2020 Toyota Tundra 5.7 dropped valve
Discussion in 'General Tundra Discussion' started by Big Dan, Dec 26, 2023.
  1. Dec 26, 2023 at 6:37 AM
    Big Dan
    Big Dan [OP] New Member
    2020 Tundra crew cab
    I've been reading about problems with the 5.7 V8 breaking valve springs and consequently dropping a valve causing complete engine failure. My question is, can all of the springs be replaced without removing the engine from the truck? I am considering a 2020 Tundra without any problems (so Far) and would want to replace all valve springs with aftermarket springs. I've read having the cylinder at TDC and filling the cylinder with compressed air, this can be accomplished. Any thoughts on this? Thanks
  2. Dec 26, 2023 at 6:41 AM
    Seems to be a pretty isolated occurrence. Are you wanting to proactively replace your valve springs? Not sure the juice is worth the squeeze.
    Silver17 likes this.
  3. Dec 26, 2023 at 6:49 AM
    Big Dan
    Not an isolated occurrence according to the youtube car care nut. Yes, considering all new aftermarket springs
  4. Dec 26, 2023 at 6:56 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Pretty sure that was only an occurrence on the 2007 model year.
  5. Dec 26, 2023 at 6:57 AM
    All hail car care nut! I wouldn't let a single source that posts content for money to get me tearing into my engine to replace something that is highly unlikely to fail.
  6. Dec 26, 2023 at 6:58 AM
    That was broken camshafts. Had a bad batch that affected several thousand VINs with quite a few actual failures reported. Identified and remedied pretty early on.
    Wynnded[QUOTED] likes this.
  7. Dec 26, 2023 at 6:59 AM
    Retired...finally
    Very well put.
    ZappBrannigan likes this.
  8. Dec 26, 2023 at 7:00 AM
    Silver17
    Northeast
    2017 TRD 4x4 Harrop SC
    I wouldn’t worry about doing anything preemptively for such a failure. It’s still rather uncommon and was more of an issue on 07-13s IIRC. Letting the engine warm up to operating temp before running it at higher RPMs is also important to preventing valve springs breaking.
  9. Dec 26, 2023 at 7:01 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Ah, I thought that it was valve springs, thanks.
  10. Dec 26, 2023 at 7:19 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I have an 07 5.7, haven't had major engine issues since I bought it in 07. Did hear about the dropped valves waaay back in the day, but in 287k+ miles I've only had basic maintenance issues with bits like: sparks, starter, water pump, radiator (collateral damage), brake pads and rotors. You can always go aftermarket springs, but in reality you'll just increase your chances of dropping a valve. Depending on mileage of the engine and whoever does the install. Quality of the springs would also come into question, OEM valves with a history of dropping you may have some recourse with Toyota Corporate, but an aftermarket option you'd be SOL on that front. I'm not here to convince you of anything, just bringing my .02.
    Terndrerrr likes this.
  11. Dec 26, 2023 at 9:45 AM
    Big Dan
    blackdemon_tt likes this.
  12. Dec 26, 2023 at 9:55 AM
    If you can find 5 examples of a 2020 3UR motor valve spring failing, then maybe go for it.
    koditten and Wynnded like this.
  13. Dec 26, 2023 at 10:10 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    That’s statistical noise for as many of these engines are on the road. I definitely wouldn’t bother replacing springs for all the aforementioned reason you listed earlier.
    Wynnded likes this.
  14. Dec 26, 2023 at 10:16 AM
    I wouldn't do it for a hundred examples and I doubt there are 5 examples of a 2020 motor failing for this. The whole thing is ridiculous to me. But OP seems concerned, I figure the only way to quell that is with new valve springs or proof his are fine.
