Which Non Tundra Toyota Rims fit FGT?
Discussion in '1st Gen Tundras (2000-2006)' started by Trueno, Dec 31, 2023.
  1. Dec 31, 2023 at 1:28 PM
    Trueno
    Trueno [OP] New Member
    Will
    2006 Sr5 Dbl Cab
    will these 17” 4Runner rims fit my DC directly? Truck is stock (not lifted) do I need to add anything? Spacers? Etc?
    Edit: I should have posted this in the Wheels section. My apologies
    The Black Mamba likes this.
  2. Dec 31, 2023 at 1:29 PM
    Yes, the will fit
  3. Dec 31, 2023 at 1:32 PM
    GipsyKxng
    GipsyKxng New Member
    2005 AC 2wd limited
  4. Dec 31, 2023 at 1:37 PM
    Trueno
    Will
    2006 Sr5 Dbl Cab
    Thanks Frenchy and Gipsy for the pic. I almost bought a set of those yesterday for $400 but hesitated and someone beat me to them. On the hunt again.
  5. Dec 31, 2023 at 1:42 PM
    This thread has a bunch of people running those and is where you should look if you're wondering about Toyota OEM wheel compatibility: https://www.tundras.com/threads/lets-see-1st-gen-with-toyota-rims.40487/
    $400 is a great price if with tires.
    I wouldn't pay more than $75/wheel if it's the wheels alone. Remember, you've got another $30/wheel for TPMS sensors, then tires, and ... before you know it you're gonna be in it for $1,800.
    I'd much prefer to buy with tires installed for $500-600 which is what I normally see in the ATL area.
  6. Dec 31, 2023 at 2:45 PM
    Trueno
    Will
    2006 Sr5 Dbl Cab
    I’m with you Shifty but New York, with a Higher Cost of Living and higher salaries, commands higher prices for everything.
  7. Dec 31, 2023 at 2:55 PM
    The Black Mamba
    Snek
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Lots of good information given already. I would just like to add that the answer to your initial question is that any rim with a lug pattern of 6x5.5 with a hub bore of 106mm will fit
  8. Jan 8, 2024 at 11:17 AM
    Trueno
    Will
    2006 Sr5 Dbl Cab
    I found a set that were just taken off a 2023 4Runner. Do the air pressure monitors come with the rims or do I need to buy them separately? How do they sync with my truck? Will the monitor system pick them up?
  9. Jan 8, 2024 at 11:21 AM
    The Black Mamba
    Snek
    DFW
    Imma keep it stock
    Only the seller can answer if they come with. If, not then you'll buy them when you mount the tires and the tire shop will program them, just so long as they are OEM. If they do come with the rim, they will still have to be sync'd. I know that with Subaru, even though they use Denso, only certain part numbers will be read by the TPMS module, and some require dealer programming.
  10. Jan 8, 2024 at 11:22 AM
    The TPMS sensors are mounted where the valve stem goes, so if the rims have tires, they should have TPMS sensors. It's pretty clear whether the wheels are using a standard valve stem; TPMS stems typically have metal showing outside the wheel.
    Not sure if the ones off the newer T4R wheels will be compatible.
    You need to program the sensors into the TPMS system for the Tundra, if it's possible. You'll need a TPMS tool (handheld) to scan the wireless ID on each sensor, then program that ID into your truck. OR to have the shop program the existing IDs in your TPMS ECU onto the sensors in the wheels.
  11. Jan 8, 2024 at 11:23 AM
    (Or you may just be able to get a tire shop to swap the TPMS sensors from your old wheels to the new ones)
  12. Jan 8, 2024 at 11:32 AM
    Trueno
    Will
    2006 Sr5 Dbl Cab
    Thanks Mamba/Shifty. I'm picking them up tomorrow. I found a set in Massachusetts and was going to drive 3.5 hours for them, until I told wife "3.5 hours, each way".....then I found another set 2 hours away in Pennsylvania. I considered those but this morning a new set popped an hour away so I'm going for them. A little pricey but in excellent condition......the way I reason these Tundra expenses, I could either look at my money in the bank or I could buy what I want with it and enjoy it.
  13. Jan 8, 2024 at 11:33 AM
    Trueno
    Will
    2006 Sr5 Dbl Cab
    But if my old wheels are throwing an error, dashboard light, wouldn't that error in reading transfer to the new rims?
  14. Jan 8, 2024 at 11:39 AM
    Yes. If the light is solid, it means your tire is low. If the light is flashing, it is normally a communications error, like... the battery inside the sensor (which is almost impossible to replace) finally died.
    Best bet? Replace the existing sensors with new Denso sensors that are the correct model for your truck. You can look up the correct part number at www.densoautoparts.com
    I just replaced all 4 of mine; $30/sensor buying at RockAuto, which had cheaper prices than I could find anywhere, including Summit and scAmazon.
    Yes, this is expensive, but authentic Denso sensors are good for 15-20 years if you buy quality OEM ones. If you choose to get the generic ones ... let's just say there are a lot of guys on here who got frustrated and pulled the TPMS lightbulb from the dash because they got tired of seeing the light come on, even with the new sensors. I remember one guy went back to his tire store 4 times (because in the '05-'06 you can't remove the light bulb :rofl: ) and they still couldn't get the popular aftermarket brand to work.
  15. Jan 8, 2024 at 11:46 AM
    Trueno
    Will
    2006 Sr5 Dbl Cab
    Please send me the Denso part number if you have it handy. I tried to find it using the link you sent and got lost.
  16. Jan 8, 2024 at 12:18 PM
    550-0103
    Don't buy 'em on scAmazon, you'll probably get knockoffs.
    Trueno[OP] likes this.
  17. Jan 17, 2024 at 9:12 AM
    Trueno
    Will
    2006 Sr5 Dbl Cab
    Shifty, is it possible that some of the sensors are bad and some can be used? And I only need to replace one or two?
    Or is it better to just replace all four?
  18. Jan 17, 2024 at 9:32 AM
    You'd need to run diagnostics to know which are bad or which are good. These trucks' TPMS system is a bit dated in that the tires aren't registered to each corner, so you need to use special tools or crafty deduction with a scanner tool that has TPMS ECU access to know which is bad. (deflate tire, watch for its pressure to lower on the scanner, etc.)
    But honestly, if they're original and one is going bad, the rest are likely to follow in short order. It hurts the wallet, but it's best to change them all now, while the tires are getting done, so you're not paying individually for replacement and programming in the coming 1-3 years.
  19. Jan 22, 2024 at 2:31 PM
    Trueno
    Will
    2006 Sr5 Dbl Cab
    I bought a full set of those sensors. My mechanic put the new rims and the sensors but the truck is not recognizing the sensors. Is there anything that must be done for the truck to detect them? Do the sensors need be "awaken" ?
  20. Jan 22, 2024 at 2:34 PM
    The Black Mamba
    Snek
    DFW
    Imma keep it stock
    Actual OEM or just generic Denso?
  21. Jan 22, 2024 at 2:40 PM
    Your mechanic should know this already. Each sensor has an ID printed on it, usually in hexadecimal format (IIRC). The mechanic must program each sensor's ID into the TPMS ECU, as it is written on the sensor. If he didn't take pictures of that ID, he'll need a TPMS tool that can scan the ID off each sensor, many TPMS tools support scanning, then auto-writing (and/or replacing) the four new IDs into the TPMS ECU. Again, this is something every and any mechanic should know, hell my 13 year old is basically aware of how this system works, if your mechanic isn't, you really need a new mechanic. Even the high school kids working at the tire store know this.
    EDIT: The above is harsh. My 13yo knows how this works because I showed her one day with my smartphone app, the reading from the sensors, then showed her a short YouTube video on TPMS system and how it functions, she was interested. But I'm very serious when I say, this is literally basic knowledge for any professional mechanic, so if your guy didn't erase the old TPMS sensor IDs and replace with the new IDs, or clone old to new (if possible), then ... that's pretty messed up dude.
    flyfisher and The Black Mamba like this.
  22. Jan 22, 2024 at 2:42 PM
    Trueno
    Will
    2006 Sr5 Dbl Cab
  23. Feb 5, 2024 at 7:21 AM
    Trueno
    Will
    2006 Sr5 Dbl Cab
    End result. The tire pressure monitors were an odyssey but my guy sorted it out.
  24. Feb 6, 2024 at 8:12 AM
    Tundruh
    Tundruh New Member
    Tony
    VA BCH
    2005 Tundra Access Cab 4x4
    I agree. I did the 07 Limited 4Runner wheels. I just need better tires. Just not sure what size, except going 275 or 285/70x18
  25. Feb 6, 2024 at 8:33 AM
    The Black Mamba
    Snek
    DFW
    Imma keep it stock
    I'm running 285/75R16
  26. Feb 7, 2024 at 9:03 AM
    Canada SR5
    Canada SR5 New Member
    Lukas
    06' 4.7L AC 4x4 and 08' 4.7L DC RWD
    20240207_113645.jpg This little light of mine, i am gonna let it shine.
    Elevatorguy likes this.
  27. Feb 7, 2024 at 10:26 AM
    If it's flashing, I got mine to go away and not come back in about 3 minutes using an OBD dongle. If it's solid, you just need air in your tires.
  28. Feb 7, 2024 at 11:37 AM
    Canada SR5
    Lukas
    No sensors, light flashes. I don't even notice the light anymore lol
  29. Feb 7, 2024 at 1:42 PM
  30. Feb 7, 2024 at 3:52 PM
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    James
    05 DC, 4.7, 4wd, LSD.
    Mine is solid and doesn’t need air. I don’t have sensors in the wheels.
