Headlights switch
Discussion in '1st Gen Tundras (2000-2006)' started by Edtuma, Dec 28, 2023.
  1. Dec 28, 2023 at 10:02 PM
    Edtuma
    Edtuma [OP] New Member
    2003 white tundra sr5
    My 03 tundra has weird headlights, the bottom image is when I turn the light switch once, the middle image is when I switch it twice and the very top image is when my high beams are on. Is there a way I can wire it to make the main headlights and side lights turn on in the first switch like in the top image? Cuz I don’t like those side light being on by themselves.
  2. Dec 28, 2023 at 10:06 PM
    Those are your “parking lamps”. Every car I’ve ever owned has functioned that way, what’s weird about it?
    GeezePlease and The Black Mamba like this.
  3. Dec 28, 2023 at 10:19 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    Hi there Edtuma, welcome to the forum.
    Your question is quite a unique one for sure. The easiest thing would be to simply turn the headlight switch to the second click (to where both your parking and low beam lights are on). Yes it might be frustrating and aggravating to do, but it will only be for a split second. Every tundra owner in the world has to deal with the same thing, so hang in there! Here’s one idea that might help..maybe close your eyes for that split second while you turn the light switch all the way to where the low beam turns on? Other than that it will most likely you’ll need your truck’s wire diagram, soldering iron, and some quality TXL wire.
    The Black Mamba likes this.
  4. Dec 29, 2023 at 3:41 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    (Bottom pic) First turn, marker lamps on (this includes tail and tag lamps.
    (Middle pic) Second turn, previously mentioned lights will remain on, low beam bulbs on and because you have the fog lamp switch turned to on, fog lamps are on.
    (Top pic) Push the left stalk forward with the switch turned to the second notch and low beam filament turns off, fog lamps turn off and high beams turn on. All remaining lights from the first turn will still remain on.
    Working as designed.
    That’s how the Toyota and just about every other manufacturer has had their lights and switches configured for at least the last 50 years.
    ATBAV8, Edtuma[OP] and whodatschrome like this.
  5. Dec 29, 2023 at 6:52 AM
    I see the fogs on in the 2nd pic. Did you install LED headlights and not realize the problems that happen with LED headlights? Or dou you have the fog light switch ON also?
  6. Dec 29, 2023 at 7:28 AM
    Edtuma
    Ok that makes sense, my guess was that since the truck was involved in a minor accident from the front, that whoever fixed it must’ve wired it wrong, but you cleared my suspicions, thank you
