Payload help on my tundra
Discussion in 'Towing & Hauling' started by Samtundra30, Dec 27, 2023.
  1. Dec 27, 2023 at 9:59 AM
    Samtundra30
    Samtundra30 [OP] New Member
    Sam
    Tundra 5.7L SR5 Crewmax 4x4 2019
    Level kit
    Hello all! New to the forum. I have a 2019 SR5 5.7L crewmax. It has a level kit. I’m looking to give it some payload assistance and to tow a travel trailer in the 4-7,000lb range.
    im looking to add a blue ox WDH and E range tires and a TRD rear sway bar (since I’ve read they’re recommended). What else would yall reccomend? I want to drive good with and without trailering anything and still have off road capability without a trailer. This is mostly for hunting out west and being able to tow a trailer as a base camp.
    should I do anything with the rear leaf? Do I need the rear sway bar?
    I definitely want to help out the tongue weight b/c my tundra is rated for 1560 payload and I want to be able to load up with gear and such.
    any other recs would be appreciated thank you!
  2. Dec 27, 2023 at 10:22 AM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    You don't require 10ply tires to tow a TT with a weight between 4-7K. With the right weight distribution hitch rated for the trailer and set up properly you don't need to do anything with the rear suspension. The added rear sway bar will make for a slightly better tow experience in heavy wind but you will probably not notice any difference.
  3. Dec 27, 2023 at 10:25 AM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I'll add to my post. Spend your money on adding a transmission cooler and tow mirrors.
    Mattedfred and HulkSmurf14 like this.
  4. Dec 27, 2023 at 10:31 AM
    Samtundra30
    Sam
    Level kit
    gotcha. I’m more considered about assisting with the payload I guess than the towing capacity for cargo purposes.
  5. Dec 27, 2023 at 10:38 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! The good news is that Toyota over-engineers their trucks. The bad news is that there is very little, and possibly nothing, you can do to increase the payload in a way that will pass muster if anything happens and the authorities start investigating your load configuration. I don't know of any way to have the payload numbers officially increased.
  6. Dec 27, 2023 at 10:41 AM
    Samtundra30
    Sam
    Level kit
    Makes sense. Not looking to necessarily increase payload, just looking to make it a more manageable drive and easier to tow.
  7. Dec 27, 2023 at 10:44 AM
    Samtundra30
    Sam
    Level kit
    What’s the hitch weight here on your setup if I may ask?
  8. Dec 27, 2023 at 10:58 AM
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    Is that 1560 a published number or the actual door sticker?
    The reason I ask is that I have essentially the same truck as you (2019 Crewmax SR5 4X4 5.7) and my door sticker is under 1300 lbs.
    I do have the TRD OR package but I wouldn't thingk that would be hundreds of lbs. reduction.
    The good news is that my stock truck performs wonderfully with nothing more than my Andersen WDH towing my 5,500 lb. trailer.
  9. Dec 27, 2023 at 11:00 AM
    Samtundra30
    Sam
    Level kit
    I’ll have to double check the sticker. Thanks for pointing that out. What about payload? Any issues? I obviously wanna take my wife and kid and dog.
  10. Dec 27, 2023 at 11:02 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    the 4-7k camper isn't a concern. It'll be you maxing out payload that happens first. You're going to want to know the weight of all of your gear and passengers combined. Then subtract that from your payload capacity. Then that's what's left for camper payload. Everything adds up including a WDH, battery, propane etc. Having 3 guys in the truck with you can already take out 600lbs of payload. Add in another 300lbs of gear, now you're at 900lbs leaving you witch 600lbs worth of payload left for the camper itself (using your 1500lbs payload estimate).
    Samtundra30[OP] likes this.
  11. Dec 27, 2023 at 3:32 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Tires and suspension will not increase the payload of your truck. Look on the door jam and there is a yellow sticker that will give you what your truck is rated for. If your at 1200lbs payload subtract your tongue weight from the trailer, the weight of any accessories you have installed and the weight of the passengers and cargo. If your added up value is over the door jam number you are over payload, unlikely on a trailer under 7000lbs but you still need to do the math.
  12. Dec 27, 2023 at 3:38 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Lots of great towing threads in here https://www.tundras.com/forums/towing-hauling.53/
    Good luck!
  13. Dec 27, 2023 at 4:38 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    RAS, Supercharger and a bag of jerky!! You'll experience the most smiles a half ton can muster!!
  14. Dec 27, 2023 at 7:06 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Rear sway bar
    High quality Weight Distributing Hitch - the kind with bars, not with chains - set up by a reputable hitch shop, not by your RV dealer.
    Weigh your setup when it's fully loaded. Use a hitch scale to make sure your tongue weight is 10-15% of your trailer weight.
  15. Dec 27, 2023 at 9:56 PM
    SD Surfer
    Bruce
    So Cal
    No issues... My trailer is pretty light @ 5,500 lbs GVWR, and I'm pretty close to that most of the time I tow.
    My Lance has quite a bit of storage and I load what I can in there. I also tow with a full fresh water tank; I know the water quality at my house, and I prefer how it handles with some tongue weight.
    I'm almost always close to, if not occasionally a few pounds over payload, but I keep it as close as possible. Popular opinion is that our Tundras are overbuilt a bit.
    Of course all my happy campers have to come too!
  16. Dec 28, 2023 at 12:44 AM
    Zoso
    Zoso New Member
    SE Georgia
    2021 Cement DC LTD
  17. Dec 28, 2023 at 12:45 AM
    Zoso
    Zoso New Member
    SE Georgia
    2021 Cement DC LTD
  18. Dec 28, 2023 at 4:05 AM
    Retired...finally
    Load your trailer and TV as if you are headed out on your trip before you install/adjust the WDH. Make sure the WDH is properly sized for your trailer GVWR. A friend of ours towing a 4,400 GVWR trailer with a Silverado showed me a written estimate from Camping World to install a 10,000# Fastway E2 WDH. Had she not come to me for advice her trailer A frame most likely would have bend in short order.
