10w40 motor oil
Discussion in 'Performance and Tuning' started by Tundraman17, Dec 27, 2023.
  1. Dec 27, 2023 at 7:42 AM
    Tundraman17
    Tundraman17 [OP] New Member
    Kentucky
    Toyota tundra 4x4
    None
    Still new to the tundra family. Will 10w40 full synthetic motor oil be ok to run in my 2017 5.7 tundra? Just not a big fan of 0w20. I pull trailers every now and then and 0 weight oil just doesn’t seem to be a good weight of oil if you use your truck. Any info is appreciated.
  2. Dec 27, 2023 at 7:50 AM
    ChesterTundra
    ChesterTundra New Member
    Central FL
    2020 Tundra SR5
    RCI Alum skids w/cat guards Leveled and AT Cooled SPD Performance exhaust Amsoil everywhere…
    0w is the cold viscosity, so the advantage there is better circulation during a cold start. At temp, it’s 20 weight viscosity. I’d check the manual for severe duty and temperature ranges before switching that to 40. I’ve read about vvt engines using oil pressure to adjust cam timing, so too thick might cause problems.
  3. Dec 27, 2023 at 8:18 AM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    5W30 is the sweet spot.
    blenton, CMikeB, HulkSmurf14 and 8 others like this.
  4. Dec 27, 2023 at 8:25 AM
    pursuit2550
    pursuit2550 New Member
    Do a search. The 5.7 can use up to 20w50 believe. You're in Kentucky so a 0/5w would be good for the winter. In the summer run a thicker oil. These engine sound like diesel on thin oil. It's all because of the EPA/CAFE standards. Thicker oil will no cause any problems, I prefer it better than the watered down 0w20 actually.
    FabioXc, Gene_in_FL, Mdl and 2 others like this.
  5. Dec 27, 2023 at 9:11 AM
    CaptRatBoy
    CaptRatBoy New Member
    Somewhere around 2500' Western Blue Ridge, NC
    Capeable, extensively modified, 2016, Limited, 4 x4 Tundra Off Road, 3td. one
    Got absolutely nothing else to do with your time just run a "search" on oil recommendations in the forums. It'll provide ya with hours of pointless discussions, some actually backed up in fact. Bottom line .... Just change your oil and change it often!
  6. Dec 27, 2023 at 9:48 AM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    This is a 12 min vid that's absolutely worth taking the time to watch. Actually, it's worth watching a few times. Much more valuable and informative than any input from the peanut gallery.
    https://youtu.be/IKdhgKUZhPA?si=_9DsSmgHiZ9SqsyA
  7. Dec 27, 2023 at 10:03 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    "... but I've seen studies showing that going from a 30 to a 20 could result in over 1 percent increase in efficiency ..."
    All you need to hear and keep using your old trusty high viscosity oil.
    Cpl_Punishment, Hbjeff and Hugemoose like this.
  8. Dec 27, 2023 at 10:17 AM
    pursuit2550
    Well since he said to ALWAYS, ALWAYS, ALWYAS use what's recommended in your owner manual and not the input from the peanut gallery. What oil should we use? Post 64 from this thread shows oil viscosity that can be use from the service manual. So in the US I guess oil acts different in the 5.7 than in Mexico.
    https://www.tundras.com/threads/what-grade-oil-changes-after-20k-miles.129534/page-3#post-3313154
  9. Dec 27, 2023 at 10:19 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    In FL I'd switch to 10w40 or at least 10w30 year round.
    Mdl likes this.
  10. Dec 27, 2023 at 10:19 AM
    Hugemoose
    Hugemoose New Member
    Philly
    2016 Tundra Crewmax
    Not enough....
    The video posted above certainly does explain it very well. That said, 5w-30 IS the recommended oil viscosity for the 5.7 everywhere else except the US. Below is the owners manual from a vehicle with the 5.7 (3UR-FE) that is outside of the US.
    84c2bceb-8885-46b7-b369-6f278ca6b5b2-png_628817461de779c1318c7d710cfc1f4d76ac34f3.png
    I personally use 5w-30, however if you want some thicker oil still find a 5w-40. You'll get the best of both worlds.
    And from my own experience in other vehicles (Subaru's), I have seen excess oil consumption, ex: 1 quart per 900 miles, using 0w-20. After simply switching to 5w-30 that has significantly improved. Manufactures may trying to say oil consumption is expected and within range, but their estimates are, in my opinion, insane. And from first hand experience, thinner oils cause nothing but issues, and not worth the fraction of a percentage in efficiency.
    Get the thicker oil and change it often. You'll be fine.
  11. Dec 27, 2023 at 10:20 AM
    pursuit2550
    I use 5 or 10w30.
    Mdl and vtl[QUOTED] like this.
  12. Dec 27, 2023 at 10:24 AM
    pursuit2550
    That's what confuses people. They think that if they dont use 0w20 their engine will blow up. But yet in Mexico, you can use all the way up to 20w50. Its all because of the EPA/CAFE standards. Just like the 10k oil changes. Another lie from them. 5k max.
  13. Dec 27, 2023 at 10:39 AM
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    It discusses temp ranges (and load). Doesn't say to use any oil from 0w20 - 20w50, based on gut feelings. Kentucky, Alberta and Mexico are all very different.
    Cerebus, ViktorG and Cpl_Punishment like this.
  14. Dec 27, 2023 at 10:43 AM
    Hugemoose
    Philly
    2016 Tundra Crewmax
    Not enough....
    Exactly. Even more important than the viscosity is clean oil. I also do 5k changes on my truck, but do 3.5k on my Outback because that bitch still eats some oil!! lol But not nearly as much as it used it at least.
    My main issue with 0w-20 or 0w-16 isn't a engine wear problem, it's oil consumption. But as I stated, manufactures have crazy specs. Subaru and Toyota both officially state that burning 1 quart per 1-1.2k miles is acceptable. I'd really like to see how those 10k oil change intervals look when that happens.....
    I really like Engineering Explained on YouTube, but I don't think he covered the issue fully in that video. That's not a knock on him, just a topic that wasn't covered and I find to be the biggest issue.
    pursuit2550[QUOTED] likes this.
  15. Dec 27, 2023 at 11:05 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    and
    5w-30 is easier to change when the oil is hot.
    0w-20 comes out like water, when hot, and splashes EVERYWHERE.
    stop....just stop....yes,I just got the fumoto. and it's like a God send. my little piece of clear hose stays on the oil catch bucket thing and it now drains directly into it.
    Gene_in_FL, WFD473, Mdl and 2 others like this.
  16. Dec 27, 2023 at 11:11 AM
    pursuit2550
    So if a truck leaving Mexico with 20w50 enters Texas, what happens to the engine? This obviously the same temp and load on the truck. So why does Toyota not tell you you can use 20w50 or any other viscosity in the US if conditions warrant the use of it?
    WFD473, Retired...finally and Mdl like this.
  17. Dec 27, 2023 at 11:12 AM
    pursuit2550
    Now they are down to 0w8
  18. Dec 27, 2023 at 11:15 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Unless you live in damn cold area, disregard oil viscosity.
    it's all the same.
    Like @Jowett said. 5w-30 now, go in peace. we have assuaged you of one of life's quandaries.
    and...put don't put this much thought in your Trans oil....just use valvoline maxlife.
  19. Dec 27, 2023 at 11:23 AM
    Hugemoose
    Philly
    2016 Tundra Crewmax
    Not enough....
    Well they have to shoot for that EXTRA 0.05% efficiently over 0w-20!
  20. Dec 27, 2023 at 11:59 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Long years ago VW and Volvo said 1 liter per 1k km is okay.
  21. Dec 27, 2023 at 12:01 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Damn cold area above us on the map mandates engine block heater in every truck sold.
    nobodyintexas[QUOTED] likes this.
  22. Dec 29, 2023 at 12:36 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Yes, been running 5w30 since 2010. After the SC install I run 5w40 in summer. Ow8 0w16 just say No, I'm not doing it and I will not conform.
    HulkSmurf14 and nobodyintexas like this.
  23. Dec 29, 2023 at 4:52 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    agreed on the 40weight
    if Costco sold 5w-40. I’d be using it
    WFD473 likes this.
  24. Dec 29, 2023 at 7:00 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
  25. Feb 2, 2024 at 8:18 AM
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    I guess if ur truck is mexican u use what the mexican manual says
  26. Feb 2, 2024 at 2:20 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    ¿Mecánicamente hay alguna diferencia?
    pursuit2550 likes this.
  27. Feb 2, 2024 at 2:44 PM
    pursuit2550
    Yo pienso que Jack no save Jack mierrda!
    Saltyhero13[QUOTED] likes this.
  28. Feb 2, 2024 at 3:01 PM
    parkerbows
    Jack
    I actually do know jack shit. It was a joke.
  29. Feb 2, 2024 at 3:06 PM
    pursuit2550
    At least you know Spanish, Jack. Our sarcasm around here is something special at times. :cheers:
    Saltyhero13 likes this.
  30. Feb 2, 2024 at 4:42 PM
    parkerbows
    Jack
    lol
