA Bif)
    I ripped a camera wire trying to pull it through the first time because I'm an idiot. The second time I slathered the wire in dialectic grease and it was a little bit easier. I should have consulted @Fotnot beforehand. o_O
    GODZILLA, bulldog93, Mater and 3 others like this.
  18. Jan 8, 2024 at 7:03 PM
    #948
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    Do you want a pregnant firewall? Cuz that's how you get a pregnant firewall
  19. Jan 8, 2024 at 7:08 PM
    #949
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    It’s ok, the other end was snipped.
  20. Jan 8, 2024 at 7:16 PM
    #950
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Always use a touch of water based lube when slipping a sheathed wire through a rubber opening :D
    Glide factor is top notch :thumbsup:
  21. Jan 8, 2024 at 8:18 PM
    #951
    RainMan_PNW
    RainMan_PNW [OP] "Oz" SSEM #82 RGBA #4 Unofficial Forum Treasurer Vendor?
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Beggars can’t be choosers here.
    I did just get the Sherpa-specific mounting brackets today in the mail.
  22. Jan 8, 2024 at 8:20 PM
    #952
    RainMan_PNW
    Casey
    Clark County, WA
    :monocle:
    I am curious - the instructions talk about a third wire that can run to a second switch for “dimming” but the bar only has two wires.
    Not that I think I’ll want to run less than 39,000 lumens… :rofl:
  23. Jan 8, 2024 at 8:22 PM
    #953
    RainMan_PNW
    Casey
    Clark County, WA
    Doh!
    The wire hider was in the box with the light bar.
    I’ll have to check with Sherpa about returning one of them.
    GODZILLA and TaquitoBandito like this.
  24. Jan 8, 2024 at 8:24 PM
    #954
    memario1214
    Colton
    Missoula, MT
    If you ordered and got one, keep it! Mine that I shipped to you is stuck. I’ll take it up with USPS. Lemme know if it suddenly shows though!
  25. Jan 8, 2024 at 8:25 PM
    #955
    RainMan_PNW
    Casey
    Clark County, WA
    Just spit on it
  26. Jan 8, 2024 at 8:25 PM
    #956
    RainMan_PNW
    Casey
    Clark County, WA
    Will do bud. Yes - I had shipping confirmation within 15 minutes of my order and it delivered today.
  27. Jan 8, 2024 at 8:30 PM
    #957
    Tripleconpanna
    The devil's lube... :devil:
  28. Jan 8, 2024 at 8:43 PM
    #958
    RainMan_PNW
    Casey
    Clark County, WA
    Let me get it wired up and mounted (maybe this weekend if I finally get a day to work on oil change). I’m leaning toward spot as well for the middle, but Jesus they are proud of those lenses!
    I’ve considered getting the hood “scoop” and center flat spot vinyl wrapped in matte black as well…
  29. Jan 9, 2024 at 2:10 PM
    #959
    Mfaley
    Mfaley New Member
    2015 CM SR5
    5100’s, Coachbuilder 3+ shackles, TRD pro grille on 18” Fuel Mavericks
    Where did you get the rear cigarette lighter USB?
  30. Jan 9, 2024 at 2:12 PM
    #960
    TRDFerguson
    Jake
    2018 MGM CrüeMax
