General Supercharger Thread
  1. Dec 24, 2023 at 7:13 AM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    I wonder if the 3URFE ECU can support two MAF sensors like some of the Lexus V8 engines do? Perhaps another reason to chase that direct injection swap?
  2. Dec 24, 2023 at 7:14 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    All-righty, that makes sense. I think that I'm also remembering it being mentioned (possibly by SNS) that when the flow limit is reached (512g/s) that the ECU simply uses the last known values for anything greater. That sound right? I'm not as concerned with maxing the airflow as I am with maxing the fuel, that seems more hazardous, so I'll start by boost referencing the FPR. I have these couple of weeks free to focus on it, so that's where my mind will be. Everything seems to be kosher up until the very maximum, so like you said, it's not something to loose sleep over as it's not typically how I drive; I'm not drag racing spending all my time at WOT.
  3. Dec 24, 2023 at 7:26 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
  4. Dec 24, 2023 at 7:27 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @Wynnded Is this where SNS talks about it?
    The basic process for determining air mass is:
    1. Reference current MAF sensor voltage
    2. Look up base mass airflow for current MAF voltage from Engine -> Airflow -> General -> MAF Calibration -> Airflow vs. Voltage
    3. Look up base mass airflow correction for engine RPM and throttle angle from Engine -> Airflow -> General -> MAF Correction -> Base
    4. Look up IAT mass airflow correction for Intake Air Temp and base mass airflow from Engine -> Airflow -> General -> MAF Correction -> IAT
    5. Calculate final, corrected mass airflow by multiplying the lookup values:
      Final Mass Airflow = Base Mass Airflow * Base Mass Airflow Correction * IAT Mass Airflow Correction
    • During large transients, the PCM models airmass instead of taking values directly from the MAF. If you log MAF and Absolute Load during a large throttle transient, you'll note that Absolute Load does not track perfectly with MAF under those conditions.
    • MAF Voltage is limited to 5V, Mass Airflow is limited to 512 g/s. Above 5V, a larger intake is required to bring the sensor into range. Above 512 g/s the tune will need to be scaled to bring the air mass back into range.
  5. Dec 24, 2023 at 7:35 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I can't collect my pink slip from the ditch! :rofl::bananadead:
    Mdl and Silver17[QUOTED] like this.
  6. Dec 24, 2023 at 7:43 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    This looks to be what I'm remembering...
    Mdl[QUOTED] and snivilous[OP] like this.
  7. Dec 24, 2023 at 7:43 AM
    Jowett
    Jowett New Member
    North Adams, MA
    Many on the way.
    The coil arrived and is obviously different, so a little research leads to the following… For the newer generations of engines, Toyota has moved the goods up and out of the spark plug tube, it’s no longer a stick or pencil type unit, but a top mount coil. This move is for an increase in durability due the coil being able to run cooler. The engine literature also mentions these are a high energy type, but do they produce more of what we need? I suspect they might. While not listed as a Dynamic Force Series Engine, the 8ARFTS was a transitional engine that uses much of the newer DFS technologies. Just as with the run to higher performing spark plugs to prevent misfires, perhaps too with the coils?
    They physically bolt in place of the stock coil, and the wire harness plug snaps right on. The harness connector is a much more durable type, and supports the wires leading into coil with a loom. Now to find out if they are truly compatible.
    New type.
    Old type.
    A62216FD-B871-4F19-9793-F2C7B696985D.jpg D8A29F42-EBF6-4CBE-BE38-7D5657CFA127.jpg
    M3Tundra-JK, e30cabrio, Mdl and 5 others like this.
  8. Dec 24, 2023 at 7:56 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I love that Toyota makes things that can (theoretically/potentially) be used in multiple models. Some of the Tundra/Sequoia/Land Cruiser mechanicals/electricals. Now potentials like this.
    Mdl, snivilous[OP] and Jowett[QUOTED] like this.
  9. Dec 24, 2023 at 8:14 AM
    Jowett
    Jowett New Member
    North Adams, MA
    Many on the way.
    Yes, Toyota does very well parts sharing between models.
    Sometime it’s the little things, like the two piece connector that captures, supports, and protects the coil wire harness. Tell me this won’t look cleaner while doing an actual job…
    e30cabrio, Mdl, Saltyhero13 and 6 others like this.
  10. Dec 24, 2023 at 9:14 AM
    snivilous
    SW UT
    300k+ Supercharged 2008
    In regards to fueling, something else to keep in mind is the tune may not command 100% injector duty cycle without some adjustments. If you have PE maxed out at 1.5 and look at the datalog and the duty cycle is at 80%, you need to rescale the MAF/IC so it will command 100% duty cycle. An injector constant of .09 with 1.5 PE might be 80% duty cycle, if you change that to a IC of .11 (telling it it has a smaller injector, so because of that will open the injector longer to try and get the same perceived fuel flow) now you'll be at 100% duty cycle at 1.5 PE, and because you adjusted the IC you then need to adjust the MAF flow down by the same amount so it thinks there's less air so commands less fuel, but with the larger IC ends up being the same result AFR.
    My point being, your truck leaning out may not be because the injectors are maxed but because the tune won't command them all the way open, and without the datalog showing the duty cycle, if you just keep increasing PE based on your AFR gauge that might not utilize everything possible.
    ARES35, Mdl, Saltyhero13 and 2 others like this.
  11. Dec 24, 2023 at 10:34 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I'm realizing that it's a lot like this:
    ...But I understand it more and more every time you and I discuss it, and I appreciate that.
    My IC is 0.1, anything lower and it struggles to hit stoichiometric at idle with the TRD Airflow v. Voltage map, which I think I've mentioned to you SNS pushed to try to maintain some semblance of, and my PE is 1.2 so there'd be room there. Actually, if I could get my wideband to cooperate and logged, I might even be able to lower that a smidge. I think that if I were to lower the IC and thusly increase the Airflow table to hit stoich, I might hit the 5V barrier earlier; am I getting this right? Oh, you know what, for a little trial and error, I enabled the COT, I wonder if that could be eating up some of the injector flow capability during PE resulting in the high Inj DC percentages. What's your thought on that?
    It pains me to just sit here today though, I wish I could get out and try some things, but so many of the roads are closed here today with all the travelers sliding off the road with the snowfall.
    Terndrerrr, ARES35, Mdl and 1 other person like this.
  12. Dec 24, 2023 at 11:59 AM
    snivilous
    SW UT
    I'll preface this as always in case someone new is reading this by saying I'm not a professional tuner, and some of these points below may not be entirely correct but in my experience work totally fine in this simplistic view. For instance Silver17 said DAP did stuff to fix the 5V limit issues he had, I'm not disagreeing that's possible, but that's beyond my scope of experience and following the below has always worked for me and at this point numerous others.
    The IC is somewhat arbitrary. The combination of IC and MAF and fuel trims should hit stoichiometric everywhere, if your fuel trims are zero then your IC and MAF relationship is correct. I start with the TRD values, but I may deviate a ton from those and that's fine. If the MAF flow hits the max, and fuel trims are zero, then just scale IC and MAF together to get MAF flow back within bounds. None of that should change being able to hit stoichiometric. If you have issues hitting stoichiometric, I would interpret that to mean your fuel trims are maxed out.
    The 5V barrier is a relationship with the intake and nothing else. You can't tweak things to make it hit 5V earlier or later because it's purely based on mechanical deflection of the sensor. The sensor hitting it's hard stop is 5V, nothing about the tune changes where the hard stop is because that's just a matter of air hitting the sensor and bending it over.
    As far as COTS is concerned, I set the base values to 1 so 99% of the time it doesn't do anything. However, I don't straight up click "disable" because that keeps the other COTS functions active like retard enrichment and stuff. How valuable that is I don't know, but SNS had mentioned doing that because you keep COTS side effects active but effectively turn off the catalytic converter enrichment which throws AFR for a confusing loop. I have disabled COTS entirely before because I was suspicious it was doing things, I've also turned it on and fucked with the base values to try and richen out the fueling even more but both those circumstances were trying to troubleshoot things. In normal form, I set the base multipliers to 1 and leave the other tables.
    ssmokedz, ARES35, jhrrld and 6 others like this.
  13. Dec 24, 2023 at 12:06 PM
    snivilous
    SW UT
    To add a specific example to the above, a week ago @helidave and I were tuning his truck. I started with the TRD MAF and IC values, and got his fuel trims to zero by slightly tweaking some MAF values. However his fueling was off, he was above 11 for AFR even after I maxed out PE to 1.5, but his duty cycle only showed 80%. To fix this, I increased IC by 20% so it'll flow 20% more fuel, reduced the whole MAF table by 20% so it thinks there's 20% less air to cancel out the 20% extra fuel, and then decreased PE by 20%. We are effectively at the exact same point we started at now, except PE is now below the 1.5 max limit, so we have 20% more fuel to add by increasing PE again.
    In this case, the TRD values for everything are long gone. Which is even more odd since he has the Magnuson intake and injectors so I thought it would've been a walk in the park since those are known values, but for whatever reason did not work in his case. Now however, he has PE left to play with, the MAF/IC relationship is the same so the fuel trims are happy, and the truck is right at the AFR we want.
    Again, maybe my approach is simplistic and wrong, that's why I tell people to try other tuners first. For instance maybe the efficiency tables should be modified also, that's not something I've screwed with but I also haven't seen any need to screw with.
    ARES35, jhrrld, e30cabrio and 5 others like this.
  14. Dec 24, 2023 at 12:13 PM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    The truck runs good, I'm learning a ton about tuning, and if I want to tweak something I'm not locked out of the file. Sounds like a good deal to me :thumbsup:
    ARES35, nobodyintexas, Mdl and 2 others like this.
  15. Dec 25, 2023 at 6:37 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
  16. Dec 25, 2023 at 8:13 AM
    Grenades4Bacon
    Grenades4Bacon New Member
    2019 Tundra
    Yes!
    I have a suspect bad set of DW650s. Injectors behave really strangely going extremely rich or lean randomly. DW is going to take them back for testing, and replace as a warranty claim.
    Meanwhile I'm getting a set from another member on here to test/validate the injectors being my issue before installing a new set of FICs.
  17. Dec 25, 2023 at 2:14 PM
    helidave
    flagstaff
    2015 DC 4x4
    Mdl likes this.
  18. Dec 25, 2023 at 2:20 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Improvement in what respect? lol K&N flows good, but doesn't filter so well. I currently use the AFE DryFlow and it does a much better filtering job. I don't think it's restrictive at all, at least not according to my airflow restriction gauge. WIX makes a pretty good air filter too.
  19. Dec 25, 2023 at 2:24 PM
    helidave
    flagstaff
    2015 DC 4x4
    I've never been super impressed with K&N stuff, so if there's something that's better at keeping crap out of the engine but doesn't hurt performance, im all for it.
    Mdl likes this.
  20. Dec 25, 2023 at 2:40 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    Wix is the answer. I use them because I work in dustville.
    Project Farm says so.
  21. Dec 25, 2023 at 2:43 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I agree. I've been opposed to KN for sometime especially in dusty or sandy desert areas. I'll run afe dry or wix filters.
  22. Dec 25, 2023 at 2:50 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @snivilous thanks for all your simplistic approaches to tuning. When we all have similar setups sometimes it's not all plug and play and requires a different approach. I've been saving your posts on tuning on here and hpt from SlowNStock posts.
    Thanks!
  23. Dec 25, 2023 at 2:55 PM
    helidave
    flagstaff
    2015 DC 4x4
    Does the magnuson airbox use 2013 tundra filters?
    Mdl and PolishedTRD like this.
  24. Dec 25, 2023 at 3:56 PM
    PolishedTRD
    PolishedTRD Lorem ipsum dolor sit amet
    CO
    Supercharged 2011 DC
    Magnuson's Finest Whine
    I found that Napa’s branded filter is just a Wix re-brand without the added cost. I throw a new one in every oil change, as cheap insurance.
    Yes
    Saltyhero13, Mdl and helidave[QUOTED] like this.
  25. Dec 25, 2023 at 4:15 PM
    helidave
    flagstaff
    2015 DC 4x4
    Do you notice any performance difference between the afe and wix?
    Mdl[QUOTED] likes this.
  26. Dec 25, 2023 at 5:18 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    It bit subjective but I read a comparison of top filters and the wix/stock paper flows best with good contaminate entrapment.
    I was gifted 2 afe dry filters and been using them the past 8 years. Was just thinking of trying paper again...
    helidave[QUOTED] likes this.
  27. Dec 25, 2023 at 6:14 PM
    snivilous
    SW UT
    Yes sir! I've been wanting to make a YouTube video of the full break down of how to build the tune, what does what, how to datalog, what to take away from it, etc. It's hard to find all the pieces, let alone in one compact and simple form somewhere.
  28. Dec 25, 2023 at 6:49 PM
    blenton
    blenton New Member
    No love for the OE Toyota filter? Simply due to cost? Or…?
    Also, anybody know a good place to buy the upper Magnuson box/intake? I found the part number 100 pages back but am striking out online. Admittedly, I haven’t called Magnuson or Super Chargers Online directly (seems I only remember to look for it after business hours).
    Mdl likes this.
  29. Dec 25, 2023 at 7:30 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Oh yeah the Toyota paper filter was top rated.
    I mentioned "wix/stock paper filter" but could of clarified it better. The study was from about 2015 but think it's relevant today too.
    I found a trd lid online but can't find it.
  30. Dec 25, 2023 at 8:13 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Wix filters best, AFE Dry is the balance of gains and filtering ability...dependant on where one lives/drives tho...in the desert, Wix...in the mountains or roads less traveled, AFE...corporate sponsorship, K&N...
    Mdl, M3Tundra-JK and helidave like this.
