Trd intake
Discussion in 'Performance and Tuning' started by Jeezluiis, Dec 28, 2023.
  1. Dec 28, 2023 at 5:46 PM
    Jeezluiis
    Jeezluiis [OP] New Member
    Can a 2007 5.7l tundra install the trd intake without any problems. Not sure this option was out for it this year. ? If anybody has experience with this could chime in please thank you.. :)
  2. Dec 28, 2023 at 5:56 PM
    It's a waste of money. Your stock setup is already a cold air intake.
  3. Dec 28, 2023 at 6:04 PM
    IIonPilgrimg
    IIonPilgrimg New Member
    2008 Tundra Limited Double Cab 4x4 5.7 6-speed Red Rock
    My 2008 Tundra 5.7L has it since new: Can't imagine it wouldn't fit your 2007 also.
  4. Dec 28, 2023 at 6:05 PM
    LATERAL G
    LATERAL G New Member
    2013 RCSB SR5 TRD Off-Road 5.7 4x4
    yes it will work you just need to make sure you get one for the 07-13. 14+ is a different setup
    Jeezluiis[OP] likes this.
  5. Dec 28, 2023 at 6:23 PM
    Once again....waste of money and purely cosmetic. Look into the SABM.
  6. Dec 28, 2023 at 7:42 PM
    dirtydeeds
    Keith
    USA
    more than I can list here
    Good advice. I’ve tested a ton of intakes. None make power on 1st or 2nd gen tundras.
    3rd gen is a different story!! Tons of power with turbos!!
    that said, stock air box mod, or sabm…. I second this advice!!
    Rica25, roughfisher, T-Rex266 and 3 others like this.
  7. Jan 1, 2024 at 6:49 PM
    JaxJacket
    JaxJacket New Member
    21 DC
    How about with a supercharger? Picked up a full pound of boost on a supercharged Tacoma going to an afe. How about the tundra?
    dirtydeeds[QUOTED] likes this.
  8. Jan 1, 2024 at 7:41 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Supercharged tundras benefit from the larger intake and sabm but the intake is a mix depending on the blower. The one to have is the magnuson airbox. The airbox benefit for us also related to the larger tube for the maf voltage
    dirtydeeds, Saltyhero13 and Mdl like this.
  9. Jan 2, 2024 at 7:40 AM
    dirtydeeds
    Keith
    USA
    Anytime you make an intake improvement when supercharged, you’re making an improvement in power.
    That said, you’ll typically have to retune the ecu when changing intakes on a supercharged truck. The mass air meter calibration is based on the intake diameter. Without a retune afr, shifting, etc. will be incorrect. Your truck will drive poorly and potentially have engine damage.
    Rica25 and reywcms like this.
  10. Jan 2, 2024 at 8:51 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    What blower + pulley are you running or planning to run? What power levels are you looking to achieve?
    It depends on what is the restriction before your blower is; filter + intake + throttle body.
    I haven't seen anyone in the supercharger thread identify the filter as a restriction, yet...
    Certain pulley+blower combos come close to maxing or are maxing out their stock intake diameter MAF readings, Harrop + 80mm is one example.
    Gains to be had matching or exceeding your intake and TB vs blower opening.
    nobodyintexas and reywcms like this.
  11. Jan 2, 2024 at 6:55 PM
    JaxJacket
    21 DC
    That sounds like the way to go. Didn't realize the magnuson came with larger box and tube. Thanks.
    Rica25 likes this.
