‘14 TSS FRONT END SHAKING-HELP!!!
Discussion in 'General Tundra Discussion' started by Sharla001, Dec 30, 2023.
  1. Dec 30, 2023 at 4:41 PM
    Sharla001
    Sharla001 [OP] New Member
    Tony
    2014 Thunder
    None
    Hello,
    My trucks front end has started shaking. At first it would slightly shake when you started to slow down. Now in addition to that at times when driving it will start shaking.
    Any idea what this is? Was thinking maybe the wheel barrings or maybe upper control arm. Help!!
    Any ideas??
    Please let me know any help would be appreciated
  2. Dec 30, 2023 at 4:41 PM
    Is this happening with the brake being applied or without? (Or both)
  3. Dec 30, 2023 at 6:27 PM
    Sharla001
    Tony
    2014 Thunder
    None
    Starts when being applied then when let off the brake it slacks. And then through traffic I can let off the gas and it will start shaking before brake is applied.
  4. Dec 30, 2023 at 6:33 PM
    Are your rotors warped or bent? How are the pads?
  5. Dec 30, 2023 at 6:53 PM
    Sharla001
    Tony
    2014 Thunder
    None
    The pads are in good shape. The rotors were replaced a year ago. Was leaning towards brakes but not now. They are good
  6. Dec 30, 2023 at 10:01 PM
    Sharla001
    Tony
    2014 Thunder
    None
    Any idea what could be going on? Where would be an ideal
    Place to take it and have it looked at besides a dealership?
  7. Dec 30, 2023 at 10:05 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Check bearing and tie rods play
  8. Dec 31, 2023 at 10:46 AM
    Sharla001
    Tony
    2014 Thunder
    None
    How do we check those? Not sure what I am looking at?
  9. Dec 31, 2023 at 11:02 AM
    tarathetundra
    tarathetundra New Member
    Nate
    2018 white CM
    37x13.50R18
    You can check the play by jacking up the truck. The side you are checking will need to be lifted off the ground grab the tire horizontally pull and push the wheel if play here it’s most likely tie rod, now do same process with hands placed vertical and push pull if movement here it’s going to be wheel bearings. I think Chris fix on YouTube has a video explaining this. Good luck
  10. Dec 31, 2023 at 12:04 PM
    Sharla001
    Tony
    2014 Thunder
    None
    1. Awesome thank you we will give that a whirl.
  11. Dec 31, 2023 at 12:33 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Tire rotation, front to back see if it’s goes away. That will tell you if your tire is out of balance or rim are bent.
    Check for stuck calipers or slide pin while you got the truck in the air
