Can the serpentine belt be tightened on 2015 4.6L
Discussion in 'General Tundra Discussion' started by dpitman1, Dec 31, 2023.
  1. Dec 31, 2023 at 3:33 AM
    dpitman1
    dpitman1 [OP] New Member
    2015 Tundra Crew Max
    My serpentine belt began squealing upon start-up about a yr ago. Sprayed some dressing on it and fixed the issue for a few weeks. Then had the belt replaced....but more squealing.
    Took it to a different shop and had belt replaced again because it was not aligned properly and I thought it may have been damaged...also had tensioner replaced....STILL squealing....
    Mechanic said it may be the build up of dressing causing it....applied degreaser & power-washed.....NOPE...still squeals.
    Been to 2 shops....5 total visits....pulling my hair out!
    Any suggestions? Can the belt be tightened? Are the mechanics just idiots?
    Ive spent $700
    Thanks
  2. Dec 31, 2023 at 5:23 AM
    gnatehack
    gnatehack New Member
    Middle of Minnesota
    13 SR5 5.7 4x4 Bench
    Up to date maintenance
    Your squealing could be a bearing instead of a slipping belt especially since you've tried many fixes.
    Lots of rotating things on the front of our engines in addition to the belt tensioner: idler, water pump, fan pulley, PS, AC, alternator.
    dpitman1[OP] likes this.
