Markings on radiator
Discussion in '1st Gen Tundras (2000-2006)' started by Dirt Ferguson, Jan 5, 2024.
  1. Jan 5, 2024 at 4:51 PM
    Dirt Ferguson
    Dirt Ferguson [OP] New Member
    Daniel
    Northern California
    04 SR5 AC 4X4 V8
    What would cause these reddish-orange markings? Dealer said it's not rust or corrosion.
  2. Jan 5, 2024 at 5:41 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    That's a plastic tank so it must be plastic degradation. I'd say get that thing out of there and replace it with a denso from rockauto before you get pink milkshake.
  3. Jan 5, 2024 at 5:43 PM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    Psychodelic coolant? :notsure: You should ask around in the 3rd Gen forums. Maybe someone has a similar issue.
  4. Jan 5, 2024 at 5:44 PM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    Already on a 2023?
  5. Jan 5, 2024 at 5:47 PM
    NickB_01TRD
    KY
    I see now that it says he has a 2023 but that engine bay is definitely 1st gen
    Elevatorguy likes this.
  6. Jan 5, 2024 at 6:10 PM
    bfunke
    bfunke Tundra Curmudgeon
    On a FGT, that’s an ominous sign of impending radiator or trans cooler failure. Buy a new rad ASAP. Only use Denso which is the OEM supplier. Rock Auto sells them.
  7. Jan 5, 2024 at 6:10 PM
    Nick is right. Your radiator needs to be replaced.
  8. Jan 5, 2024 at 7:22 PM
    Dirt Ferguson
    Daniel
    Northern California
    04 SR5 AC 4X4 V8
    My bad, everyone, I forgot to include that this is on an 04 DC 4X4
    ATBAV8 likes this.
  9. Jan 5, 2024 at 7:25 PM
    I had a friend who had a paint job like that on his '71 Cutlass.
    JakeJake likes this.
  10. Jan 5, 2024 at 7:27 PM
    scooterprint
    scooterprint Idiot with a wrench
    Jeremy
    Conway, AR
    ‘04 DC 4x4
    Yikes. Time for a new radiator. I just replaced the radiator in my 04 about a year ago after it started turning brown. Denso from rockauto.
    BroHon and Dirt Ferguson[OP] like this.
  11. Jan 5, 2024 at 7:28 PM
    Dirt Ferguson
    Daniel
    Northern California
    04 SR5 AC 4X4 V8
    kind of has a trout skin look.
    BroHon, Xcumminsguy and JakeJake like this.
  12. Jan 5, 2024 at 8:05 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Looks to me like a chemical reaction with the plastic, have you cleaned under there with anything lately? :notsure:
  13. Jan 5, 2024 at 8:09 PM
    Dirt Ferguson
    Daniel
    Northern California
    04 SR5 AC 4X4 V8
    Sorry, I left out a bunch of important info on this thread.
    This is a truck I am considering buying. It was just detailed.
    I'm used to seeing plastic parts fade to tan when they wear out, like the heater control valve. But this is something new to me. The guy I spoke with at the dealership said it was a chemical reaction, but I was dubious.
    Leo's first and w666 like this.
  14. Jan 5, 2024 at 8:18 PM
    New Denso radiator is less than $200. I e seen em as low as $120. Not sure why you wouldn’t just replace the f’n thing for crying out loud.
    Dirt Ferguson[OP] likes this.
  15. Jan 5, 2024 at 8:30 PM
    TILLY
    Massachusetts
    How is the radiator compromised over some surface discoloration?
  16. Jan 6, 2024 at 2:14 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    From a dealership?!
    1. <sigh>, often the least knowledgeable about their own products
    2. Fine...make your offer (after you check the other fluids) contingent upon their replacing it with OEM or Denso
  17. Jan 6, 2024 at 2:44 AM
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    James
    05 DC, 4.7, 4wd, LSD.
    First gen police were on it lol. Clearly not a 2023 engine bay lol.
  18. Jan 6, 2024 at 6:09 AM
    I could actually believe the chemical reaction story after looking at the picture again but I also believe it's likely the original 15-20 year old radiator so it should be replaced either way. First gens are extremely reliable but they need maintenance due to age.
  19. Jan 6, 2024 at 6:44 AM
    Dirt Ferguson
    Daniel
    Northern California
    04 SR5 AC 4X4 V8
    I've bought 6 different Toyota trucks from dealers and private sellers over the years and the experience I am having with this crew is no-nonsense and transparent.
    They were unclear about the timing belt and water pump and offered to replace it, on their dime, with an OEM kit.
    BroHon and Leo's first like this.
  20. Jan 6, 2024 at 7:33 AM
    1st gen radiators have a penchant for discoloring (marbling/patching in tannish brown, not necessarily speckling, though both are visible here) on the top plastic as they age.
    Transmission line runs through the radiator on 1st gens, and the older designs corrode where the transmission line enters the radiator, allowing cooland and transmission fluid to mix ("pink milkshake").
    The smart thing to do here is spend $120-150 to buy a new Denso radiator to save you from what will ultimately lead most people to a $3,000+ transmission replacement.
  21. Jan 6, 2024 at 5:28 PM
    Dirt Ferguson
    Daniel
    Northern California
    04 SR5 AC 4X4 V8
    and that is the plan on my end.
  22. Apr 30, 2024 at 8:43 PM
    TacticalAnt
    TacticalAnt New Member
    2006 Tundra DC
    So all 1st gens have transmission cooler built into radiator? Not just the ones with the factory tow package?
  23. May 1, 2024 at 4:10 AM
    It’s a thing for tow pkg and non tow pkg trucks. If you need to confirm, look at the bottom of the radiator for a small hose going in on one side and out the other. But given there are only a couple part numbers, and those part numbers have entry/exit bibs, ….
  24. May 1, 2024 at 6:57 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    leopard print?
  25. May 1, 2024 at 7:05 AM
    Think bowling ball style (see video if you're not familiar), but with spots. With bowling ball, all the shops I knew would lay cling wrap or similar on wet paint to create the effect, peel it, repeat for desired look, then wetsand smooth and multiple coats of clear. I don't know how the shop got his effect. It's almost like they seeded the wet paint so it created round voids, and cleared over it. It looked very similar to that radiator.
    FishNinja[QUOTED] likes this.
  26. May 1, 2024 at 8:41 AM
    TacticalAnt
    2006 Tundra DC
    Yes, i have the trans cooler and tow package, just didnt want to inadvertently order one without trans cooler if they existed.
