*DRIVER SIDE GRAB HANDLE RAM PHONE MOUNT*
Discussion in '2.5 Gen Tundras (2014-2021)' started by Teegee, Dec 28, 2023.
  1. Dec 28, 2023 at 7:05 PM
    Teegee
    Teegee [OP] Around
    Grouch
    21 MAX
    I did this mod to my Tacoma years ago. @G.T. On TW has a great thread on it. I could not find anything to do this to our Tundras. So here is what I came up with.
    This will work for anyone adding the grab handle with the 1/4” bottom bolt needed for the install. This will also work for early 2nd gens with the handle already factory installed however you need to figure out the correct metric bolt size. This isn’t the cheapest phone mount but it doesn’t block windshield or side mirror and clears the vent. No stick on stuff or magnetic BS. It’s really in a great spot and you can make numerous adjustments. I spent about $70 total.
    Parts-
    1/4 x 20 x 3 Cap hex bolt ( I used stainless)
    1/4 ID x 5/8 OD x 3/4 long spacer ( I used aluminum)
    Thin 1/4 washer
    Ram mount universal bar mount 1” ball
    For the phone mount I used the following-
    Ram medium coupler
    Ram small coupler
    Ram 1” ball extension
    Ram quick grip phone mount
    I mounted the quick grip upside down. It is easier to load the phone in where I have it located.
    Once you have the hardware in you can use numerous different phone holders or mounts. This stuff is all available at hardware store, Amazon, or Ram mounts so I’m not going to post links.
    If anyone comes up with other ideas please post here.
    Disclaimer- I’m not responsible for you stripping bolts, adding handles, crashing cause you’re looking at your phone etc etc. Do this at your own risk—
    08A1431C-A6CB-4E8A-889F-5AC3DFC4500A.jpg 72E9DDE7-2A6E-4D7C-9DE5-E496A105A181.jpg E0514DFA-FB1F-47AF-9E5A-94ACF01FEB21.jpg
  2. Dec 28, 2023 at 7:05 PM
    Teegee
    Teegee [OP] Around
    Grouch
    21 MAX
    Pic of actual truck used
  3. Dec 29, 2023 at 4:13 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Looks pretty sweet! If I ran this, I’d probably turn that twist handle on the small arm towards the windshield.
    Was going to run it upside down as well, but was told the spring compression can get loose over time due to bumps and what not.
    Droptarotter and Teegee[OP] like this.
  4. Dec 29, 2023 at 9:50 AM
    Lassie
    Lassie New Member
    HKM
    TAMPA, FL
    I did the same in my previous Tundra!!
    Teegee[OP] likes this.
  5. Dec 29, 2023 at 1:54 PM
    Teegee
    Teegee [OP] Around
    Grouch
    21 MAX
    Nice! Thanks for the heads up on the quick grip
    pvn.beluga[QUOTED] likes this.
  6. Dec 29, 2023 at 4:11 PM
    Droptarotter
    Droptarotter New Member
    2020 Tundra TRD Off Road, Double Cab
    That's a great idea and I think I have enough Ram bits to make this happen.
    Stock metric bolt is 6mmX1.5mm pitch.
    Only thing I wonder about is if that will affect the side airbag?
    Cheers
  7. Mar 20, 2024 at 5:45 AM
    wiseboat
    wiseboat TBD
    2021 Tundra TRD Pro
    I found this video that put me at ease: Toyota Tacoma Driver Side Grab Handle Airbag Concerns
    Key points were:
    1. It's a side curtain airbag meant to come out alongside the window between the pillar trim and glass window, creating the curtain between.
    2. The passenger side if there was a safety issue would have the same issue.
    I found it compelling but obviously you can decide.
    Droptarotter[QUOTED] likes this.
  8. Mar 20, 2024 at 5:46 AM
    wiseboat
    wiseboat TBD
    2021 Tundra TRD Pro
    @Teegee I'm wondering if there is enough room in the mounting point to sneak some cables into - I'd love to do same mount but have the cradle have a wireless charging component.
  9. Mar 20, 2024 at 6:02 PM
    2020 dc
    2020 dc New Member
    2020 tundra dc sr
    Did you get the 1/4 ID x 5/8 OD x 3/4 long spacer from Lowes or Home Depot?
  10. Mar 20, 2024 at 6:39 PM
    Florida AF
    Logan
    North Florida
    There was not when I did mine. So I just have a long USB going across my dash.
    Nice write up OP. I think there was another one floating around somewhere, but I only posted a couple pics when I did mine.
    wiseboat[QUOTED] likes this.
  11. Apr 4, 2024 at 1:57 PM
    TundyManFL
    TundyManFL New Member
    2021 MGM TRD Pro CrewMax
    I'm also interested in seeing if I can get a charging mount here and found this linked off the TW thread from GT that OP mentions above:
    https://www.tacomaworld.com/threads/gps-install-hardwired-to-the-a-pillar.305904/
    There's one photo in particular in the linked thread where it looks like I could drill a hole in the lower mount point on the pillar that would normally be obscured by the handle and then there's enough space in the matching point in the grab handle (or after a little bit of drilling) to snake a wire through, position it so its secure and away from air bag, and then run it on down to the fuse box left of steering.
    Looks like most people do the add-a-fuse options on an existing fuse to power it - I'm wondering if I want to use a MagSafe charger (to fast charge iPhones at max speed) if I need to add anything special. In @RainMan_PNW's thread on his custom MagSafe tray he used one of these (https://www.amazon.com/dp/B09D98799T).
    Still trying to find handle and pillar at a good price but leaning towards giving this a shot.
  12. Apr 4, 2024 at 2:41 PM
    TundyManFL
    Just realized one tricky bit would be getting the USB plug side of the MagSafe charger through the handle and pillar without cutting/drilling a bigger hole. I think the example was probably using a smaller DC male jack.
