Found the right cheap adapter for dropping the spare quick and easy
Discussion in 'Wheels & Tires' started by MedCityMoto, Jan 2, 2024.
  1. Jan 2, 2024 at 1:59 PM
    MedCityMoto
    MedCityMoto [OP] SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    I went with a set of 5 new tires and sourced another TRD Offroad alloy wheel, and I've been looking for the right adapter to make dropping the spare for my 5-way rotations with my onboard impact driver easier. Found just the thing on my second try!
    7/16-Inch Female Pipe Plug Socket for $6.75 shipped to my door from Amazon.
    https://www.amazon.com/dp/B006L23G0W
    Perfect fit, right over one of the two male ends of the extension piece of our OEM spare tire tools. Call me lazy or whatever, but this is just the thing for simplifying dropping the spare!
  2. Jan 2, 2024 at 2:10 PM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
  3. Jan 2, 2024 at 2:11 PM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    You can also put a 3/8" square drive inside of the larger flare end... I don't remember if the extensions work the right way to drop the spare like that but I used that to spin the bottle jack for some work I was doing.
    MedCityMoto[OP] likes this.
  4. Jan 2, 2024 at 2:12 PM
    MedCityMoto
    I opted for this solution because the way the flared female end of the tools is shaped, but I did make that work before, just didn't like the slop. Prefer a snug fit!
    APalmTree[QUOTED] likes this.
