What’s wrong with my truck? video inside
Discussion in '2nd Gen Tundras (2007-2013)' started by Mattyc, Dec 27, 2023.
  1. Dec 27, 2023 at 8:54 PM
    Mattyc
    Mattyc [OP] <insert custom title>
    Matthew
    NY
    2008 Limited Rock Warrior
    Not stock
    Is this the symptom of a wheel speed sensor? No rhyme or reason as to when it happens. Sometimes doesn’t happen for days, other times it’s multiple times a day. Any help? If you can’t see the traction control
    Light is rapid flashing
    https://youtube.com/shorts/OCrlL9PSNOM?si=WRxoS-MibCRN_KUc
  2. Dec 27, 2023 at 9:14 PM
    blenton
    blenton New Member
    It could be a wheel speed sensor, but I’m not an expert. they often trip a few other lights when they go bad. A good obd2 scanner that can read more than a CEL can read body modules and tell you if a sensor is having issues.
    Is your truck 4wd? If so, are you having issues engaging 4wd? Check the wiring to the rear speed sensors for breaks or corrosion.
    PhotoNerd likes this.
  3. Dec 28, 2023 at 4:16 AM
    Mattyc
    Matthew
    NY
    Not stock
    There are no codes. Dealer said “we can’t replicate it. Wait until it gets worse”
