Adding turn signal mirrors 2nd gen
Discussion in '2nd Gen Tundras (2007-2013)' started by OldGuy03, Jan 3, 2024.
  1. Jan 3, 2024 at 11:41 AM
    OldGuy03
    OldGuy03 [OP] Still new here, but working on it
    Jay
    CO
    12 MGM DC RW
    I've used the search tool and can't find a direct answer to this. I would like to add mirrors with the turn signals in them to my 2012 tundra grade rock warrior. I see parts on Amazon and the like with the mirror I want but am not sure if the wiring harness supports the signal function. Reading through reviews online I'm seeing that both; yes they fit and no they won't. Has anyone here added this aftermarket part or know if our oem harness will operate the signals within it?
    I'm not looking to go with full on tow mirrors, aka boost, just want the replacement glass with the heated and turn signal function. Currently my oem mirror glass has the heated function, just not turn signals.
    Thanks for any insight into this.
    https://www.amazon.com/gp/aw/d/B0BJKX66K9?smid=A2K0GLCDDJD24I
  2. Jan 3, 2024 at 4:21 PM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    My stock mirrors did not have turn signals. I installed the Boost mirrors with turn signals and the signals worked fine using just the OEM harness. So, it's prewired. Enjoy.
    OldGuy03[OP] and Wynnded like this.
  3. Jan 3, 2024 at 4:42 PM
    The turn signal wires do go to the plug, but you have to figure out which two they are and tap into them.
    OldGuy03[OP] likes this.
  4. Jan 3, 2024 at 4:49 PM
    I have not used Amazon mirrors, but I did add the Muth turn signal mirrors to both my 2013 and 2020 SR5 DC's. There are 2 wires that you will need to tap into. I was able to tin the wires with solder and insert them into the back of the plug and then zip tie them to prevent them from coming out. I have pics from my 2013 showing which positions to use but I will have to find them. I'm pretty sure that Casey's wiring thread will have that schematic as well.
    dp0031 and OldGuy03[QUOTED][OP] like this.
  5. Jan 3, 2024 at 4:57 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    My 2011 SR5 RCSB came with the standard heated and power adjustable mirrors. I stumbled into some Limited take-offs that additionally had the signals in the glass. My truck was prewired for the mirror signals.
    OldGuy03[OP] and PhotoNerd like this.
  6. Jan 3, 2024 at 10:03 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Exactly what I was looking for guys. Thanks for the feedback. Cheers.
  7. Jan 3, 2024 at 10:14 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    You need to test these pins/wire with a DMM to see if your mirror plugs are getting a signal feed.
    Going to be N5 and M6 are your mirror plugs.
    Pin 4 will be hot on/off for the signal, red on the left and pink on the right.
    Pin 3 the ground.
    Turn on your 4 ways and give it a shot..
    On my 2014 they were not hot and I had to run my own wiring from the kickplate for my Muth mirrors.
    If they aren't hot, you can look on Muth's install diagram.
    21000300RevE3 (muthco.com)
    07 Tundie, dp0031 and OldGuy03[OP] like this.
  8. Jan 3, 2024 at 11:10 PM
    pyrite808
    pyrite808 Real TRD Pros are built not bought
    Anthony
    Mid Tennessee
    08 DBL Cab Pyrite
  9. Jan 4, 2024 at 10:05 PM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    I love, love, love, love my spotter mirrors.
    Used them to replace my Muth mirrors on my 2014.
    After getting the Hottail's rear LED kit that gives you an amber rear turn signal, I needed an amber arrow in my mirror instead of the MUTH red arrow.
    It's because I have OCD issues..:rolleyes:
    I love (did I mention that?) how the spotter mirrors cover the blind spots..
    dnd387at_12eaa26b76edc362cbc3632e810cc56aa11e2146.jpgrxuossdz_b77b59a89b30e1a743bca96a3a03ec4ee89319e3.jpg
    Might be TMI, but here are the Hottail tail lights with the Spotter amber signal mirrors....
    https://youtu.be/i1jGXn7rSm4?si=9hK-95GcQStx-BM8
    https://youtu.be/k0hMlh9S_6o?si=tosbpsDVe7CLZANb
  10. Jan 5, 2024 at 12:21 AM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    This is what I need. I don't know how I missed it in your build thread which I've thoroughly enjoyed. Your rig is so sick. When I was looking to buy a newer tundra I was hoping a pyrite mica would fall in my lap, but buying used had always left color choice behind so many other priorities and I ended up with what I have instead. Thanks again for the idea on the mirrors.
    pyrite808[QUOTED] likes this.
  11. Jan 5, 2024 at 12:25 AM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    This is exactly what I needed to help streamline this whole process. Thanks for the thoughtful insight. These kinds of details will help get the approval pushed through my accounting department.
  12. Jan 16, 2024 at 7:10 AM
    AlexFIA
    AlexFIA New Member
    Tundra Rock Warrior
    Do you have a pic of these? How bright are the turn signals. Wondering if it's worth trying to find take offs or looking aftermarket.
  13. Jan 16, 2024 at 5:50 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I don't have any pictures of the signal while lit up. FWIW, they're amber, they're bright enough to be seen in the daylight by other drivers, but not annoyingly bright to the driver.
  14. Jan 16, 2024 at 6:25 PM
    mtucker
    mtucker New Member
    Escondido CA.
    2008 Double Cab
    Listed in my build thread
    I also bought the Spotter mirrors. My stock mirrors were power adjust and heated. My truck turn signal wires ran to the connector that is inside the door, but they did not continue past that connector and into the mirror. I cut and soldered to the turn signal wires at the door connector and then ran the wires into the mirror housing and connected to the Spotter turn signal wires. Like 1lowlife , I really like the convex mirrors that are built-in to the Spotter mirrors.
    Ran the wires:
    Mirror turn signal in action:
  15. Jan 17, 2024 at 2:16 AM
    Canman
    Canman New Member
    2007 Crewmax Limited
    Interesting read. I have the turn signals in the mirrors so I just assumed this was a standard feature on the Tundra.
    After driving my FILs 22 GMC AT4 recently on a full day highway trip, I loved the spotter/blind spot feature in the side view mirrors. I would swap my mirrors just to have that feature.
  16. Jan 17, 2024 at 4:04 AM
    AlexFIA
    AlexFIA New Member
    Tundra Rock Warrior
    Thanks. Definitely worth considering either way for the next upgrade.
    OldGuy03[OP] and Wynnded[QUOTED] like this.
  17. Mar 11, 2025 at 5:14 AM
    Thumper_6119
    Thumper_6119 I've seen things you people wouldn't believe.
    2011 Toyota Tundra SR5 Texas Edition (Crewmax) 4x4
    Just installed my SpotterMirrors over the weekend. Loving them.
    Install was a learning experience, but it wasn't difficult. (This thread was actually a big help). I researched the install process as much as I could before removing anything.
    The mirrors come with all of the wiring and connectors to put the mirrors together, but they don't include the connectors that go into the harness from the mirror to the door. It took a little googling around, but I found the male pin connectors that go into the mirror side harness (from Digikey).
    Pulled the mirror assemblies off, removed the mirrors from the housings, fed the wires through (removing the little panels under the housings makes feeding the wires a LOT easier), inserted the pinned wires into the harness, snapped the mirrors into the housings, reinstalled the housings, connected the harnesses, then put the panels back on. Tested..... BOOM! The turn signals work great.
    I had originally found these looking for blind spot mirrors. What's this? Turn signals too? And I get to keep my defroster functionality? Yep, someone is about to get my money. I have an SR5, so I wasn't sure if I was wired up to the door for the turn signals, but a little searching on here, and I had confidence that I was good to go.
    No more autoparts store stick-on tiny blind spot mirrors. These things are awesome. Wide field of view, and big enough to glance at and still get a good idea if there is anything next to me and what their proxemics are to my vehicle. (I still look over my shoulder. That's a 40+ year, well conditioned habit that isn't going away). For the times when I have to leave from my Fortress of Solitude and venture into the city, I like to have every advantage that I can acquire to make navigating Austin-metro traffic (especially rush hour) a little more safe.
    I'm very happy with my SpotterMirrors.
    1lowlife and OldGuy03[OP] like this.
  18. Mar 12, 2025 at 12:16 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Man you're inspiring me. I've had these mirrors in my cart for over a year now. I need to get off my ass and pull the trigger. But that's hard to do when I already have a bunch of purchased mods that haven't even been installed yet. Maybe I should start a thread for all of those things...
    I could call it my imaginary build thread. :anonymous:
  19. Mar 12, 2025 at 12:56 PM
    Lol.....my LC blower motor has been sitting in the garage for months.
  20. Mar 12, 2025 at 1:04 PM
    Thumper_6119
    There for a while, I had a "pile-o-parts" of new mods and maintenance items. New wheels, new grill guard, tonneau cover, SpotterMirrors, color matched mirror caps, new shocks and UCA's, spark plugs, and full set of rotors and pads. I'm down to just the rotors, pads, and spark plugs. My wife is pretty happy that I have all of the parts and boxes out of the garage. (She's still on me about the rotors).
    The SpotterMirrors are fairly easy to install so long as you plan your attack. I did all of the wiring on the SpotterMirrors before I ever pulled anything off of the truck so that all I had to do was feed the wiring, plug it into the connector, and snap the mirror onto the mirror housing mounts.
    I used these connector/wire combos to wire the mirrors to the mirror housing side connector. (The pins are tiny).
    https://www.digikey.com/en/products...bD6OO5l-LItzhO2YM8I6H-5zaPc01l7xKR0W5QBb0lapQ
    I just clipped off the female end leaving enough wire to splice onto the mirrors wires, then inserted the pins into the back of the connector harness. You'll need 4 of those.
  21. Mar 12, 2025 at 2:52 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Thanks for the Install notes.
  22. Mar 12, 2025 at 4:05 PM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    My 2010 Reg Cab regular everything came with plain black mirrors. I got a set of chrome signal embedded
    mirrors and put them on, they plugged in and the big signal arrow worked. cool. No wiring required.
  23. Mar 13, 2025 at 8:37 AM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    I should add I paid a whopping $75 for pair of mirrors and brand new still in bag carpets for MC.
    Of the most prolific items on FB for sale are mirrors. Christ, literally hundreds of pairs for pennies on the dollar.
  24. Apr 1, 2025 at 1:40 PM
    07RCSB
    07RCSB New Member
    2007 Tundra RCSB
    none yet
    I completed this over the weekend and added the spotter mirror and blinker arrow to both sides of the truck. LOVE the spotter mirrors and the amber turn signal is nice. Feels a tiny bit less like a 18 year old truck :)
  25. Apr 30, 2025 at 8:05 PM
    Aphelion79
    Aphelion79 New Member
    2020 Midnight Black Tundra SR5
    None (yet!)
    @Thumper_6119 Hey bud, I just ordered this because I was thinking of doing the EXACT SAME THING. Question though: How did you figure out what Pin would fit the terminal? I've got a ton of other applications and wiring to do on other projects and have no idea how to identify which pin size, etc I need.
    Thumper_6119[QUOTED] likes this.
  26. May 1, 2025 at 5:28 AM
    Thumper_6119
    I am no wiring expert, and I had no idea of the pin designation. I took a photo of the factory mirror-side harness with the pins showing and uploaded it to google image search. I got a bunch of results of several different pin sizes. I went through a few of them until I found the correct shape and size. Digikey had the ones that I wanted (that I linked above).
    During that search, I also found boxed kits containing a variety of different male and female connectors that would go into several different types of harnesses (though I didn't order any of those as I didn't have a use for all of that).
    I hope that helps.
    ETA: this is the photo that I used:
  27. May 1, 2025 at 12:33 PM
    Aphelion79
    None (yet!)
    Oh I didn't think of using AI or image search for stuff like this... I'll have to give it a try. But thanks for doing the trial and error for the rest of us! I should have my wires by next week so I can finally wire these up!
  28. May 1, 2025 at 1:29 PM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    Do you still need wiring diagrams?
    You can find them here for your truck.
    Ultimate TUNDRA Wiring Diagrams Collection | Toyota Tundra Forum
    You might have power to your mirror plug for turn signals, but you might not.
    Your mirror plugs are N5 and M6
    In this pic, it's upside down and the male side of the connector.
    Pin 1 power and 2 ground are the heaters.
    Pin 10,11, and 12 are the power mirrors.
    The turn signals will be pins 3 ground and 4 power
    And if you ever want to do your own puddle lights pin 5 ground and pin 6 power
    GAknight, Thumper_6119 and Wynnded like this.
  29. May 1, 2025 at 5:17 PM
    Thumper_6119
    More gold from @1lowlife. Your diagrams really helped when I did mine. :thumbsup:
    OldGuy03[OP] and 1lowlife like this.
  30. May 1, 2025 at 11:44 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    To OP, and FWIW;
    I added Platinum mirrors with the turn indicators some years back. Since they were also power-foldable, I added the folding-power switch, along with a custom LED strip. Here's a brief write-up.
    As mentioned in earlier posts above, the wiring diagram for the plug is the main thing. The plug (truck-side) just needs to have the wires and pins added. I source all my wiring, plug, pin needs from Corsa-technic. I can't recall the exact pin size, but I simply pinned some new wire(s), added them into the plug on the truck/door side, then ran the wires over to the driver kick panel and tapped into the turn signal.
