Loud snapping sound coming from the passenger side tire area
Discussion in '1st Gen Tundras (2000-2006)' started by Hairfarm, Nov 5, 2022.
  1. Nov 8, 2022 at 7:39 PM
    #61
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    I had Moog lowers in mine. Threw them out when the recall notice was released and replaced with OEM 'Yota lowers.
    shifty` likes this.
  2. Nov 9, 2022 at 11:10 AM
    #62
    Hairfarm
    Hairfarm [OP] New Member
    This seems to be the consensus. I will probably replace the LBJ with OEM.
    I took the wheel off to get a better look, checked the sway bar linkage, all relevant bolts for tightness, did another test with crowbar and LBJ, checked brakes and rotor etc. Didn't find anything:
    https://www.youtube.com/watch?v=7HJ33PJTxso
    I think someone here recommended I take the brakes and rotor off and inspect the hub area. Any good videos on removing the brake and rotor and not damaging the metal brake line?
  3. Nov 9, 2022 at 11:31 AM
    #63
    Aerindel
    Aerindel New Member
    Montana
    You don't have to remove the brake lines to remove the caliper, just leave it connected.
  4. Nov 9, 2022 at 12:05 PM
    #64
    artsr2002
    'Yonder
    Sue does a good job of replacing the bearing which shows you how to remove the entire knuckle. Here you go.
    https://youtu.be/_Yy9-VLahbA
    abcinv and richsadams like this.
  5. Nov 9, 2022 at 6:36 PM
    #65
    richsadams
    richsadams New Member
    Northwest
    2000 SR5 AC 4x4 4.7L
    The LBJs on our '00 looked fine, but after reading up on LBJ failures here and elsewhere, plus encouragement from the experts here, I went ahead and replaced ours with Toyota OEMs and ARP hardened bolts and washers. Peace of mind. More here:
    Lower ball joints/part numbers
  6. Nov 11, 2022 at 9:05 AM
    #66
    Hairfarm
    Update:
    Things I am beginning to notice about the snapping/knocking sound.
    1. Only after the vehicle warms up will it start to make the snapping/knocking sound on the right side near wheel. Once I park it overnight and drive it again on the morning the sound will not happen when the truck is cold until it warms up again.
    2. If I drive at low speed, like 15mph, ansd tap the brakes it is louder and more constant.
    3. When I lightly tap the brakes at low speed I can get it to recreate the noise now. But only after the car has been warmed up and driven for about 20 minutes.
    I tried making some video but it doesn’t convey the severity of the noise.
    The "good" news is that its becoming more prevalent and constant now. I wish it would just break outright during my low speed tests so I can see it then fix it.
    Anyone have a brake that made a knocking/snapping/clunking sound? It only happens now after it has been warmed up. My theory is that if it only happens when the truck is warm then it points to a component that get hot: Brakes and rotor mostly. Shocks, ball joints, sway bars/link, control arms, don't really get hot. And since the sound is only happening when the truck is hot and driven then that point to brakes and rotor.
    So, if it only happens when the truck has been driven for awhile and when I apply the brakes then I’m thinking I need to pull the rotor and brake assembly and see if there is damaged in that area as well(?) Can brakes get so grabby that they grip too hard?
    It’s going back in the shop on Monday.
    Btw, I have a large empty parking lot nearby that I use to test on so I'm not risking anyone's safety.
    thanks,
  7. Nov 11, 2022 at 9:11 AM
    #67
    It could be the lower BJ castle nut isn’t torqued properly, you’d need to remove the cotter pin to check. I watched your pry bar video on the LBJ and didn’t see any big movement
  8. Nov 11, 2022 at 10:11 AM
    #68
    That's a super astute, but very bizarre observation. Heat playing a factor, I'd be tempted to pop the wheel off while things are hot, toss a couple of extra jackstands under just in case, engine running, and have someone tap the brakes on and off and swing the steering wheel while you jiggle stuff. But I'm also totally crazy, so I would do something this stupid.
    richsadams likes this.
  9. Nov 11, 2022 at 12:59 PM
    #69
    Hairfarm
    I too would be stupid enough to try something like that. That's actually not a bad idea. I think I have an extra set of jack stands and it might give me just enough information to move forward. Obviously I wouldn't get under the truck or in front of it. But with the wheels removed I might be able to see something happening from a few feet away. It's times like this I wish I had a lift.
    Thanks!
    shifty`[QUOTED] and richsadams like this.
  10. Nov 12, 2022 at 4:37 AM
    #70
    The only thing I had that sounded remotely similar was a loose exhaust manifold heat shield. Once I removed it, the noise was gone.
    w666 likes this.
  11. Nov 12, 2022 at 5:56 PM
    #71
    artsr2002
    'Yonder
    The mystery continues.
  12. Nov 13, 2022 at 9:43 AM
    #72
    Hairfarm
    Indeed. I need this mystery like a hole in the head...
    dbittle and shifty` like this.
  13. Nov 13, 2022 at 8:40 PM
    #73
    artsr2002
    'Yonder
    Have you popped off the brake assembly and rotor to check those 4 bolts that hold the dust/brake shield to the knuckle? When you do, give those slide pins in the brake assembly a good clean and some grease since you are there already.
  14. Nov 14, 2022 at 10:12 AM
    #74
    Hairfarm
    Will do. I'm going to have some time so this tomorrow and will update.
    thanks!
  15. Dec 23, 2023 at 8:31 AM
    #75
    tunder construction
    tunder construction New Member
    Cody
    Calgary Alberta.
    2001 tundra trd
    Old man emu suspension. 33” tires.
    So what was it?!
  16. Dec 23, 2023 at 8:43 AM
    #76
    Sounds like a lower balljoint to me but this user hasn’t signed on again in over a year so they’re not gonna tell you, I bet.
    And lower ballpoint is one of those parts where you MUST use OEM, or regret it later. This is a very well known issue, Moog and Napa have had recalls, Toyota had recalls, and OEM are the only ones made stout enough. And when they fail, it’s often catastrophic.
    Have you done a basic push/pull test for balljoint/tie rods/wheel bearings?
  17. Dec 24, 2023 at 8:33 AM
    #77
    tunder construction
    Cody
    Calgary Alberta.
    2001 tundra trd
    Haha, yeah I found out about the lower ball joint issue the hard way when the driver side failed on me going 75mph. I’ve replaced the lbj’s with Toyota ones, no sway bar, new upper control arms, new lower control arm bushings, new tie rod ends, steering rack, coil overs (old man emu 3 inch lift), axels, diff drop, all new brakes.
  18. Dec 24, 2023 at 8:41 AM
    #78
    And you have an access cab? That OME lift wasn’t designed for our access cab trucks. Look no further than this guy for proof: https://www.tundras.com/threads/ome-3-1-kit-goes-full-extension-with-a-bang-too-fast-why.109151/
    Reg and acc cab trucks aren’t engineered the same as the double cab and Sequoia, suspension wise. OME kits aren’t made for our trucks as it is, they’re made for 4Runners or Tacos, and considered “potentially compatible” by some sources. They translate pretty well to the double cabs and Sequoia. It doesn’t translate to the reg and acc cab Tundras. You’ll get too much lift and bad shit happens.
  19. Dec 24, 2023 at 8:44 AM
    #79
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    If you had a Ouija board he could tell you.
    OP kept performing diagnostics in the form of driving around, after @Spraynard said to knock that sh*t off, and ended up loosing control of his truck... veered off the road, took out 16 mailboxes, and plummeted off a cliff.
    Recovery efforts of OP's corpse yielded a light snapping sound: his nipple was caught in the seatbelt.
  20. Dec 24, 2023 at 1:34 PM
    #80
    tunder construction
    Cody
    Calgary Alberta.
    2001 tundra trd
    Well if that’s the case I guess I’ll just live with it for a while. Mines not as extreme as that guys sounded. Kinda just makes a bit of noise while turning and going over bumps.
  21. Dec 24, 2023 at 2:19 PM
    #81
    Hopefully doesn't damage anything else, I guess :D
    Have you checked for grease sling? Is it possible you slung all the grease out of your CVs from lifting so tall, and now your CVs are failing from running dry? Or maybe the CVs are binding due to excess lift?
    Did you take before/after measures to confirm how much lift you got? I've only got 2" lift based on before/after measures and I was slinging grease from the CV inner boot, at the large clamp neearest the diff. Ultimately will need to apply more grease.
    Seems like people have the most problems when they exceed 2.5" lift.
    Push/pull test done on each side to verify the joints? LCA bushings OK?
  22. Jan 5, 2024 at 5:52 AM
    #82
    tunder construction
    Cody
    Calgary Alberta.
    2001 tundra trd
    No grease loss so far, it does have a diff drop installed, no idea if that has any real affect. Cv’s are both pretty new. I didn’t take any measurements but it now looks like it has settled a bit. All bushings are brand new, lbj’s are brand new Toyota ones. I’ve pushed and pulled on everything I can put my hands on but of course I can’t simulate thousands of pounds rocking around. Next I think I’m gonna look at all the body mounts. Maybe they’re just clunking around.
  23. Jan 5, 2024 at 9:11 AM
    #83
    That's a common one, especially the rear cab mounts.
    Best bet is to do what I did: Rock the truck, or work with someoen to rock the truck. Like, you get under the truck and ...
    If you still have the OEM nerf bars/side steps installed, have them stand on a step and rock the truck. If not, have them open the driver's door, stand on the door sill, and hop up and down to make the truck rock back/forth while you listen where the sound is coming from.
    Have them move to the rear bumper, on passenger side, then driver side and repeat that hopping while you listen. You can also put your body under the spare tire, with your head under the driver tire. Tuck your knees up under the spare tire and push up/down on the truck at the spare tire with your knees to listen for noise arount the axle/leaf springs. Repeat on the driver's side. You can also bench-press the spring at the cup under the rear shackle on each side.
    One of these should help you track down at least the vicinity of the noises.
    You may also want to jack up the truck at the center and lay under it while someone else steers lock-to-lock (with engine running) to listen for noise. While it's in the air, I'd take the OEM bottle jack under one of the LCAs to jack it up, then repeat with the wheel roughly at ride height.
    I suspect you're lifted more than you should be, and you'll find you're actually making early contact somewhere, metal-to-metal, or your CV axles can't handle the higher-than-normal lift.
    Or something is bottoming out, swaybar links or something else.
    Hopefully it's not looming LBJ failure.
