General Supercharger Thread
  1. Dec 30, 2023 at 12:43 PM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    8an hose is 10.9mm .44”, but what are the rails they produce?
    Mdl likes this.
  2. Dec 30, 2023 at 1:00 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, solid Offroad engine mounts, DIY Traction Bars, Tuning by snivspeedshop.com
  3. Dec 30, 2023 at 2:43 PM
    luxury4play
    luxury4play New Member
  4. Dec 30, 2023 at 3:21 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    No it’s not. Not sure the boost that is and your elevation. But on a Whipple one step down is 8psi and that’s with a dw650 and a 340 pump was plenty
    ARES35, snivilous[OP] and Mdl like this.
  5. Dec 30, 2023 at 3:56 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    You'll be solid. That's exactly what I'm running and fueling logs are good
  6. Dec 30, 2023 at 4:01 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    The stock system is good to go.
    Those post are for people who like to change, modify things and just can't leave well enough alone.
  7. Dec 30, 2023 at 4:04 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Haha most of us
  8. Dec 30, 2023 at 4:20 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    No it’s not
    I’m running 77.5mm on my harrop standard stuff including 650’s
    no issues
    I ran the 80mm also.
  9. Dec 31, 2023 at 8:18 AM
    ARES35
    ARES35 New member for life
    Mile high
    MPVI-3 is in town! Pretty pumped up that I'll finally be able to see some actual tuning tables/mapping and not just wonder what the hell is going on with a locked map! Plus I actually like dorking out on tuning/data. @snivilous, I'll be running some datalogs between today/tomorrow, sorry for my delay on getting them yesterday. Got busy with some of my daughters stuff, damn kids lol
  10. Dec 31, 2023 at 8:42 AM
    snivilous
    SW UT
    300k+ Supercharged 2008
    No worries man, doesn't affect me in the slightest when you get it done :D
    Fastlane47, helidave, Mdl and 3 others like this.
  11. Dec 31, 2023 at 11:43 AM
    VWTim
    Corvallis, OR
    Ok, Harrop fuel pressure. This is a Harrop supplied FRP from summer '23, they "crush" them prior to shipment now. It's a factory Toyota FRP.
    The gauge and tap from Racetronix showed up, 1/4 the price of the NX tap and sealed perfectly.
    At warm idle (without boost/vacuum reference): 51 PSI
    With boost/vac reference, 40 PSI idle
    Now we know. Plus looks like if we need a bump in fueling, a FFV FPR should get another 9 PSI.
    ZPhilip, ARES35, Mdl and 10 others like this.
  12. Dec 31, 2023 at 12:16 PM
    19PlatinumCrew
    19PlatinumCrew New Member
    Dave
    MGM 19 Platinum Crew
    Toytec 3" coilover lift,295/75/18 on Method Nv,Nitto tires,Retrax cover,spray liner.
    Did you returned after installing the 77.5
  13. Dec 31, 2023 at 12:18 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    no
    same tune as 80 mm
  14. Dec 31, 2023 at 12:20 PM
    19PlatinumCrew
    Dave
    How do you like it, I haven't changed mine yet
  15. Dec 31, 2023 at 12:24 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    it’s more better
    since I don’t delve into the higher rpms, it’s ideal.
    plenty of low end punch.
    and 9.5psi can’t be good for my stock block
    but i rarely see anything higher than 7psi with my driving style
    I’m sea level - Houston
    Silver17, ARES35, Mdl and 1 other person like this.
  16. Dec 31, 2023 at 12:26 PM
    19PlatinumCrew
    Dave
    I'm old and slower haven't been past 6psi
  17. Dec 31, 2023 at 1:04 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    9+ psi here all is well.
    Fastlane47, Silver17, ARES35 and 4 others like this.
  18. Dec 31, 2023 at 1:19 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Nice, thank you for doing this, good to know a real-world number.
  19. Dec 31, 2023 at 1:51 PM
    snivilous
    SW UT
    Awesome info, I'll add it to the first page.
    Does the stage 2 only come with that, or does the stage 1 kit include the FPR do you know?
    Fastlane47, e30cabrio, ARES35 and 2 others like this.
  20. Dec 31, 2023 at 1:59 PM
    VWTim
    Corvallis, OR
    Stage 1 comes with the FPR and pump only for fueling changes.
  21. Dec 31, 2023 at 4:19 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I'm out working on the Tundra and my mom comes by and says it worse than having a high maintenance girlfriend...geez!:D
  22. Dec 31, 2023 at 4:49 PM
    19PlatinumCrew
    Dave
    Probably more expensive too
    nags, nobodyintexas, Silver17 and 3 others like this.
  23. Dec 31, 2023 at 5:40 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Trying to clean up all the wire taps for relays in the fuse compartment that need ignition sources. Those that have additional fuse blocks, did you mount it on the cover and give some addition wire to open cover?
    ARES35 and reywcms like this.
  24. Dec 31, 2023 at 6:53 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Lightly used Harrop deal in VA if anyone knows anyone looking.
  25. Dec 31, 2023 at 7:41 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Merry New Year ya filthy animals!
  26. Jan 1, 2024 at 6:50 AM
    Silver17
    Eastern PA
    This video is interesting in regards to rear cylinders running hotter than others. Not sure how the main argument he is making as far as more airflow to the rear cylinders due to inertia of the entering air flowing from front to back of the manifold correlates to how the air is distributed through our supercharger manifolds. I assume that all goes out the window once the air travels through the rotors, then it’s probably just a matter of how equal the distribution out of the discharge of the rotors is which is probably different from one blower to the next. I guess it could be a good idea to marginally increase fueling to the rear cylinders via the tune?
    https://m.youtube.com/watch?v=UppclOQjs5E
    ARES35, Saltyhero13 and Jowett like this.
  27. Jan 1, 2024 at 8:39 AM
    snivilous
    SW UT
    I've heard this from a local diesel shop also. They (and subsequently I) put the looser rings on the rear pistons because of that. I was under the assumption it was because the rear cylinders are just sitting behind everything else that's hot, so regardless of coolant or intake flow, they are getting blasted by hot air coming and just generally sitting in a hotter part of the engine bay. That could be disproven by an inline engine rotated 90deg, I wonder if those have the same results.
    Regardless, I don't fuel the rear cylinders more since all the cylinders in general (I'm assuming) are getting so much fuel anyways, what's an another one or couple tenths AFR difference going to make. And without telemetry to those cylinders, it's as much a guess fixing the problem as it is guessing if there is or isn't a problem to begin with. And if anything we hear of evidence that the rear cylinders are not the problem ones, so imo simpler tuning prevails. Just my $.02
    ZPhilip, Saltyhero13, ARES35 and 6 others like this.
  28. Jan 1, 2024 at 8:58 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Would information from a transverse 4cyl (with all cyls evenly "exposed") and/or a transverse V6 (with the rear bank tucked between the front and the firewall) give some insight?
  29. Jan 1, 2024 at 9:06 AM
    snivilous
    SW UT
    That's what I'm thinking, with the 4cyl the whole block would be broadside to the airflow and heat coming off the radiator. Get something with an intake with even distribution or just individual throttle bodies/carburetors, etc. Maybe that video they were scientific about it, put it on a dyno, put it broadside to the fan, etc. but the fact dude narrowed in on intake airflow of all things making the rear cylinders hotter doesn't make sense to me, and would be extremely easy to disprove (hell a naturally aspirated 2JZ has a symmetric air intake since the intake wraps over the top of the engine and 1-2-3 is effectively a mirror of 4-5-6). So his analysis seemed biased from the start since it seemed based on a turbo 2JZ which normally runs the intake where it starts at cylinder 1 and ends at 6, so as biased for "airflow causes it" as possible. Couple that with the guys I know saying they've seen the same results, with an entirely different engine and intake configuration, makes me think it's NOT the intake design causing it.
    And since we don't all have access to engine dynos, that's just why I was throwing out a different real world configuration that might help isolate what variable actually causes it if someone cared to delve into it :D and maybe I'm full of shit, it'd just be nice if a place like Haltech could be a bit more scientific before throwing out a video like that.
  30. Jan 1, 2024 at 9:14 AM
    Silver17
    Eastern PA
    5 and 6 being centrally located cylinders on the 3UR, and being the likely ones to pop may align with the fact that the discharge of the rotors at least on the Harrop is pretty centrally located. Not sure about the other blowers, I just know looking at where the discharge was in Viktor’s video looking inside the Harrop it looked pretty centralized to the manifold and if anything slightly biased to the rear. Not sure if that’s how the Magnusons are. Seeing as the air would have to make less turns to get to cylinders 5 and 6 through the blower manifold I do see how they could maybe get more airflow.
    Saltyhero13, ARES35, ViktorG and 3 others like this.
