When's the last time you lubed up?
Discussion in 'Suspension' started by texasrho83, Dec 28, 2023.
  1. Dec 28, 2023 at 11:01 AM
    texasrho83
    texasrho83 [OP] Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    That's right everyone's favorite pastime...
    Lube jobs.
    I'm having the devil of a time getting to the zerk in the front driveshaft closest to the T-case. Any suggestions?
    I've got 2 gun tips in addition to the original one. A 90° and coupler lock (the kind that grips the fitting to allow both hands on the gun).
    Thanks and always remember to lube regularly.
    reywcms likes this.
  2. Dec 28, 2023 at 11:21 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    If you move the little heat shield out of the way it’s easy.
    texasrho83[OP] likes this.
  3. Dec 28, 2023 at 12:48 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Well, I don't think that'll help me. Here is what I'm looking at:
  4. Dec 28, 2023 at 1:18 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Have you tried spinning the driveshaft to see if you can get a better angle/access?
  5. Dec 28, 2023 at 1:22 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    On my 17 there’s a small heat shield towards the driver side. 2 12mm bolts if I remember correctly. With that shield out of the wat it’s an easy shot to that zerk.
    I’ve also used the angled attachment and cursed and right before I quit it latched on and worked. I got the “remove heat shield “ advice off this site and it worked.
    A couple more bolts to remove but it made a big difference.
    just throwing out options that worked for me.
  6. Dec 28, 2023 at 1:22 PM
    Us first gens just grind down the tip of a regular zerk coupler and it gets in there
    KNABORES likes this.
  7. Dec 28, 2023 at 1:49 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yes.
  8. Dec 28, 2023 at 1:51 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    The end of the coupler isn't the issue. It's the length. The part of the coupler closest to the gun hits the trans mount.
  9. Dec 28, 2023 at 1:53 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    The only way I’ve gotten to that one is when it’s pointed to the drivers side of the truck.
  10. Dec 28, 2023 at 4:19 PM
    TRXTER
    TRXTER New Member
    Allan
    Ontario, Canada
    2015 5.7L Silver Sky Metallic Tundra 1794
    Just getting started.... Start X remote starter.
    Hi there, we all feel the pain and the sigh when we goto do this fitting. I bought the lock n lube off Amazon, pricey but it works for me with no heat shield to remove. I put my head at front of truck feet towards the rear. Rotate the drive shaft so fitting can be barely see at its 11 o'clock position the way your looking up at it. You will barely see it sneaking a peak by leaning head towards passenger side. I am able to sneak the lock n lube up in there clamp on and pump away. I have a 24" flex line on my grease gun. I hope this works for you. One other note: I still curse it !! One further thing I did, not that I expect to break a u joint, I have gone ahead and marked the multi piece drive shafts in reference to each other with a paint marker for reference points. This way if they ever seperate and come apart I know exactly how it was lined up before to avoid any balance issues. Call me paranoid
