  1. Dec 24, 2023 at 8:16 AM
    Dakillacore
    Georgia
    I checked both sides and it seemed fine, but the crackling was present on the old tweeters as well. I had bought some OEM ones off of eBay to replace the first ones and used that harness connector for the JBLs, just in case. All 3 crackled at higher decibels is seems. But then again, I'm a major novice with this area.
    And I'll gladly take you up on that. Ill shoot you a message when I get all the supplies and we can figure something out that works best for us both. I'd much rather have the the master with me while it's done.
    Edit: it seems that the previous owner did upgrade the lower door speakers but not the headunit. I'm hoping they didn't screw around with anything ina bad way.
  2. Dec 24, 2023 at 8:31 AM
    IIRC, the DC with JBL has each speaker wired directly, and they’re all 2ohm. Chances are the woofer the PO installed is probably 4ohm which … who knows how the OEM JBL amp is going to respond to being under-loaded at half the amperage it was designed to expect.
    There are a few things possible. It could be PO replaced the woofers thinking they were causing the crackling. It could be he replaced the woofers with different amperage than what’s expected and it’s causing extra noise somehow. Or it could be the amp is already borked up, and generating noise, and that’s why the PO swapped the woofers. It could be the PO did something really f’n stupid with how they installed the woofers, maybe they wire-nutted the connections or something similarly stupid, and a nut fell off. You never can tell.
    Chances are they didn’t touch anything in the dash. I wouldn’t be too worried there.
  3. Dec 24, 2023 at 9:03 AM
    Dakillacore
    Georgia
    I took those woofers out just to check the back and it seems that the PO didn't screw around with the harness from what I could tell. But then again, I don't really know much of what I'm looking at on a deeper inspection, ha. I'm hoping that it's just the headunit that's going kaput.
    They are JBL branded woofers but I didn't get the model off of it when I was tinkering back there.
  4. Dec 24, 2023 at 10:16 AM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    Do you have resistors on the tweeters? Are they in place?
  5. Dec 24, 2023 at 10:30 AM
    Dakillacore
    Georgia
    I do believe that they did come with resistors. I'm not a smart man with this stuff but the tweeters do have a "package" wrapped up in-between the tweeter and the connecting wire section. This is what I'm talking about
  6. Dec 24, 2023 at 2:38 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    Badge update, think it'll fool anyone?
  7. Dec 24, 2023 at 4:20 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    NUDRAT[QUOTED] likes this.
  8. Dec 25, 2023 at 6:01 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
  9. Dec 25, 2023 at 6:41 AM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    :rofl::thumbsup:
    The Black Mamba likes this.
  10. Dec 25, 2023 at 2:32 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    Just my truck wishing y’all a merry Christmas!
  11. Dec 26, 2023 at 1:19 AM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    I bring gifts!!!
    New RockAuto discount code my dudes.
    253835322198778604
    Good thru January 26, 2024.
    oscardog86, bmf4069, NUDRAT and 8 others like this.
  12. Dec 26, 2023 at 12:10 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Boys I hit the rust belt lotto. Went into bleeding the rear brakes expecting to have to replace both wheel cylinders and lines because rust.
    A little heat and the bleeders backed right out. An expected day long job took me about 2 hours.
    Did find out my carrier bearing is trashed though.
    oscardog86, Voss, bmf4069 and 7 others like this.
  13. Dec 26, 2023 at 12:15 PM
    Carrier is cheap/easy enough to replace.
  14. Dec 26, 2023 at 12:20 PM
    Bleeder caps do wonders for keeping out rust (at least I’ve noticed). Just a PITA paying $2-3/each for them.
    oscardog86 likes this.
  15. Dec 26, 2023 at 12:39 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    Yeah this'll be the 2nd one. I replaced it shortly after I bought it in 2017, just didn't realize it was bad or I'd have ordered one from RockAuto when I ordered the rest of the stuff.
    Pretty sure these ones have been missing the whole time I've owned it. Didn't even try them just put the new ones in.
  16. Dec 26, 2023 at 12:59 PM
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Sales dept took in a Taco on trade. I snagged the hitch cover :)
  17. Dec 26, 2023 at 1:05 PM
    Heathen
    Tripleconpanna, Voss, bmf4069 and 3 others like this.
  18. Dec 26, 2023 at 1:06 PM
    I go nowhere without my 3" drop hitch with 2" ball on it in the receiver. Saved me too many times from rear end damage.
    Tundra2, Tripleconpanna, Voss and 4 others like this.
  19. Dec 26, 2023 at 1:12 PM
    The Black Mamba
    DFW
    Imma keep it stock
    I really should be doing that. You can see by the bend in the 4 prong that I've already been tagged once.
  20. Dec 26, 2023 at 1:28 PM
    Bought one of these to replace my wife’s after it went missing in a parking lot. Got stolen again at an Air BnB in Tybee. Replaced it again. Got stolen again. Gave up.
    Tripleconpanna likes this.
  21. Dec 26, 2023 at 1:52 PM
    The Black Mamba
    DFW
    Imma keep it stock
    03 Pre-Runner 182K and they already sold it for 9.5k
  22. Dec 26, 2023 at 2:57 PM
    The police can fine you in my state for having that without a vehicle in tow. Not that I've seen it happen but it does go against your record and add at least a couple points.
  23. Dec 26, 2023 at 3:02 PM
    bfunke
    bfunke Tundra Curmudgeon
    Such Nor’easter BS
    txagg and Jack McCarthy[QUOTED] like this.
  24. Dec 26, 2023 at 3:04 PM
    Yep. Anything to add points and increase your insurance here for the next 6 years. They got rid of state regulated car insurance which falsely leads you to believe the rates went down. Well they did, but only if you never get a ticket or in an at fault accident.
  25. Dec 26, 2023 at 4:35 PM
    They can kiss my ass
  26. Dec 26, 2023 at 6:53 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Trailer hitch, to load or not to load?
    my hotrod had a European hitch on it, weren't no removing it. I've come out & seen my hitch ball imprint in the front plate of the car behind me. :)
    you get rear-ended with the ball in & it ups the chance of bent frame.
    knew a guy, coming out of a bar, dark parking lot, walked right into someone's drop hitch. Right to the shin. When he finished 1-foot-dancing he removed the hitch & threw it through the back window.
    Pros & cons to leaving your hitch loaded.
    oscardog86, Voss, Mr.bee and 3 others like this.
  27. Dec 26, 2023 at 6:56 PM
    Exactly, the hitch isn’t a shock absorber, it transfers the energy somewhere………
    oscardog86, Tripleconpanna and Voss like this.
  28. Dec 26, 2023 at 6:58 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I like your trailer light harness holder thingy. I need one of those for Dad's Taco.
  29. Dec 26, 2023 at 6:59 PM
    This happened to me when I was 16. My friend Sean saw it, got pissed off by the situation, ripped both their side mirrors off.
    I’ve since taken two to the shins, smarts both times, but after how many times I’ve taken skateboards and kicks to the shins over the years, it was just an “ow”, not much else to speak of.
    Voss and NUDRAT[QUOTED] like this.
  30. Dec 26, 2023 at 7:01 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    We walk faster up north than you southerners. o_O
    Voss, Jack McCarthy and cody c like this.
