Power ports in console stopped working
Discussion in '2nd Gen Tundras (2007-2013)' started by Borderlander, Dec 25, 2023.
  1. Dec 25, 2023 at 7:22 AM
    Borderlander
    Borderlander [OP] New Member
    2008 TRD
    The cigarette style power ports all stopped working. I looked at the wiring diagram someone posted earlier and see that all three (dash, in console compartment and on the back end of the console). The cigarette lighter works...it is on a different circuit.
    I checked the fuses for this circuit and they are good.
    Does anyone have any ideas what might have caused this? I am including the wiring diagram page for this circuit.
  2. Dec 26, 2023 at 7:32 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Check the power relays. I don't think there is a way to see if they're bad, you're gonna have to test them. An additional point to check before you replace the relays is check that grounding point and see if they're loose or corroded, if it is, then there is your answer.
  3. Dec 27, 2023 at 9:15 AM
    Borderlander
    2008 TRD
    I was wondering about the relay myself. Thanks suggesting that.
    I had a shop put Katskin seat covers in and he added seat heaters so I took the console apart to see if he might have done something that caused the problem but everything looked good.
    I will check the relay theory out...thanks.
    Andy
