Bed Mats for 3rd Gen Tundra
Discussion in '3rd Gen Tundras (2022+)' started by Tub356Fan, Jan 20, 2023.
  1. Jan 20, 2023 at 5:05 PM
    Tub356Fan
    Tub356Fan [OP] New Member
    2023 Tundra Limited Crewmax 4WD - Blueprint
    Does anyone know why very few aftermarket bed mat manufacturers aren’t building mats for 2022-23 bed mats?
  2. Jan 20, 2023 at 5:46 PM
    Cp1
    Cp1 New Member
    Chad
    2023 tundra limited 4x4
    I couldn’t find the rubber mat that I’ve had in my previous trucks so, I ended up buying recycled material carpeted mat.. purchased from realtruck.com. Haven’t received it yet…
    Tub356Fan[OP] likes this.
  3. Jan 20, 2023 at 5:56 PM
    ArticTundra
    ArticTundra New Member
    Cold
    My dad has a Toyota bed mat on his Tacoma, its meh. I use Livestock stall mats and cut to shape. They are super strong and difficult to destroy.
  4. Jan 20, 2023 at 6:13 PM
    SC4333
    SC4333 New Member
    Grant
    2022 Tundra Limited TRD OR 4x4
    I've run the Toyota OEM rubber bed mat on both my Tacoma and my Tundra. No complaints here, and hard to beat for the money. You can order them from your Toyota dealer or have one shipped.
    I ordered the mat for the Tundra from Sparks Toyota www.sparksparts.com since I'm out in the sticks. On top of that my dealer won't sell any parts under MSRP.. So online it is!
    PT318-34221 Tundra Bed Mat -Standard Bed $138.00
  5. Jan 20, 2023 at 6:27 PM
    Cp1
    Cp1 New Member
    Chad
    I should have shopped around..I paid $130 for the recycled material carpeted one..:(
  6. Jan 20, 2023 at 6:33 PM
    SC4333
    SC4333 New Member
    Grant
    I hear that. Almost made the same mistake myself!
  7. Jan 20, 2023 at 8:36 PM
    Peak23
    Peak23 New Member
    Kyle
    2023 tundra crew max SR5
    Weird, it’s showing $174 before tax and shipping for me
  8. Jan 20, 2023 at 10:10 PM
    SC4333
    SC4333 New Member
    Grant
    Wow, I just checked the price and it is also showing $174. My invoice at $135 (prior to tax & shipping) was from only 4 months ago! I ordered a ton of stuff that day so i'm not sure exactly what the shipping cost would have been for the mat alone. Between the mustache, grille, steps, and bed mat, the shipping quote was over $100. No surprise there. Still much less expensive than buying them at my local dealer :/
  9. Jan 20, 2023 at 11:36 PM
    Timmy23
    Timmy23 New Member
    OR
    25 1794 MGM Tundra LB
    None
    Tub356Fan[OP] and SC4333 like this.
  10. Jan 21, 2023 at 1:20 AM
    b0yax
    b0yax New Member
    Use this site Toyota Parts and Accessories - Official Online Store and search using part number. You can choose which dealerships carry those parts and select the cheapest one you can find. Use code FREESHIP to get free shipping. I bought around 2k worth of parts from dash cam, running boards, bed mat and bed step.
    Cp1, Tub356Fan[OP] and Yaboy like this.
  11. Jan 21, 2023 at 2:09 AM
    Timmy23
    Timmy23 New Member
    OR
    None
    I did that, all local dealers didn’t have that much of a discount….
    It was later through this site after I had ordered one that I found the Texas one with much better pricing on everything.
    Oh well, it is installed now.
    Tub356Fan[OP] and b0yax[QUOTED] like this.
  12. Jan 21, 2023 at 7:45 AM
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp/sub, rear seat del, cat shield, AMP power boards
    I actually like the BedRug or similar carpet types better than rubber. Tonneaus are never 100% dry and the carpet gives you a little air gap in the event there is some moisture present. These aren't for anyone who hauls loose dirt, sand or mulch, however. Yes, they can easily be removed and hosed down, but that kind of stuff would probably get embedded.
  13. Jan 22, 2023 at 7:16 AM
    Cp1
    Cp1 New Member
    Chad
    I received the bed rug yesterday…disappointed because it’s so light..(probably weighs less than 5 lbs) I’m going to send it back
  14. Jan 22, 2023 at 7:32 AM
    raylo
    Frederick, MD
    That's sort of the point. The carpet fiber pile is mostly air which keeps your stuff dry if a little moisture gets in the bed. And it makes it very easy to remove and clean. Doesn't mean that it is delicate, I have had one in my Tacoma for years and it is in great condition. My use case is mostly lumber, drywall, coolers, luggage, bicycles, kayaks, etc.. with an occasional riding lawnmore engine or pile of gravel. But if your use case includes really heavy metal stuff with sharp edges, a dense rubber mat would probably be better.
  15. Jan 22, 2023 at 7:57 AM
    Cp1
    Cp1 New Member
    Chad
    Agreed
  16. Jan 22, 2023 at 9:33 AM
    Breathing Borla
    AZ
    With moisture always present to some degree, doesn’t the bed rug smell moldy?
  17. Jan 22, 2023 at 9:42 AM
    raylo
    Frederick, MD
    No, at least with my Tacoma with the retract tonneau, that mostly lets a little water in at the tailgate. The mat is all synthetic and doesn't absorb a lot of water. so it dries out quickly.
  18. Jan 22, 2023 at 5:10 PM
    Cp1
    Cp1 New Member
    Chad
    reminds me of bubble wrap
  19. Jan 24, 2023 at 2:23 PM
    Cp1
    Cp1 New Member
    Chad
    Just order a rubber Toyota mat… free shipping $180 total
  20. Jan 24, 2023 at 2:57 PM
    dowdydl
    dowdydl New Member
    I have the BedRug and I love it. I had it with my last 3 tundras. Even though you get a little water in the bed at times, it does not cause problems. The bedrug does not absorb water and the way it is designed underneath allows water to move to the bed drains. I have never had a problem with mold or odor. It's also super easy to remove and reinstall.
    Boomer08 likes this.
  21. Jan 3, 2024 at 4:57 AM
    KYBob
    KYBob New Member
    2024 Platinum
    I can't find an OEM mat, a Black Armour mat, or a Gator mat that is available. Toyota dealer quotes a "stop sale" status on the OEM mat, and retailers say the other two are "currently unavailable". I'd really like to find the Black Armour one, but would settle for an OEM or Gator one. Anyone know what the problem is behind the unavailability?
