  1. Jan 7, 2024 at 7:36 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    How much that cost y'all?
  2. Jan 7, 2024 at 7:39 PM
    Swalters
    Swalters Run your truck, not your mouth
    Sam
    Arizona
    "Attaque" - LT V8 4runner
    The shell is like just shy of $1900. Still cheaper than most camper shells new. I like that there is no carpet inside. I can actually still load hay in the bed with it on. Windows and mesh are fully removable, including the front one. There's pockets built inside. Less weight on the bed. It's well worth it upon first impression.
    oscardog86 likes this.
  3. Jan 7, 2024 at 8:36 PM
    Nicklovin
    Nicklovin Yap Yap
    Huntington Beach, CA
    00’ 4.7 AC 4x4 - GFC
    Whoaaaa $250 for a shell with windoors, you lucky guy. What a score, congrats!
  4. Jan 7, 2024 at 8:58 PM
    albru2
    albru2 Keep it simple stupid
    2002 Tundra Limited 4.7l 4WD AC
    @shifty`! Just the man I wanted to talk to! Did the 5574K22 clamps above work for you? I'm slangin' big, chunky, post-lift grease. Did you just re-clamp and call it good? This is just a small portion.There's.... a lot.
  5. Jan 7, 2024 at 9:08 PM
    albru2
    what a score! I'm going to try to not think about the 1$1500 I just paid for mine. Your patience paid off in the end!
  6. Jan 8, 2024 at 3:31 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    More luck than patience. Just the right place at the right time. For me, it was meant to be.
    BroHon, shifty` and 455h0le_dachshund like this.
  7. Jan 8, 2024 at 3:33 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Thank you!
  8. Jan 8, 2024 at 6:13 AM
    KingSequioa007
    KingSequioa007 Dreaming of URD S/C
    San Diego, CA
    07 Sequoia SR5
    Current mods: AFE Cold air intake, AFE TB Spacer,JBA Long tube headers, DD full cat back race exhaust, pedal commander pedal controller, URD MAF Calibrator tuned by Mike @ Autowave, DD 12 hole 320CC injectors, R9K ECU reflash,Solid Off road mounts. Future upgrades: 4.8 gears and LSD, ,long travel kit.
    BBB Industries part # 9900669 on rockauto.com and doing this because Sequoia's didn't come with a serviceable pulley and I bought the XAT light pulley kit to gain a few more free horses. So far the Alternator pulley and top idler pulley working great. The tensioner pulley did not fit.
    The Black Mamba likes this.
  9. Jan 8, 2024 at 7:10 AM
    oscardog86
    oscardog86 New Member
    Southern California
    Re-torqued my Archive Garage U Bolts after 100 and 500 mile since install. Got a little extra snugness out of them, should be good for awhile. Might do a check at each tire rotation or just use a paint pen to mark em and insure nothing is loosening up.
  10. Jan 8, 2024 at 7:12 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Yes, please! If they are different than the ones you are using on your LEER. I've thought about that style.
    2002_Tundra_AR likes this.
  11. Jan 8, 2024 at 7:39 AM
    It looks like the clamps I bought aren't available anymore. This is the closest I could find to them, as with all Chinesium on scAmazon, they are probably all the same product. At least they're the right color, the styling is the same as my current clamps: https://www.amazon.com/dp/B0785RMF1K/
    Here are the clamps I've got a 6-pack of in the basement right now, which I'll probably never use, but I paid $34 shipped for - the above ones are half that cost for 1/3 less product, which is a win all day long. https://www.amazon.com/dp/B09J8PWW33/
    I'd offer to ship you the spares I have, but you can get a new set for probably the same price it'll cost to ship these so I'm not even sure it makes sense to offer, since (if you have Prime) they'd be there faster ordering from scAmazon. But I'm open to shipping these over.
    I probably had half as much grease as you, and simply cleaned the grease, then monitored. Boot still feels like it has a good amount of grease in it and I haven't been slinging anymore. The clamps appear (to me) as if they'll work fine when I crawled under the truck to line it up. Kick me a PM, I'm happy to send a pair to you.
  12. Jan 8, 2024 at 7:43 AM
    I hadn't paid any mind to actually swapping out pulleys on everything. I mean, I know aftermarket pullies exist, and I'd swapped out a couple on my previous VWs because an old acquaintance of mine in town was machining them at the time. At the price point, I always took them as a little gimmicky.
  13. Jan 8, 2024 at 7:54 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    $250 for the top, around $100 in misc. Paint and equipment I have already from the hood and other projects. Time is money, but I won't count my labor.
    $350 is a fantastic investment in something valued way much more :thumbsup:
  14. Jan 8, 2024 at 8:11 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Why two different types of struts?
  15. Jan 8, 2024 at 8:14 AM
    2pr for windoors, 1pr for rear door, duh
  16. Jan 8, 2024 at 8:16 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I forgot he got the fabled windoors! :D
    @The Black Mamba is the front window a flip up/down or stationary? I saw it was solid.
    oscardog86 and FrenchToasty like this.
  17. Jan 8, 2024 at 8:17 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Flip down. Great thing is, I don't have a sliding back window, so it's perfect.
  18. Jan 8, 2024 at 8:22 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Dude, you got a hella score. Both the white ones I found for cheap in my area have sold recently. Both had broken or missing front windows. Part of me wishes I made a low-ball offer and fixed em. Then I see your ass make off like a bandit. I'll keep waiting and watching. In the meantime, the softopper will continue camping duties as needed.
  19. Jan 8, 2024 at 9:00 AM
    Patience, young Grasshopper.
    https://www.youtube.com/watch?v=YzaWAEhFWpw
  20. Jan 8, 2024 at 9:17 AM
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 DC SR5 Tundra TRD Off Road
    Starting the new job I discussed a few months back, and I get to keep my Tundra. It will not be put up for sale. I negotiated the use of a company truck for my new role instead of reimbursement.
    Now, for the Tundra.... planning on a 4.30:1 re-gear, engine management, and cams this year. And a few years down the line; built bottom end and a supercharger.
  21. Jan 8, 2024 at 9:18 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    So here's the fun part, as soon as @shifty` found his, all of the sudden they started popping up all over Jawja (JA). Texas in Nextas.
  22. Jan 8, 2024 at 9:22 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Keep us posted on the cams
    BroHon likes this.
  23. Jan 8, 2024 at 10:34 AM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    Yeah, another day to add to the tally. :thumbsup:
  24. Jan 8, 2024 at 10:41 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Historically, it takes 28 days to form a habit. Let's see what happens on Jan, 28.
  25. Jan 8, 2024 at 11:33 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Whelp @shifty` add another what, $70 to the total? The pic almost looks like it wants to do a Kitt thing
  26. Jan 8, 2024 at 12:52 PM
    $30-50 is the norm on that one. Be careful which one you get, there's a few kinds.
    Usually they're adhesive'd in on Leers. Maybe same on SnugTop, maybe @FrenchToasty can confirm. If I were you, I'd pop that joker out and get the part number off the back of it, and also take a pic of the shape. Then start your hunt with the part number first, and use the shape to confirm.
  27. Jan 8, 2024 at 1:59 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L AC Limited 55k mi
    Call Camper Corrall (there's one in Dallas and one in Funky Town), they are a SnugTop dealer. Send them your camper's serial number and ask them to see if they have a replacement for that light. I had great luck with my Leer/SnugTop dealer down thisaways.
  28. Jan 8, 2024 at 2:02 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    Godspeed you! "Behind every desire is another one, waiting to be liberated, when the first one's sated." Video filmed somewhere in Texas, I want to say Austin or Dallas?
  29. Jan 8, 2024 at 2:03 PM
    Riverdale21
    OTP ATL
    Been looking to our Aussie brothers for the next stages. Kelford 251/251 for cams and Xat for the supercharger. Still hunting an engine management, which will come first after re-gear. May have to go piggy-back until the truck is emissions exempt.
    Looking at Orange Virus for ECM but unsure about management accuracy or ability to get it tuned.
    Would like to go UCON-EMS but they've been out of stock at URD for a hot minute.
  30. Jan 8, 2024 at 2:07 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I'd love to hear what your engine sounds like when you're done.
    So you planning on doing a procharger or what?
