General Supercharger Thread
  1. Dec 22, 2023 at 8:51 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Modular, for a variety of diameters....naturally! :D
    Mdl and ARES35 like this.
  2. Dec 22, 2023 at 8:53 PM
    ARES35
    ARES35 New member for life
    Mile high
    Oh man that would be icing on the cake there! :bowdown:
    Mdl and Wynnded[QUOTED] like this.
  3. Dec 22, 2023 at 10:00 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, solid Offroad engine mounts, DIY Traction Bars, Tuning by snivspeedshop.com
    $3500? New is what...$7500. I got mine for $2k minus fuel pump and idler pulley with 30k on it. But that was in 2013. Make sure you download the parts list and inventory what your getting.
  4. Dec 23, 2023 at 7:29 AM
    snivilous
    SW UT
    300k+ Supercharged 2008
    I paid $3k, I would have a hard time paying over $4k since "complete" is never complete, so you're not saving much past that point.
    Especially since newer and improved superchargers are $7k new now.
    Mdl likes this.
  5. Dec 23, 2023 at 7:30 AM
    snivilous
    SW UT
    That would be dope, but the probably $25 for a basic pulley probably outweighs any benefits otherwise :D
    Wynnded[QUOTED] and Mdl like this.
  6. Dec 23, 2023 at 7:36 AM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    The advantage is of the t-belt pulley are bearing diameter and width… they are enormous. The size obviously increases life, but also stays true and flat, which keeps the belt flat and aligned going on and off the SC pulley.
    That last little bit of extra is always relatively pricey.
    Wynnded, Mdl and HulkSmurf14 like this.
  7. Dec 23, 2023 at 12:25 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    All-righty, the K081145 (standard) / 5081145 (heavier duty) belt seems to be working and not slipping as near as I'm able to determine.
    Here's an at present unverified list of alternate applications/part numbers that I stumbled upon:
    • Brand: Chrysler, Interchange Part Number: 5143206AA (possible source)
    • Brand: Dynacraft, Interchange Part Number: 4081144RP
    • Brand: John Deere, Interchange Part Number: T187704
    • Brand: Mercedes-Benz, Interchange Part Number: 1129970092
    • Brand: Size Designation, Interchange Part Number: 8PK2910
    • Brand: ACDelco, Interchange Part Number: 8K1145
    • Brand: Carquest, Interchange Part Number: K081145
    • Brand: Dayco, Interchange Part Number: 5081145
    • Brand: Goodyear, Interchange Part Number: 4081145
    • Brand: Metric, Interchange Part Number: 8PK2910
    • Brand: NAPA Belts/Hose, Interchange Part Number: 25-081145
    I was able to get a 25-081145 belt from NAPA. I'm not going to recommend them unless you're able to get it from them for a great deal less than what I did. It was a rip-off at just under $100 (I feel ~$50 would be fair), the most I have ever paid for a belt, in any context. I'm a bit sour about that but I wanted to get this figured out as soon as I was able. I did it for the likes...;):rofl:
    I was able to test it out as the roads were drying out after a slight dusting of snow. It was just above freezing at 8000ft. My boost gauge showed 7-7.5psi depending upon the specific run. I got a couple WOT logs and have pretty much maxed out my injectors and the MAF voltage, 97% and 4.8V respectively. AFRs in the mid 10s. They're the 720cc injectors and RCF MAF and a smaller than normal SABM into the TRD/Maggie airbox with the AFE Dryflow drop-in filter. My rev limiter is set to 6500rpms and when I look at the log it's shifting at 6300rpms.
    Hope this helps! :thumbsup:
    snivilous[OP], AZTundra, Mdl and 7 others like this.
  8. Dec 23, 2023 at 12:31 PM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    7.5psi at 8000' :eek2:
    Mdl, ARES35 and Wynnded like this.
  9. Dec 23, 2023 at 12:35 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    I am bowing in your general direction
    Mdl, ARES35 and Wynnded[QUOTED] like this.
  10. Dec 23, 2023 at 12:38 PM
    ARES35
    Mile high
    Thank you for the information! Looks like you have found the perfect belt for the 70mm. 7-7.5 seems like a good amount at 8k ft! Surprised you're maxing out 720cc injectors that high but in the 10's makes sense. With 86 Im seeing 5.9/6 in front range. I'm still in the search for a belt thatll wrap the 76mm only stopped in Oriellys thus far
  11. Dec 23, 2023 at 1:05 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    You might be able to get away with the stock belt, only one way to find out. :D
    I was kind of surprised about the injectors as well, but I noticed a flash of 8.8 on the gauge as well, so there might be room for refinement. It just seems that I'm not able to get my Innovate AFR gauge to log with HPT so I can see where that's happening. I'll have to just continue to mess with it, I'd like to see if I can come up with just a bit more of a safety margin with the Inj DC. Tinkering never ends! :cool:
    ARES35[QUOTED] likes this.
  12. Dec 23, 2023 at 1:06 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Awesome! I’m sure it feels pretty good. Maybe time for a higher pressure and/or boost referenced FPR to help reduce your duty cycle?
  13. Dec 23, 2023 at 1:17 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I've seen these mentioned, but just kind of ignored them for the time being. Briefly, how involved are each? Currently my FPR is connected in the stock fashion, to the intake tube.
  14. Dec 23, 2023 at 1:19 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    All the horsepowers
  15. Dec 23, 2023 at 1:24 PM
    Silver17
    Eastern PA
    Can’t comment on the aftermarket ones and therefore the necessary plumbing changes. I would probably get an OEM Toyota FFV FPR since those are 60psi instead of 43.5, or maybe buy one from Harrop. Boost referencing is just a matter of teeing that line into the boost port. You would need your tune adjusted for it though, but it would definitely lower duty cycle.
    Mdl, helidave and Wynnded[QUOTED] like this.
  16. Dec 23, 2023 at 1:32 PM
    Silver17
    Eastern PA
    Mdl and Wynnded like this.
  17. Dec 23, 2023 at 1:32 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Ah, easier than falling off a log, it sounds like boost referencing would be the logical place to start. I'd not read of changing out to the FFV FPR, that might have some appeal too. I just had a glance at the paperwork for the injectors I'm running but it doesn't give flow rates for pressures other than 43.5psi. Maybe I can find that with some interweb action. I'll see what boost referencing does for me first, I don't have to order parts to do that! Thanks.:hattip:
    helidave and Silver17[QUOTED] like this.
  18. Dec 23, 2023 at 1:35 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    I still haven't found out how much PSI Harrop modifies theirs to. I guess I need to throw a gauge on and find out.
  19. Dec 23, 2023 at 1:41 PM
    Silver17
    Eastern PA
    Mdl likes this.
  20. Dec 23, 2023 at 1:53 PM
    VWTim
    Corvallis, OR
    I just pulled out the URD pressure tap that installs below the FPR and realized it won't fit due to the return line sneaking under the IC coolant reservoir. I'll have to grab the NX port fitting and report back.
    Mdl, HulkSmurf14 and Silver17[QUOTED] like this.
  21. Dec 23, 2023 at 2:11 PM
    VWTim
    Corvallis, OR
    I found a company called Racetronix, they make a similar fitting for less than $15. Decided to give that a try, fitting and gauge ordered.
    HulkSmurf14 likes this.
  22. Dec 23, 2023 at 2:12 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Bought time you get a gauge!!
  23. Dec 23, 2023 at 3:01 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I found the info for my injectors. According to that, they are said to flow in the neighborhood of 800cc/min at 58psi. I found a length of hose in a tool box drawer and I'll see if I can find a t-fitting in my stash of miscellaneous at work and see what boost referencing does before trying anything else.
    ARES35, Mdl, Silver17 and 1 other person like this.
  24. Dec 23, 2023 at 6:02 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Having them boost referenced should help out and richen up the afr. I had to reduce PE in the 3000rpm and up range.
  25. Dec 23, 2023 at 8:02 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Cool, I don't know why I didn't pick up on this information before. Distracted by other things I suppose...:notsure::rofl:
    If I max out the MAF voltage at some point, and I mean just barely, would scaling the remedy for that? I'm sure there are probably limits, but is that done with one of the maps/tables in HPT, and how might one go about that? I'd reference the one that I've always suspected, but I can't recall it off the top of my head, and HPT is on my other computer otherwise I'd look it up. I could be way off in how I'm thinking about some of this though.
    Have you encountered this bit of info about resetting learned values? It looks like it can indeed be done via Techstream.
    https://www.tacomaworld.com/threads...smission-learning.422915/page-2#post-15694509
    ARES35, HulkSmurf14 and Mdl[QUOTED] like this.
  26. Dec 23, 2023 at 11:47 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I just need to find someone in my area with Techstream.
    I believe @snivilous said to take the fuel trim and multiply by the corresponding maf voltage percentage to get a correct maf value...or something like that. I'd reach out to him.
    Wynnded likes this.
  27. Dec 24, 2023 at 5:47 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Ah okay, I think I know what you're talking about. That sounds like the MAF Calibration table, Airflow vs Voltage. The table that I was thinking of, and don't know if it's something relevant for us are the MAF Correction tables, Base and IAT. Thanks.
    ARES35, Mdl[QUOTED] and HulkSmurf14 like this.
  28. Dec 24, 2023 at 6:34 AM
    Silver17
    Eastern PA
    @TurboKits.com was working on some device of sorts to solve the MAF voltage issue that it sounded like they may offer for sale. I don’t really know the details though. Perhaps Jesse can give details.
    There may be ways around it via tuning, I know DAP had found a way around it when I had the stock intake with the 80mm pulley. That said I don’t think it’s technically the right way, and I did get occasional P0101 codes. Otherwise I think the only proper way to solve it is to get a larger MAF tube and scale for it. I was at 4.97v with the 80mm on the magnuson intake (I also used air straightening honeycomb before the MAF which may have made it read higher.) I’m sure I’m hitting the ceiling now with the 77.5. Being remote tuned though I think I was tuned way excessively rich though, so if anything it’s probably better AFRs now.
    TurboKits, ARES35, Mdl and 4 others like this.
  29. Dec 24, 2023 at 6:45 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Ah, I'll peruse through his posts to see what he's mentioned so far. Thanks.
    Mdl, Silver17[QUOTED] and HulkSmurf14 like this.
  30. Dec 24, 2023 at 6:58 AM
    snivilous
    SW UT
    This is my understanding:
    If the MAF voltage hits the limit you're kind of SOL. If the MAF flow rate value hits its limit, that is different and can be adjusted for. The voltage is mechanically derived from the sensor which is why it can't be adjusted in the software. The sensor deflects so far from airflow and that's 5V either way since you pegged the deflection it can read. The resulting airflow measurement also has a cap, but that's software driven so by changing other variables like injector constant you can keep the airflow value inside the software limits.
    MAF voltage limit -> bigger intake
    MAF flow limit -> adjust IC and MAF table
    With that said, if you just tickle either of those at the high end I wouldn't sweat it. Worst case you get a CEL that does nothing when you're WOT at 6000rpm. As long as the voltage doesn't max earlier since then you don't have MAF data for the higher rpms since it can't read anything then.
