Unique heated seat question
Discussion in '2.5 Gen Tundras (2014-2021)' started by Zipper2014, Dec 27, 2023.
  1. Dec 27, 2023 at 3:05 PM
    Zipper2014
    Zipper2014 [OP] New Member
    I have a 2014 Tundra Limited. When I bought it used, the previous owner had removed the OEM stereo and climate controls and replaced it with an aftermarket touch screen unit. There are no instructions online for the aftermarket touchscreen unit and there is no switch or option to turn on the heated seats (I've looked for an hour). I've confirmed that my seats definitely have the OEM heater pads, but I need some way to turn them on and off. The Toyota heated seats work with a CPU module under each seat which is controlled by the Climate control switches.
    So I have a couple questions.
    1. Is it even possible to wire up manual switches? Meaning, is the OEM climate control console absolutely necessary to control the heater coils on the seats?
    2. Does that under seat control module work with other Toyota model seat heater switches (e.g. I also have a 2019 highlander with manual roller switches (not in a climate control console), and the under seat control module.)
    3. Does anyone know how to use the OEM wiring to install aftermarket rocker switches to control the OEM seat heaters?
    4. Does anyone have the wiring diagram which explains the wires in more detail? (I've seen a couple diagrams, but none that show which wires do what.
    I've checked with multiple local companies and none of them will touch this. They suggest ripping out the perfectly good seat heaters and doing a total replacement.
  2. Dec 28, 2023 at 4:31 AM
    DCRB4X4
    DCRB4X4 New Member
    BLACK 2015 DCRB SR5 4X4
    5100's front, spacer rear
    I only have your questions to go by to judge your level of electrical knowledge. My suggestion would be to return to a stock head unit if you want heated seats. It can be done keeping the current head unit, but you need a way to communicate to the modules under the seat in a manner that they can accept. You may be able to find a head unit to do this. I would avoid "engineering" an untested solution. Heated seats can be a fire hazard if not properly controlled.
    Someone with more specific knowledge feel free to chime in, I could be totally wrong.
    Back ground= Industrial Electrician, Heavy Equipment Repair since 1985
    Good luck
  3. Dec 28, 2023 at 4:52 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    You should find all the answers to your questions in this thread:
    https://www.tundras.com/threads/seat-heater-install.57912/
  4. Dec 28, 2023 at 5:37 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    You should be able to trace the wiring for the heaters….cut and splice in dash switches
