GEN 3 (2022+) Wheels and Tires Photo thread
Discussion in 'Wheels & Tires' started by Tsquare, Jan 16, 2022.
  1. Jan 2, 2024 at 4:53 PM
    #4201
    Magnetic1
    Magnetic1 New Member
    Looks great, I am going to do the same with my Magnetic 1794, however I may go with a 295 series tire. How is the ride compared to stock, have you thought about adding a hub centric wheel spacer to bring them out a bit?
  2. Jan 2, 2024 at 5:24 PM
    #4202
    Magnetic1
    Looks sick!
    CYBERO24[QUOTED] likes this.
  3. Jan 2, 2024 at 6:06 PM
    #4203
    jayluv76
    jayluv76 New Member
    2022 1794 Edition
    ReadyLift 2” Mickey Thompson 275/65/r20
    If I had to do it again I’d go with a 295/60 on the stock wheel. It is annoying that my mph is so off now. That said, the ride is great and for me, better than stock by far. I choose the 275 in the hopes of keeping things close to factory (like mph, mpg, ride etc). But, the 295s wouldn’t be any different as it turns out. I still love the truck though.
    As for the spacers, I just came from a 6” lifted Chevy on 35/12.5 on a 20x10 +18 so I had no desire to have that much poke again. :)
  4. Jan 2, 2024 at 6:15 PM
    #4204
    abgiles
    abgiles New Member
    2022 CrewMax Limited - Wind Chill Pearl
    TRD Grille w/Rough Country LED, Tuffskinz products,
    From a tire size comparison calculation, if your originals were the same as mine (265/60/20), you'd be off 3.4mph @ 70mph. With the 295/65/20, you'd be off 5.6mph @ 70mph true speed.
    I got the same size (275/65/20) in the Recon Grapplers, but my speed just seems to be off 2mph per two different GPS apps.
  5. Jan 2, 2024 at 6:18 PM
    #4205
    jayluv76
    jayluv76 New Member
    2022 1794 Edition
    I didn’t know if I could really trust the apps I used. One said 10mph and I deleted the app. The other is 3-5 depending on speed. What app do you use?
    Edit: What I meant by not much different was mph difference between 275/65 and 295/60. Not much difference there.
  6. Jan 3, 2024 at 3:01 AM
    #4206
    abgiles
    abgiles New Member
    I just have a couple of basic GPS apps. They both just say GPS on the app name. Haven't really looked that closely at them.
    jayluv76[QUOTED] likes this.
  7. Jan 3, 2024 at 4:29 AM
    #4207
    Shep1824
    Shep1824 New Member
    Justin
    2023 Tundra Limited Hybrid
    Not really sure how accurate it is but my phone GPS shows 2-3 MPH faster than speedo.
  8. Jan 3, 2024 at 6:10 AM
    #4208
    kirkb
    kirkb Lurking Member
    DFW
    2024 Tundra Limited 4x4 WCP Nightshade
    You can use the Tire Size web page to compare. It shows the MPH diff between two tires.
  9. Jan 3, 2024 at 6:33 AM
    #4209
    jayluv76
    jayluv76 New Member
    2022 1794 Edition
    I used the one over at tacomaworld but I like this one better. I was aware of the faster than reported speedo but before I had the new tires put on, factory was running slower than what was shown so it took me by surprise at just how off my speed was. I blame the app I was using.
  10. Jan 3, 2024 at 7:22 AM
    #4210
    superdude
    superdude New Member
    2022 Tundra Platinum
    This looks amazing. I'm currently finalizing my decision on a similar set up (Method 703's, still deciding on tires between Falken AT3W or Toyo AT3). Is this lifted or leveled at all?
    Thanks,
    bigbear503 likes this.
  11. Jan 3, 2024 at 6:07 PM
    #4211
    tundraty
    tundraty New Member
    Fort Worth, TX
    2022 Celestial Silver SR5 CM 4x4 TSS Off-Road
    Just got Toyo Open Country AT III installed
    Completely stock SR5 with the TSS Off Road package. I went with LT275/65R20. Love the tires so far.
    Lebo, mayan, TN_Tundra_24 and 7 others like this.
  12. Jan 4, 2024 at 5:31 AM
    #4212
    Rampking01
    Rampking01 New Member
    I seen this at the dealership the other day. I thought it looked good.
    jayluv76 likes this.
  13. Jan 4, 2024 at 6:24 AM
    #4213
    NinjahGoose
    NinjahGoose New Member
    2024 Sequoia
    I have a 2024 Sequoia Limited (non-TRD) I purchased about a month ago. Have no plans to lift or level the truck since I tow our 21' Bay Boat regularly.
    I'm thinking about Method 703 17" +35 wheels with either the classic 285/70r17 or 285/75r17, both in C load. Does anyone have a stock Tundra or Sequoia with either those sizes? The 285/75's are 4lb's lighter and a full inch larger diameter, would be great if they fit without any rubbing.
    superdude likes this.
  14. Jan 4, 2024 at 6:36 AM
    #4214
    Tom
    Tom New Member
    I had 285/70/17 +35 on my Tundra and had no rubbing problems.
    Got them for sale 1,200 pick up houston.
    NinjahGoose[QUOTED] likes this.
  15. Jan 4, 2024 at 6:39 AM
    #4215
    NinjahGoose
    2024 Sequoia
    Thanks! I will probably end up going this same way to save some money but would still like to see a 285/75 if anyone has them.
    SiXGUN likes this.
  16. Jan 4, 2024 at 9:10 AM
    #4216
    SiXGUN
    SiXGUN New Member
    Eddy
    2022 Tundra SR5 6.5 Bed
    This thread has been super helpful in my decision making with tires and rims. Thank you everyone for posting and sharing!
    My setup:
    - Method +35 backspacing (Very little poke...which I prefer)
    - 285/75R17 BFG AT's Load range E
    - Stock Suspension - No lift at this time
    - 17 wheels cleared but be careful on where the wheel weights are mounted. I ordered this package online and had two wheel weights that interfered with the calipers on the front.
    No rubbing at all. Did pin back the liner, but added Amazon mud flaps after the tire and wheel install. Have not had it offroad yet though
    Note that in CO the slush/snow builds up in the wheelwell I do get some rubbing on the frozen ice buildup.
    Have the Wescott lift in the garage and plan to install the preload collar and no top plate in the future
    Azrsx, Hank Hill, 4lo Toys and 9 others like this.
  17. Jan 4, 2024 at 10:19 AM
    #4217
    superdude
    this is what I wanted to see, 285/75R17 with no lift or leveling.
    Looks great!
    SiXGUN likes this.
  18. Jan 5, 2024 at 5:19 AM
    #4218
    BeastOfBourbon7
    BeastOfBourbon7 New Member
    2022 Grey SR5 TRD Sport
    Apologies up front if these questions have been asked. I have the Rough Country leveling kit on mine and am looking at getting the biggest tire possible without rub, but I have been leaning towards 275/60/20. I'm just curious what that would be?
    The second question is I have is that I am looking at the Cooper Discoverer AT3 XLT, but was told they're being phased out for the Discoverer Road+Trail AT. Has anyone had any experience with them yet? They look like a good tire and am looking to get it done next week.
  19. Jan 5, 2024 at 6:08 AM
    #4219
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    I have a 2022 with 1.75 RC leveling. I have just recently installed Cooper AT3 XLT in 275/65/20, so one size up in sidewall than what you are looking at. I have had the AT3 XLTs on my previous Tundra and was very happy with them. I got 78,000 miles out of a set and they were not very noisy and performed great on road and off road. They are obviously a bit harder ride than the OEM P-rated tires, but that is a given when you go to LT tires; nothing uncomfortable or annoying; just slightly noticeable on your first ride out of the tire shop, and then you get used to it.
    I don't have any rubbing. I do have 1.75" wheel spacers though, but if anything, those almost cause rubbing on the outside scrub against the mud flaps.
    From what I understand, the AT3 is not being replaced by the Road & Trail but the R&T is being added to the line-up, but I am not sure about that.
    I do have to mention that I lost about 2MPG with the bigger, much heavier tires.
    Lebo and BeastOfBourbon7[QUOTED] like this.
  20. Jan 5, 2024 at 6:19 AM
    #4220
    BeastOfBourbon7
    Thanks for the response! Yeah, it seems like we have very similar set ups then. The place I went to had told me the AT3s were being, "phased out" which could just mean he was trying to push the new tire, who knows. I am going to call around to some other local places and get some more information. I definitely like the size and look on yours, so I think the 275s will be the likely size I go with.
    Boerseun[QUOTED] likes this.
  21. Jan 5, 2024 at 6:23 AM
    #4221
    Boerseun
    Ferdie
    Sarasota Florida
    I have seen others post 275/65/20 also with no lift or leveling, and no rub, but if you go with 275/60/20 you will be on the safe side, definitely no rub, and still look a bit better than the OEM size. I wanted to add a bit more sidewall, hence the 65.
    Regarding the R&T replacing the AT3, I have heard both that it is being replaced and that it is just being added to the lineup. I honestly have no idea. The AT3 is so popular that I can't really see Cooper just do away with it and cause uncertainty with clients.
  22. Jan 5, 2024 at 10:31 AM
    #4222
    Magnetic1
    Stock 2024 Tundra 1794 4x4 with OEM 20x8" wheels (+60 offset) will I be able to run a 295/65/20 Michelin Defender Platinum tire prior to adding a RC 1.75" level??? Not opposed to running a wheel spacer to clear control arms if necessary. Thanks!
  23. Jan 5, 2024 at 10:36 AM
    #4223
    22platitundy
    22platitundy New Member
    2022 White Tundra Hybrid Limited TRD Off-Road
    Yes you should be good without the level. You could do a test fit. 295/60/20 fit definitely. 65 will be close.
  24. Jan 5, 2024 at 11:56 AM
    #4224
    Magnetic1
    Thank you, yup I agree 295 60 20 should be good, but I want that extra height/sidewall height with the 65. I am thinking maybe just put the RC 1.75" level on which should then allow for that 65 to work, and I could also add a wheel spacer too if needed. What do you think?
  25. Jan 5, 2024 at 2:30 PM
    #4225
    Teddyk1
    Teddyk1 New Member
    Teddy
    Wisconsin
    2022 Tundra SR5 , blueprint
    Tonneau cover
    Got my new wheels put on this week.
    Method MR317 18x9, 18offset. BFG KO2 275/70/18
  26. Jan 6, 2024 at 6:43 AM
    #4226
    22platitundy
    I think you’d more than likely be fine without the level. If there was any rub it would be minimal and you could address it after. No need for wheels spacers.
  27. Jan 6, 2024 at 11:59 AM
    #4227
    The Limited Alex
    The Limited Alex Beer Budgeter
    Alex
    Huntsville, Al
    2024 Crewmax Limited 4x4- Ice Cap
    1794 grill/mustache. 20% tint/40% windshield tint. Gun magnet. Raptor lights. Snowflakes. RC 1.75 level.
    I know there’s a lot of heat about going with big wheels on here, but this is exactly what I wanted. 24” snowflakes with 35x12.50. I have the RC 1.75” level and have the slightest rub on the felt behind the front wheels, but I removed the bracket and plan to zip tie the felt back. Wheels at +20 and I used a 1” hub bore adapter by Venum Wheels (very pleased with the product). All in all, sitting at -5.4 offset. The poke is a little much for me, but I plan to combat it with paint matched bushwacker fender flares. IMG_3733.jpg IMG_3731.jpg IMG_3734.jpg
  28. Jan 6, 2024 at 12:28 PM
    #4228
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2023 Tundra Platinum Hybrid
    Dobinsons IMS 2"/1", BMS 1" Wheel spacers with OEM Platinum Wheels. Icon Sway Bar Spacer. 285/65/20 Firestone Destination XT Tires.
    I don't usually like big wheels, but those look great. It looks factory, but better.
    Also, take a look at these flares. One problem I see with the bushwackers is RC specifically says they are not responsible for paint damage, and that you should expect rubbing.
    Here's another option that attaches like the OEM flares. https://nytop.store/toyota-tundra-s...p/2022-current-toyota-tundra-fender-flare-kit
    Csteppe and Boerseun like this.
  29. Jan 6, 2024 at 12:48 PM
    #4229
    The Limited Alex
    Alex
    Huntsville, Al
    Oh awesome, thanks for the suggestion. I just measured and I’m sitting right around 2” out from the oem fender flare, so that would be pretty dang close to flush. IMG_3738.jpg
  30. Jan 6, 2024 at 12:51 PM
    #4230
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    Yeah I think those NYTOP's would fit pretty much perfectly. They'd cover the tread but let the sidewalls stick out just a hair.
