Leveling kit Suggestions
Discussion in 'Suspension' started by 2019Tundra!, Jan 7, 2024.
  1. Jan 7, 2024 at 7:54 PM
    2019Tundra!
    2019Tundra! [OP] New Member
    18 Tundra
    Need suggestions for a leveling kit. Leaning more towards struts for a 2019 Tundra SR5 4x4. Also is a diff drip necessary?
    Thanks
  2. Jan 7, 2024 at 8:00 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    No need for a diff drop
  3. Jan 8, 2024 at 7:47 AM
    Robin1
    Robin1 New Member
    2020 MGM Crewmax 1794
    6 inch Rough Country Vertex Coil Over lift, TRD Dual Exhaust, K&N CAI, Fuel Vector 18x9 +20, Falken Wildpeak AT3w 285/75r18
    It is rough ride on a leveling kit.
    Had one on my previous Tundra, ride was worse than stock.
    TBH, with these Tundras, especially if you plan to keep a long time and drive daily.....do a lift kit (4-6 in.), with coilovers in front and remote reseviors.
    Worth it.
    2019Tundra![OP] likes this.
  4. Jan 8, 2024 at 8:06 AM
    srfndoc
    srfndoc New Member
    2018 Tundra SR5 Crewmax 5.7L
    Bilstein 5100's all around, top setting up front. Nitto Grappler G2's.
    5100's all around with the front set to the top setting. Rides better than stock and levels the truck out nicely.
  5. Jan 8, 2024 at 8:10 AM
    b6graham
    b6graham New Member
    2020 Voodoo 1794 RW Wheels 315/70
    if you just want level and maybe slightly larger tires, then 5100s will give better performance for roughly the same cost as a spacer leveling kit.
    6112/5160 for some better offroad. above that Fox/King/ADS with numerous options in several price range brackets
    if you want form over function then pick a 4-6" lift, but know they're no where near necessary to fit 35s
  6. Jan 8, 2024 at 8:15 AM
    NoRcptn
    NorCal
    2017 Platinum
