SPC UCAs Too Close to Tire?
Discussion in 'Suspension' started by AggiePhil, Dec 24, 2023.
  1. Dec 24, 2023 at 6:02 PM
    AggiePhil
    AggiePhil [OP] Texas Chapter President
    College Station, TX
    Just installed a 3” lift and SPC UCAs on my 2020 last week. Still has the factory wheels and tires. Is it just me or is this UCA ball joint really close to the tire? Don’t think it’ll be a problem with this setup but will it be in the way when I upgrade to 33s or 35s? Surely others have run this combo. Not quite sure why it’s so close. Or is it?
  2. Dec 24, 2023 at 6:08 PM
    That last picture looks really close. You could run Spidertrax spacers if keeping the stock wheels.
    Black Wolf likes this.
  3. Dec 24, 2023 at 7:11 PM
    AggiePhil
    College Station, TX
    As is, with the smaller tires, there’s more clearance than it appears due to the ball joint being further in than the outer edge of the arm. But with larger tires, I’m afraid it’d rub. Need to know that ahead of time, before buying wheels/tires, since I do not want to run spacers and really don’t want any more poke than I currently have.
    Is this a common problem? If not, what is different about my setup that’s causing it? :confused:
  4. Dec 24, 2023 at 7:22 PM
    2mchfun
    Precisely why I bought aftermarket rims with a +30 offset and a set of low profile fender flares. Worked out pretty well. Still need to get my aftermarket mudflaps mounted though. Good luck!
    CaptRussia253 likes this.
  5. Dec 24, 2023 at 7:23 PM
    AggiePhil
    College Station, TX
    I’m starting to think the SPC UCAs were unnecessary after all. :(
  6. Dec 24, 2023 at 7:25 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Offset is really the only problem. Those 60mm offset on the stock wheels are no joke - it just pulls everything in.
    Nothing wrong with running Spidertrax - just make sure you torque it down properly.
  7. Dec 24, 2023 at 7:33 PM
    AggiePhil
    College Station, TX
    Yeah, that’s what I love about them. Not a fan of the poked out look.
    Guess I never read in any of my research that SPC UCAs could interfere with the stock wheels. Figured they’d be an improvement in all regards.
  8. Dec 24, 2023 at 7:33 PM
    2mchfun
    Just buy and sell rims. Pretty sure Method has good sale prices right now if that helps.
  9. Dec 24, 2023 at 7:35 PM
    AggiePhil
    College Station, TX
    Not really a fan of aftermaket wheels. Was planning on using BBS TRD Pro or steel spare wheels. May have to rethink the whole plan now. That said, I did keep the factory UCAs…
    2mchfun[QUOTED] likes this.
  10. Dec 24, 2023 at 7:36 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    It would be an upgrade if you planned on running bigger tires with 3” lift. I knew I was going to get 37s, so UCA was going to help with alignment and clearance.
  11. Dec 24, 2023 at 7:37 PM
    2mchfun
    Trust me, +30 offset with a low profile flare looks great. Not poked out excessively and flares make the truck look "finished".
    AggiePhil[OP] likes this.
  12. Dec 24, 2023 at 7:38 PM
    AggiePhil
    College Station, TX
    Yeah, I thought the added adjustability would come in handy. Imagine my surprise when the alignment shop left the ball joints right where I had them. :facepalm:
    2mchfun likes this.
  13. Dec 24, 2023 at 7:41 PM
    2mchfun
    Greasable is a beautiful thing!
    pvn.beluga likes this.
  14. Dec 24, 2023 at 7:43 PM
    2mchfun
    Congrats on the Dobinson's lift!
  15. Dec 24, 2023 at 7:43 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Unless if you told them and gave them the spec sheet, they wouldn’t know to adjust the ball joints to whichever option that would give you more caster or less caster.
    I set mine up to setting A before bringing it into Firestone for my alignment.
  16. Dec 24, 2023 at 7:44 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Most def, 5-10 squeeze of moly into the ball joints every oil change does the trick.
  17. Dec 24, 2023 at 7:55 PM
    AggiePhil
    College Station, TX
    The new ones aren’t even greasable.
    They said they were familiar with them but I gave them the sheet anyway. Claimed the uppers didn’t need any adjusting to get things in spec, which I guess makes sense. I was just a bit miffed, thinking “What was the point then?”
  18. Dec 24, 2023 at 8:06 PM
    They are greaseable. You're missing your zerk fittings.
  19. Dec 24, 2023 at 8:09 PM
    2mchfun
    You can get greasable joints for a decent price if you want. Nothing wrong with having a set of back ups on board. I had mine set up close prior to alignment and the shop made zero adjustments at the upper ball joints. Most of the adjustment was toe. Good luck with it all, I truly know how it feels to have a few mods transform into many. I still have a bunch unfinished and waiting for time and weather conditions.Very frustrating for sure!
    AggiePhil[QUOTED][OP] likes this.
  20. Dec 24, 2023 at 8:10 PM
    His are greaseable. The zerk fittings are missing.
  21. Dec 24, 2023 at 8:12 PM
    AggiePhil
    College Station, TX
    They do make a retrofit kit to return these to the old design, but I’m not interested in doing that. Supposedly these are maintenance-free. Will see. The ball joints are the least of my concerns at this point. lol
    2mchfun likes this.
  22. Dec 24, 2023 at 8:12 PM
    2mchfun
    I think they have marketed them both ways at different times. I think the idea was "maintenance free" to be more competitive.
  23. Dec 24, 2023 at 8:13 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    If you wanted everything in spec, then there wasn’t a need to adjust the ball joint from the OE position you had it in.
    Goes back to your wheel/tire set up is when you’ll move the ball joint into the right position.
    Saltyhero13 likes this.
  24. Dec 24, 2023 at 8:18 PM
    NWPirate
    Zach
    WA
    The Pro wheels should help your clearance issue compared to the Plat wheels, not positive on the offset numbers.
  25. Dec 24, 2023 at 8:19 PM
    AggiePhil
    College Station, TX
    I just measured and the tire is 1 1/8” from the UCA at the closest point. So I think it’s fine for now but yeah, an increase in tire size by 1-3” would likely be a problem.
  26. Dec 24, 2023 at 8:20 PM
    AggiePhil
    College Station, TX
    Same offset for all the factory wheels, minus the Rock Warriors and maybe the TSS ones.
    2mchfun likes this.
  27. Dec 24, 2023 at 8:22 PM
    NWPirate
    Zach
    WA
    Damn, sorry. I always thought the Pro wheels had more positive offset :monocle:
  28. Dec 24, 2023 at 10:12 PM
    AggiePhil
    College Station, TX
    What if I were to move the ball joint out as far as it will go in the slot? It’s currently in the middle. Would that help?
  29. Dec 25, 2023 at 4:47 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Follow the instructions. If you do that then you’re also either adding or subtracting caster and it’s going to result in a realignment - unless if you do it yourself.
  30. Dec 25, 2023 at 6:13 AM
    2mchfun
    I'm surprised that you haven't already. Mine are either there or really close to it and it has a great alignment overall. It does give me quite a bit of gap with a 285/75 18 and +30 rim. I could likely go with a stock rim but I like the "finished" look that the flares give. Plus it gives a little door/shopping cart protection, which is another reason I did it this way. As long as it can't rub, close is fine. The tire doesn't flex or bulge at the top and it can't really make contact unless something goes bad at the hub such as loose nuts or a bad bearing.
