285/70R18 on 18x8 Stock rims??
Discussion in 'Wheels & Tires' started by Marcos65, Dec 27, 2023.
  1. Dec 27, 2023 at 2:33 PM
    Marcos65
    Marcos65 [OP] New Member
    Marcos
    Curacao, Dutch Caribbean
    Black 2008 Tundra
    I've been reading alot to figure out if I can put 285/70R18 tires on the stock 18x8 rims of my 2008 Tundra, and my conclusion is YES I CAN. However... just before ordering the Kanati Terra Commander 285/70R18 tires, I noticed that this tire spec indicates a minimum 8.5" rim width.
    I am very very interested to know what you think about this. Can I ignore and order the 285/70R18's or should I head the warning and go for the Kanati Trail Hog 275/70R18, which specifies 7-8.5" rim width?
  2. Dec 27, 2023 at 4:37 PM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    Not enough to worry about. Pulls the sidewall slightly out beyond what the manufacturer says is ideal but it’s not unsafe and I’d bet if you looked at the tires spec sheet is gives 1/2 - 1” either way. That’s an 11” width tread. Just looked it up. No worries.
    Marcos65[OP] and CaptRussia253 like this.
  3. Dec 27, 2023 at 5:48 PM
    Marcos65
    Marcos
    Black 2008 Tundra
    Yeah, I just needed some affirmation. Thank you very much. It is much appreciated!
    Cruiserpilot likes this.
  4. Dec 28, 2023 at 12:18 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    stock wheels work great for 285/70 as well as 285/75
    Marcos65[OP] and biebs96 like this.
  5. Dec 28, 2023 at 12:29 PM
    blenton
    blenton New Member
    Specs for the tires I've looked at in that size say approved rim width is 7.5-9", so an 8" wide factory rim is great. Now...
    :worthless:
    Marcos65[OP] likes this.
  6. Dec 28, 2023 at 12:39 PM
    AZBoatHauler
    So.Arizona
    That’s what I’m currently running. Will move to 285/75-18 next time.
  7. Dec 28, 2023 at 12:44 PM
    biebs96
    PA
    Yes, to confirm what others are saying they will fit, along with 285/75/18 on stock wheels.
    ^285/75/18
  8. Dec 28, 2023 at 6:10 PM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    ^^^^^Nice looking truck. Good colour. J
    biebs96 likes this.
