General Supercharger Thread
  1. Jan 3, 2024 at 11:25 AM
    gkin
    gkin New Member
    2020 White Tundra
    Sounds like a blast. Waiting for a bonus in march and then may pull the trigger
  2. Jan 3, 2024 at 11:27 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, solid Offroad engine mounts, DIY Traction Bars, Tuning by snivspeedshop.com
    That's a plus! Sniv's speed shop and offroad sight seeing. Throw in some rock crawling. That's a trip I'd make.
    Silver17, ARES35, helidave and 3 others like this.
  3. Jan 3, 2024 at 11:28 AM
    snivilous
    SW UT
    300k+ Supercharged 2008
    Hell I'll even take you for a rip in my other supercharged vehicle :D play with all the toys and at the end of the weekend have a Tundra with another 200hp. Food for thought ;)
  4. Jan 3, 2024 at 11:31 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    completely unfair sales technique.
    diabolical....
    how does a Grown-ass man say no?
  5. Jan 3, 2024 at 11:32 AM
    gkin
    gkin New Member
    2020 White Tundra
    that thing looks sweet! Thanks for the generous offer. I’ll keep you posted
    Mdl and snivilous[QUOTED][OP] like this.
  6. Jan 3, 2024 at 11:35 AM
    snivilous
    SW UT
    Have to sweeten the pot somehow, Indiana is a long ass drive :rofl: I know I'd be hard pressed to drive that far for much of anything
    Fastlane47, ARES35, Mdl and 2 others like this.
  7. Jan 3, 2024 at 11:55 AM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    Anybody know how to tune out the rpm flare on startup? I have the startup rpm adder set to zero, but it still goes up to like 1700rpm right when it starts and then immediately drops to idle. Startup airflow tables maybe?
    ARES35, Mdl and Wynnded like this.
  8. Jan 3, 2024 at 12:07 PM
    TunedYota
    TunedYota New Member
    Magnuson SC
    I am a Magnuson dealer here in the Midwest. We also specialize in Toyota/Lexus tuning. I can easily create a quote for you and go over any details you need.
    info@tunedyota.com or the shop line at 612-406-7117
  9. Jan 3, 2024 at 1:05 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I messed with this just a little over the summer. I only decreased the Startup Adder by 100rpms. At the same time I reduced the Base Setpoint > Base P/N >Target Idle Speed P/N by about 100-125rpms. When the engine was at operating temp with the Adder at 0, it seemed to need a little longer starter engagement, like there wasn't enough air or fuel and it would do what I can only describe as a "gradual start" where it would start from a very low rpm and then slowly come up to idle and then the starter would disengage when the ECU seemed to be satisfied that it was going to continue running. Cold starts didn't seem to change much at all. Right now I have Startup Adder at 200rpms and then Base Setpoint > Base P/N >Target Idle Speed P/N like this (below) compared to stock for the winter time so that starts below 30F are normal for warmups and reliable remote starts when I can't see/hear the truck. I went to this after getting distracted by the 2650 upgrade and getting that tuned.Target Idle.png
    I've tried messing with the Airflow tables when I was trying to sort my injector rich starting issue and really didn't get anywhere. After installing the current injectors, I messed with them some more to see if I could recreate the rich starting, but no luck there either.
    With that said, maybe try setting Startup Adder at 100rpms, dropping Base Setpoint > Base P/N >Target Idle Speed P/N by 10-20% and then Engine > Idle > Airflow > Startup Airflow ECT by 10-20% (the entire table, save a copy of your base tune though!) and see what you get. Maybe break each one of those changes into a separate flash/test to see what changes versus changing too many things at once and not being sure which tune change makes a difference. Then make 5% changes, then smaller and to more specific areas of the tables to narrow it down to what your goal is. Then let us know what you discover, and good luck!
  10. Jan 3, 2024 at 1:06 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Probably order it with pineapple so no one else would touch it...;):rofl:
    1UP, ARES35, Mdl and 2 others like this.
  11. Jan 3, 2024 at 3:13 PM
    PolishedTRD
    PolishedTRD Lorem ipsum dolor sit amet
    CO
    Supercharged 2011 DC
    Magnuson's Finest Whine
    Sorry fellas but allow me to break away from the serious tone of this thread - just for a brief moment - and share with you some exciting news from China.
    I've been looking for a variable displacement turbo supercharger, and finally found one. I know, you're thinking, "PolishedTRD, ya dumbass, there's no such thing as a VaRiAbLe DiSpLaCeMeNt TuRbO sUpErChArGeR."
    Well you're wrong.
    Behold, the 2.0-3.5L Turbocharger Supercharger remanufactured from the finest Chinesium! It even includes a flared threaded intake port.
  12. Jan 3, 2024 at 3:21 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    What, no C.A.R.B. approval?
    Also, I can't believe you took the time to capitalize every other letter...
    Added to my Wishlist. Meanwhile, searching for that 6% off coupon.
    Mdl, Silver17, ARES35 and 2 others like this.
  13. Jan 3, 2024 at 3:32 PM
    PolishedTRD
    CO
    I'll register it in Utah if I have to, if it means owning the greatest advancement in forced induction, since the leaf blower.
    It's figuring out the damn fuel injectors that worries me!
    Shift button be worn out!
    ARES35, Mdl and Wynnded[QUOTED] like this.
  14. Jan 3, 2024 at 4:05 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    What boggles the brain is how you are able to search for the latest and greatest in forced induction technology.
    ARES35 and snivilous[OP] like this.
  15. Jan 3, 2024 at 4:13 PM
    PolishedTRD
    CO
    It starts with ignorance.
    I follow @reywcms build thread he created for his dad's truck. I don't know what "Sachi-Supercharged" means, so I Googled sachi supercharger, thinking there was some new amazing brand or perhaps tuner called Sachi. Instead of finding a reasonable answer, I was gifted the gift of google results.
    Mdl[QUOTED], ARES35, Wynnded and 2 others like this.
  16. Jan 3, 2024 at 4:29 PM
    ARES35
    ARES35 New member for life
    Mile high
    And it begins!.....insert evil laugh:devil:
  17. Jan 3, 2024 at 4:48 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    From the Google-
    Sachi is a feminine name of Japanese origin. This charming name is a clipped version of the Japanese name Sachiko and translates to “child of joy”—certainly a fitting title for your family’s newest arrival! The name also has roots in Indian tradition, thought to mean “one who is related to the Sun God”, which would suit a baby with a bright disposition.
    AKA- fun haver lol
  18. Jan 3, 2024 at 4:53 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    But also correlates to the famous Japanese dog which is another reason for the name they chose for the rig
    Hachikō
  19. Jan 3, 2024 at 5:48 PM
    snivilous
    SW UT
    Anyone know what a P219A code is? It says "Fuel Trim Cylinder Balance Bank 1" and seems to indicate bank 1 is off? There's a P219B which is for bank 2, but that's not blown. Customers offroad only racecar with no cats has P219A, which I've never seen before and doesn't seem like it'd be related to the cat delete, and if it was I'd think P219B would also blow? Fuel trims are within 2% between the banks.
    Fastlane47 and ARES35 like this.
  20. Jan 3, 2024 at 6:00 PM
    JustDSM
    JustDSM New Member
    Justin
    2023 Ford Raptor
    High mileage motor?
  21. Jan 3, 2024 at 6:11 PM
    snivilous
    SW UT
    I don't know the mileage but it's a 2019.
  22. Jan 3, 2024 at 6:16 PM
    JustDSM
    JustDSM New Member
    Justin
    2023 Ford Raptor
    I've seen that code pop up on worn valves/seats. Odd, but after looking at everything else had a leakdown test done and once valve job was done all was good. Probably due to the motor ingesting fine particulate. Valves were cupped.
    *Edit* Should probably note it was accompanied with an occasional P0300 as well.
  23. Jan 4, 2024 at 3:12 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I did a thing. (below is me hitting the "peak" button after parking at the whse.)
    3/4 pedal onto the 225 on ramp. 48 degree humid morning.
    the truck made beautiful noises.
    I probably got up to 5000 RPM and still did not hit the 500gm MAF alarm.
    AFR was a tasty 10.2
    I finally got to see the effects of the HPtuners Transmission tuning.
    Me thinks I'll stop here.
  24. Jan 4, 2024 at 3:27 AM
    19PlatinumCrew
    19PlatinumCrew New Member
    Dave
    MGM 19 Platinum Crew
    Toytec 3" coilover lift,295/75/18 on Method Nv,Nitto tires,Retrax cover,spray liner.
    Nobodyintexas, did you change out your air box to the Maggie
  25. Jan 4, 2024 at 3:31 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    no.
    I used the regular TRD unit. so, it's still essentially a stock intake. uses the same WIX filter.
    only change I made was that I installed the flared inlet thing...which probably does nothing, but I was there & it was easy.
  26. Jan 4, 2024 at 3:33 AM
    19PlatinumCrew
    Dave
    Keith up and your gonna forfeit the old and slow title
  27. Jan 4, 2024 at 3:35 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Hah...truth be told I was going 59mph this morning - to see if I could hit 18.5mpg.
    got a little anxious when I saw I was first at the stop light to turn onto 225.
    So, I gave it the beans. Man, it moved!
    I feel like I'm riding in a grenade that I've yet to pull the pin on!
  28. Jan 4, 2024 at 3:40 AM
    19PlatinumCrew
    Dave
    I feel ya Brother, wife and I was out driving and she commented how good the truck was running I said until it Doesn't
  29. Jan 4, 2024 at 3:42 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    dead on.
    Until it doesn't.
    Kinda like the old submarine joke - How deep will it go?
    Mdl and 19PlatinumCrew[QUOTED] like this.
  30. Jan 4, 2024 at 10:22 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Hopefully you left an "11" :burnrubber:to commemorate new boost PRs.
