What have you done to your 3rd Gen Sequoia today?
Discussion in 'Sequoia 3rd Gen (2023+)' started by Bob, Nov 30, 2023.
  1. Nov 30, 2023 at 12:40 AM
    Bob
    Bob [OP] Member Staff Member
    Bob
    07 Tacoma PreRunner Black
    Post your latest mods, maintenance and updates for your 3rd gen Sequoia...
    TK1979, T-Rex266, Terndrerrr and 2 others like this.
  2. Jan 4, 2024 at 10:43 PM
    rohit_trd
    rohit_trd New Member
    2023 Toyota Sequoia HV SR5 4WD with TRD Off-Road
    Got the following TRD pro mods installed on 2023 Sequoia SR5:
    - TRD Pro Front Grille (with Light Bar and 3 Marker Lights)
    - TRD Pro camo pattern fender flares (with marker lights) for the 4 wheels
    - TRD Pro Skid Plate with red TRD lettering (not clearly visible in these photos)
    - aFe Front Tow Hooks (red) - this is aftermarket part (not TRD Pro)
    - Removed the air dam (valance) from the front of the vehicle.
    Before mod:
  3. Jan 27, 2024 at 6:37 AM
    TK1979
    TK1979 New Member
    TK
    Youngsville, NC
    2018 DC Limited
    Dual Exhaust and Side Steps
    Looking good!
    rohit_trd[QUOTED] and Bob[OP] like this.
  4. Mar 31, 2024 at 5:18 PM
    GingerGremlin84
    GingerGremlin84 New Member
    2021 Black TRD PRO
  5. Apr 5, 2024 at 6:17 PM
    turbo8
    turbo8 New Member
    Well, I wasn't going to modify this but got a flat tire, which destroyed the crappy stock tire. Put on BFG KO2 295/70r18 (34.5") tires. No rubbing so far.
    Now I need to raise the front up a couple inches to get ride of the rake.
    PSA:
    I put one of the stock AT tires on the steel spare wheel which should be around 33" in diameter. With the tire pushed all the way to the rear most crossmember there was only 1/2" between the tire and the panhandle bar. So Sequoia owners can't run any larger tires in the spare location.
    The way Toyota wants you to operate the spare tire hoist has changed, and really sucks. The hook tool that was used for the jack is now used for the spare hoist too. It constantly slips out and binds up on things it also hooks itself on the guide sleeve when trying to remove.
    MAC25Tundra, mrainv23 and 3d_pilot like this.
  6. Apr 5, 2024 at 6:36 PM
    18" TRD Off Road Wheels
    If you ever plan to tow anything or just load stuff in the back then I'd recommend keeping the rake. It's a functional thing. If you never carry passengers or gear, go for bad.
    That thing looks great with the beefed up tires!
    turbo8 likes this.
  7. Apr 5, 2024 at 6:45 PM
    turbo8
    turbo8 New Member
    Yeah, I'm not towing or loading it up with anything substantial. This is just a daily driver/ski vehicle.
  8. May 8, 2024 at 7:03 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    They do look good at least.
  9. Aug 3, 2024 at 2:01 PM
    mrainv23
    mrainv23 New Member
    2024 Trd Pro
    Have you experienced any rubbing now that time has gone by? Thx
  10. Aug 3, 2024 at 2:33 PM
    turbo8
    turbo8 New Member
    Yes, there was a slight rub at full lock and hitting a bump on the mud flaps. I removed the mud flaps and no more rubbing.
    mrainv23[QUOTED] likes this.
  11. Aug 4, 2024 at 6:20 PM
    turbo8
    turbo8 New Member
    Added some OEM 200 series 10mm thick spacers to the top of the front shocks. I wanted to see how much they increased the ride height, which was around 1-1.25".
    I need to take the springs off the shocks and cycle the suspension to make sure the shocks are not bottoming out before full bottom out on the frame mounted bumps.
    After
    War Machine likes this.
  12. Aug 13, 2024 at 1:20 PM
    oddhours
    oddhours AS IS
    Barry
    Georgia
    24 SR5
  13. Aug 31, 2024 at 11:28 AM
    kana6207
    kana6207 New Member
    2024 sequoia capstone
    Icon stage 3 lift, icon wheels wrapped in 35” Toyo open country rt tires. TRD pro conversion grill, Prinsu roof rack with 50” KC Hilights gravity pro6 light bar, and Baja designs ditch lights. And NYTOP gloss carbon fender flares.
    IMG_1173.jpg IMG_1168.jpg IMG_1166.jpg IMG_1170.jpg IMG_1169.jpg Stage 1 build done. 2024 sequoia Capstone with Icon stage 3 lift, Icon rebound pro wheels with Toyo open country M/T 35x12.50 tires. NYTOP carbon fiber fender flares, TRD Pro conversion front grill. Prinsu roof rack with KC Hilights gravity pro 6 light bar, Baja designs squadron pro ditch lights.
    Now time to start stage 2!
  14. Oct 4, 2024 at 10:23 AM
    rezapp
    rezapp New Member
    ‘23 Sequoia Limited w/ Off Road Pkg
    Been looking to make the same grille upgrade to the pro. Where did you happen to get the Pro Grille w/lightbar? Did you install it yourself or take it to a dealership perhaps?
  15. Oct 20, 2024 at 9:31 PM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    '21 Cavalry TRD Sport CM Tundra & 25 TRD Pro Sequoia
    Drove to get some donuts
    Lateralus and SoCal_Erik like this.
  16. Oct 20, 2024 at 10:37 PM
    SoCal_Erik
    SoCal_Erik New Member
    2023 SR5 Sport 4x4
    the white looks purdy!
    Toe404[QUOTED] likes this.
  17. Oct 30, 2024 at 3:20 PM
    Rad Sequoia
    Rad Sequoia New Member
    Patrick
    Wescott lift 35 Toyo ATIII’s SCS F5 wheels
    Ripped her around in the dirt and mud
  18. Nov 24, 2024 at 10:05 PM
    MtnCrewmax
    MtnCrewmax New Member
    08 Crewmax TRD, 25 Sequoia Platinum
    Subd .. I'm torn between keeping the new 25 pretty much stock and hopefully never needing anything done, and modding it and making it mine but probably going to end up needing more to maintain in the end...
  19. Nov 26, 2024 at 3:48 PM
    JooolesM
    JooolesM New Member
    Julie
    03063
    2024 Toyota Sequoia
    Removed third row seating, installed base deck.
    Goodbye third row, hello "queen bed."
    MtnCrewmax likes this.
  20. Nov 26, 2024 at 5:29 PM
    manofsteele2003
    manofsteele2003 New Member
    24 Sequoia TRD Pro, 03 Tundra Limited 4WD
    Westcott designs 3"/1" lift 295/70/18 Falken Wildpeak RTs Canvasback cargo liner aFe Tow hooks
    Finally got my Westcott's lift in, also upgraded to 295/70/18s, completely changes the look. Should have came this way from the factory. PXL_20240816_213416061.jpg PXL_20241030_211519678.jpg
    MAC25Tundra likes this.
  21. Dec 6, 2024 at 9:07 AM
    Runn4est
    Runn4est New Member
    2023 TRD off-road. No lift with 35x12.50s and Fuel 18x9 20mm rims. Prinsu rack. Black valence conversions. I also added lights in the trunk.
    DrtyQuoia47 and MAC25Tundra like this.
  22. Dec 6, 2024 at 9:25 AM
    JooolesM
    JooolesM New Member
    Julie
    03063
    2024 Toyota Sequoia
    How did you do the back lighting? Photo? Thanks ...
  23. Dec 6, 2024 at 10:47 AM
    Runn4est
    Runn4est New Member
    LED lights wired off the trunk light wiring, so they shut on and off with them. Only downside is that I can't keep them on past the point when power cuts off to the trunk. I could easily tap into the battery for that, but haven't yet.
  24. Dec 6, 2024 at 10:51 AM
    JooolesM
    JooolesM New Member
    Julie
    03063
    2024 Toyota Sequoia
    They look nice -- where did you get them? The whole back end of the vehicle is ridiculously dark! Did you do the install yourself?
  25. Dec 6, 2024 at 11:51 AM
    Runn4est
    Runn4est New Member
    Thank you, yes I did it myself. Popped the trunk trim and ran it through the rubber grommet, so you cannot see any wires. The LEDs are just the cheap 12v eagle eyes on Amazon.
    It's a huge difference in lighting for sure!
  26. Dec 12, 2024 at 10:35 PM
    4Z2
    4Z2 New Member
    No rubbing?
  27. Dec 13, 2024 at 8:26 AM
    Runn4est
    Runn4est New Member
    I had to trim the inner edges of the fender flares and remove the bracket behind the lining (just a bolt on) and the mud flaps. The only time I rub, is just slightly at full compression high speed dips or bumps. I plan on adding durobumps which should give me 1/2 inch taller stop, and eliminate the rub.
  28. Jan 18, 2025 at 6:59 PM
    kylant
    kylant New Member
    were the grille lights plug and play?
    do you happen to have part numbers for the lights and grille?
    thanks
  29. Feb 20, 2025 at 12:39 AM
    rohit_trd
    1. 3rd Gen Sequoia TRD Pro Front Grill Insert - 53114-0C530 (Install video for 3rd party grille is YouTube video refference G5EGf1W67E8 - However, the steps for OEM grill are very similar.)
    2. TRD Pro - 3 Marker Lights Front - PT358-34220-AB
    3. Wire Harness for Sequoia TRD Pro OEM Marker Lights - https://raveoffroad.com/products/wi...-pro-oem-marker-lights?variant=40090326269987 (This link also has the install instructions for the marker lights.)
    4. Front camera bracket - https://westcottdesigns.net/product/2022-toyota-tundra-sequoia-front-camera-relocation-bracket/ (This bracket allows you to transfer the front-facing camera on a non-TRD Pro trim when installing the OEM TRD Pro Grille Insert.)
    5. TRD Pro - Front Light Bar - PT358-34220-LB (You can find used OEM Light Bars a lot cheaper on ebay).
    Steps to power the OEM Light Bar - https://www.tundras.com/threads/grille-interchangeable.100356/page-8#post-2790295. Alternatively, you can go for a third-party light bar (example: Diode Dynamics / Heretic / Baja Designs / Rave)
    6. Light Bar Dash switch - PT45A-34220-AA (see this thread for wiring the Light bar switch - https://www.tundras.com/threads/trd-pro-light-bar-switch-p-n.116422/)
  30. Mar 1, 2025 at 10:11 PM
    TechSeq
    TechSeq New Member
    San Diego, CA
    2024 Sequoia SR5 TRD Sport
    Suspension: King 2.5 Performance Series Kit w/Remote Reservoirs Wheels: Method 312 Tires: Falken WildPeak AT4 TRD Pro Fender Flares TRD Skid Plate TRD Pro Heritage Grille AFE Tow Hooks Talons Garage Catalytic Converter Shield
    IMG_1056.jpg IMG_0833.jpg Added my Diode light bar. This kit came with its own switch that allows you to turn them on independently without your high beams having to be on. Very happy with these as they are super bright.
